Question about HP Pavillion dv9740us Notebook
Location of SD port for SanDisk
Where is sd port and how do I insert?? Appears to be just a plastic insert w/ no cradle
    Brigadier General:
  • HP Master
  • 3,614 Answers
The hp laptops have a lil small slot on the left side under where the uilt in control goes if yours came with one
its a small thin line
just take your memory card probably sd and yeah its gonna b a lil bigger than the line thats ok its design for several different memory card types
just stick it on the side towards the monitor if it works a lil light should come on
if its a sony memory card u might need a small adaptor that are like a dollar
or if its a sd micro or min u need to get the daptor to turn it into a regular size sd card must memories card will come with those adapters when you buy them
hope this helps
Posted on Dec 24, 2008
Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
My Sandisk 'Wake up your phone' adapter & the micro one won't let me add music or anything else. It says that the disk is write-protected. Help?!
Micro SD write protect means there is damage to the firmware. Micro SD write protect, the data can be saved. Follow these steps:
Step One
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process repair micro SD.
Based on experience, the following methods can be used to repair the damage: RAW file system, used space 0 bytes, free space 0 bytes, micro SD can not be in the format, micro SD corrupt. To write protect a micro SD cases, 40% probability of success. But, you can try it. Good luck.
Step Two
Using the HP Drive Key Boot Utility, the first way
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extract.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, a second way
1. Open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - select Backup / Restore - click Restore - From filename, click Browse - Look In. Find the file initrd.img
2. If you are using Win XP, the location of the file in C: \ Program Files \ Compaq \ hpdkbu \ flash \ initrd.img - Next
3. If you are using Win Vista or Seven, the location of the file in the folder where you extract the files cp006049.exe. After the file is found, press Next
4. This process, will take a very long time, so you wait. This way you do for a capacity of 2GB. This involves when, the first way did not work. If the process runs smoothly, the chances of success, but if the process is running very slow, the possibility of failure and immediately stop the process. If you are unsure, or afraid to make mistakes, you should not do it this way.
5. After the process is complete, remove the micro SD card from the USB port, then insert it again.
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
Oct 10, 2011 | SanDisk 2GB microSD Memory Card
I have a 2GB micro sd card,but when i check it into my cellphone,my memory card is error.What is the problem of my memory?
All you have to do is:
Step One:
Step Two:
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extrack.
Oct 07, 2011 | SanDisk 2GB microSD Memory Card
How do I transfer pictures from my cell phone to my laptop
You can transfer pictures to your laptop by using a Micro SD card reader like the one in the image:
Insert the Micro SD to the slot which says "Micro SD" and then plug it in the USB port of your laptop. The laptop will soon detect the Micro SD. Open "My Computer" and then choose the removable drive which is usually E: or F: or G:. Thanks.
Sep 16, 2011 | SanDisk 2GB microSD Memory Card
Format micro SD card
Hi, The quickest way would be to insert micro SD card into an SD adapter or plug it into some card reader, then stick it into the computer's usb port. Proceed to "My Computer" right click onto memory card and select "Format".
I hope this helps.
Aug 10, 2011 | SanDisk 2GB microSD Memory Card
How to remove write protection from a sandisk hc memory card
Hello Friend,
  • There is a write-protection tab on the mini sd card HOLDER. Every time you insert this into your PC or card holder, this tab slides to the write protect position. Either keep resetting, inserting & reinserting until it doesn't slide or tape it down.
  • There is nothing wrong with the mini sd card. Simply locate the write protection key and push it.
  • The mini sd card has some error: Go for a low level formatting.
  • The card has virus: Remove the virus.
  • Change the Usb Port(Recommend you to Use Backside Port)
  • Change the Cable
  • Restart PC
  • Still have Problem Change Card Reader..
Hope this Helped you..Thanks for Contacting FixYa...........
May 28, 2010 | SanDisk 4GB microSDHC Memory Card
I have a sd micro card and i want to load music on it from my computer to put on my phone
This is a relatively easy problem.
You can do so by using a memory card reader.
You can easily get a memory card reader from any local store at a cheap price, depending on your country.
Most of the Memory card readers come in USB type, so what you just need to do is to plug it in any available usb port on your PC, and then insert your
sd micro card in the appropriate port for it.
For SD Micro Cards (The Smallest Types), most times you might need to first insert it in a Small Card Adapter that comes with SD Micro cards, before inserting it in your USB Card Reader.
Hope this helps you out.
Kindly let me know how it goes.
Good luck.
Nov 19, 2009 | SanDisk 1GB microSD Memory Card
Where to I put the chip in my computer?
You may have to get a card reader that takes stuff off and puts stuff on the sd card that connects to the computer using a usb port because most computers do not have an area where you can insert the micro sd card.
Nov 15, 2008 | SanDisk 2GB microSD Memory Card
Sandisk Adapter Problem in a HP Laptop
If you install SP3 it may work as SP3 updates the index parameters for file size limitations within such an old OS.
Oct 11, 2017 | Electronics - Others
Micro SD 2 GB just stopped working
The PIC or EEPROM inside these cards may not be working. I guess you best bet is to buy a new one try Kingston brand or go with another Sandisk.
Jul 02, 2008 | SanDisk 2GB microSD Memory Card
HP Pavillion dv9740us Notebook Logo
135 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
