Question about Yamaha GX-500B Shelf System
Memory loss Hi, I have a problem with my Yamaha GX-500CD shelf system. (Not sure if this is the same as GX-500B) It's a great system, but in all the time I've had it, the briefest interruption in mains power wipes all the station memories. I had got to the point where I no longer bothered using the radio section (we live in an area prone to regular power outages) as it's an absolute shocker to reprogram. The other day, I noticed an item in the manual to say that it's supposed to hold its memories for a week! And given that it's actually quite a nice tuner, I've decided I'd like to try using it again. Now, I'm a radio tech and Ham radio operator, and I have the service manual, but at 60, my knowledge is a little (ok, a lot) out of date, and I cannot see HOW it's supposed to hold the memories. I can't find a battery or supercap anywhere, and would have expected non-volatile ram to hold the memories forever. Can you help, or tell me what to look for...? I have not, at this stage, opened up the unit. Thanks, Michael
  • Yamaha Master
  • 5,683 Answers
See if you can find one of these capacitors. It's called a memory retention capacitor they are normally squashed looking things. Voltage ratings around 6 volts.
If you do replace it.
Posted on Mar 08, 2017
SOURCE:
  • 238 Answers
SOURCE: remote control
hi, ya if u know the exact model no. of the remote you can buy a spare one from the manufacturer or any dealer, try searching it on the internet first.
Posted on Jan 03, 2008
  • 3 Answers
SOURCE: Yamaha NX-SW300 sub woofer
Yes, that type of connector is often used for a VGA signal for a computer monitor. But in this case it is an all-in-one connector Yamaha used in order to simplify the hookup of this home theatre system. Unfortunately, the subwoofer is only usable with the DVR-S300 receiver/DVD player.
Posted on Jun 11, 2008
SOURCE: Looking for circuit diagrams for yamaha dx21
Have you managed to locate a DX21 service manual yet?? What problem are you experiancing with the 21?? From your request notes you mention 'all audio sections are live', do you mean that you have no audio from the 21?? Most faults i have experienced with the 21 are, failure of the main OPP YM2164 fm chip and associated D/A convertor(YM3102). In some cases YM3102 is ok .When the YM2164 fails, DX21 will boot as normal but no sound whatsoever from the audio out's. YM2164 is the main tone generation ic. Also when YM2164 is replaced, if sounds are reloaded back into the memory areas from ROM and the display reads gibberish in certain memory areas then a ram or rams have failed also. The crunch, Don't expect to get a YM2164 and Associated components easily, these things are very rare. I have seen the YM2164 fetch £35!! Best way around this, if you are eager to repair the synth is to purchase a working YAMAHA FBO1 FM MODULE ,not a popiular module and sell for about £20 - £50 on ebay. You can rip the parts out of the unit and use them in the 21. Sell whats left on EBAY spares or repairs.
The damaged (i believe) is caused by failure in the powersuppy causing voltage rails to 'spike'. What is strange is the cpu stays in tact. Capaitor replacements can cure this problem. I have a complete circuit diagram i can scan and email to you for a small fee for my time if required . email me:- proteus4@blueyonder.co.uk
Posted on Mar 08, 2009
smarthome2
  • 1114 Answers
SOURCE: Yamaha RX-V2500 completely shut down
Sounds like the volume control on zone 2 is your culpret. You should set up zone 2 to have a "fixed" output instead of "variable" it's in zone 2/3 setup. whats happening is you are overloading the volume control from the zone volume on the receiver and getting feedback to the receiver and shorting it out. What you do is put zone 2 to fixed output. set the vol control to 3/4 then adjust the vol to relatively loud and exit out of settings. this will be your max volume setting. Now, on to your problem.Unplug the receiver. There is an internal fuse that could have blown, not to likely but it's possible. You have to take the top off the receiver with a #1 phillips or a T10 torx they vary. It's about 7 screws, pop off the top and look from front to back, you will see 1 or 2 fuses near the AC plug port. Sometimes they are gray or white and you cannot visibly tell if it's bad. If you have a multimeter, set it tone resistance. Then put your leads on either side of the fuse, if you hear tone the fuse is ok. If not check your leads by touching them together and you will hear tone then test again. If you don't have tone, your fuse is bad. Radio Shack should stock the fuse you need. If you don't already know this, there are 2 Power switches for your unit. Front of receiver bottom left corner "Master Power" and normal Power switch "Main Power" check them both. If your fuses are good and power is good, you have bad transistors internally and it needs to go to service. check www.yamahausa.com support and service, and you can find the closest authorized service center to send it to. If you mail it out directly to the service center rather than taking it to a dealer, you will save some money and get it back faster. Lastly, pull your zone 2 volume control and look for black marks on it or white chalky substance. "oxidation". If you don't mind spending a little money on the system, hardwire the speakers thru and replace the volume control with an IR receiver. If you could control the zone from the zone by pointing the remote at the volume control you had an IR vol control. You really didn't need the vol part. Xantech or Proficient make good IR receivers that aren't too expensive and will keep this from happening again. If you need any more help, I am a Yamaha Dealer, let me know where your located and I can send you to a good service center. Just post a comment and I'll get you the info you need. Hope this helps
Posted on Jun 06, 2009
finish line
  • 207 Answers
SOURCE: power trim on 60 hp yamaha quit working
find the solenoid for the trim it will be a the engine or on the trim motor it self get a test lite and find the power wire on the trim motor and with someone pushing the trim button test the hot on the motor if there is no power it is the solenoid if there is power u my have a brush stuck in the trim motor itself but 99% of the time it is the solenoid u can tap the trim motor and see if that gets a result but dont hit hard
Posted on Jul 09, 2009
Is it possible to program an alternate remote to replace the Yamaha GX-50 OEM remote VU506200.
You could pick up a new one at this website for $40. Not sure if that is feasible.
YAMAHA GX 50 AUDIO REMOTE CONTROL SYS1 VU506200
I believe the ZA11360 remote works with Amplifiers and is not compatible with the GX-50 mini sound systems. You could try and buy a universal remote and then try and program it for the GX-50 but it is hard to find codes. There are a few Yamaha sound system codes available on the web and you could try these with the ZA11360. But these are for Yamaha CD players. Try one of 60036, 60490,61907.
Aug 03, 2014 | Yamaha Remote Control VU506200...
Speaker wire replacement for Yamaha GX550
The usual repair is to trim the broken ends, strip insulation for 1/2 inch, and insert the new ends into the connectors
Sep 29, 2012 | Yamaha GX-505 CD Shelf System
The cassette player door on my Yamaha GX-500 system doesn't open fully. The motor is working, but the door only moves one-half inch. Possible/expensive to fix?
Hi. I suspect that the belt may be worn and/or the motor pulley may be contaminated with dirt and dust. This would cause the belt to slip on the pulley when under tension / load. I would recommend cleaning the open / close mechanism with an alcohol based solution and a cotton-bud / cuetip - (those things you would use to clean your ears).
Hope this is of some help to you.
Aug 02, 2011 | Yamaha GX-500B Shelf System
ER message for CD, Sharp GX-CH150
The optics assembly is having a problem. Either it can not read the disc at all or the disc is not spinning. In any case, the unit will require service. If you can reach the lens, try cleaning it using a cotton swab and alcohol. That may resolve the problem. If not, update this. Please try to see whether or not the disc spins and report that as well.
Thanks,
Dan
Apr 07, 2008 | Sharp GX-CH150 Shelf System
Cd tray stuck closed
open the cabinet and remove the magnetic lock placed on the top of the mechanism then u can remove the cd
Jan 02, 2008 | Yamaha GX-505 CD Shelf System
Connect to computer
hi, you will need some cables for this job. to connect ur GX to the comp will take a stereo RC to EP cable, the RC connectors will go to the line out of ur GX and the EP will go to the line in of the comp sound card.. let me know
Dec 29, 2007 | Yamaha GX-70 CD Shelf System
Sound
hi, ya, someimes the POT i.e the volume controller variable resistor loses its contacts with the carbon strip. tru using some switch cleaning solution( NoN Acidic) to clean the POT,let me know
Dec 07, 2006 | Yamaha GX-70 CD Shelf System
Remote control
Nov 10, 2006 | Yamaha GX-70 CD Shelf System
63 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
