SOURCE: Dear Sir, I am using Samsung
This happens when two or more similar (saving one number with different names) contacts is saved on your phonebook, i.e. if you've saved my number on the sim card with a name and at the same time you have my number (same number) on your phone's memory, the caller id will not be displayed, you'll only see the "Incoming Call" or "Call". So I would suggest you to please check the phonebook and delete (keep only one per number) if there are multiple similar contacts saved on your phonebook.
You can also reset the phone to Factory default, in case there's no problem with your phonebook/contacts.
Good luck.
Thanks for using FixYa.
SOURCE: Need to reset samsung galaxy s2 phone. Can't
If you want to try a simple solution, Go to Settings, Wireless and Networks, then Turn on "Airplane Mode" wait until you see an airplane on the top status bar of your phone... then Turn OFF "Airplane mode"
If that doesn't work, and you want to reset your phone, take it to the place you bought it or any place that is on your carrier.
SOURCE: free unlocking codes for samsung galaxy s2
Free codes does not work sometimes..So better you purchase the unlocking service from your network provider or you may get it from online providers like http://www.prounlocking.com/ .They will help you to unlock your mobile easily.
SOURCE: samsung galaxy S3 screen dims when it goes to internet
is the phone on light saver mode or is the wire bad?
SOURCE: My Samsung Galaxy S3 Showing Downloading Do not turn off target !! What I had to do?
yes you can remove batt.
1 - Switch ON your Samsung Galaxy S2 with a NOT ACCEPTED SIM Card.
2 - Compose : #7465625*638*CODE# (or *#7465625*638*CODE#).
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung Galaxy S2 is locked to.
CODE: Its the unique Unlock Code for your Samsung Galaxy S2.
