Konika 7022 copier F 51-6 error. Please help to resolve
  • Anonymous Mar 24, 2009
    Check the power supply or the motor itself?
    Problem Solver:
  • 8 Answers
Check polygon motor and printer drive board
Posted on Oct 06, 2012
    Sniper:
  • 87 Answers
That is for laser motor problem.just check it .check its supply or replace it.code will bi removed.MIAN AKHLAQ
Posted on Jan 03, 2009
Konica 7022 error F35-1
F 35-1 pertains to Abnormal Low fixing temp TH1. Try to clean the thermistor and reset the code by entering mode 25, software switch 3-1, make it zero. If the problem occur again, try to replace thermistor. Make sure that AC supply from mains is okay.
Aug 27, 2014 | Konica Minolta 7020 7022 7025 Copier Drum...
Konica 7022 26-3
Yes I stated what I recommended to do in your last post!
Jul 12, 2014 | Konica Minolta 7020 7022 7025 Copier Drum...
Konica 7040 trouble code 51-4
This 51-4 code is directly related to the write unit. It can either be a bad lazer index control board mounted externally to the side of the write unit or a bad M5 polygon motor. It is better to replace the whole write unit. Konica P# 26WA-6500.
On a side note, the 7020 write unit can be used in place of the 7022 write unit & is far less prone to failure then the 7022 write unit! 7020 write unit Konica P# 26NA-6500.
Nov 07, 2012 | Konica Minolta Copier Toner 7033/7040...
I have a Konica Minolta 7022 printer, scanner, fax, and copier machine. How do I get it to scan?
Please see this website complete manual for Konica MInolta 7022 printer I think i can help your problem
http://help.nceas.ucsb.edu/images/2/2a/Konica.pdf
Thanks
May 10, 2011 | Konica Minolta Office Equipment & Supplies
ERROR F35-4 KONIKA 7022 PLEASE HELP ME
Remove the power from the printer, check the motherboard and connections including the cartridges. In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or
poor ink cartridge contacts.
May 06, 2011 | Office Equipment & Supplies
How can i reset m2 bizhub 211
I Have a Konika Minolta bizhub 211. I had been trying this solution for repairing m2 call. but the code is appear till now. anyone help me. please give me solution step by step.
Thanks
Mar 05, 2011 | Sharp AR-5320 Black and White Copier
Konica 7022 with Problem code F-26-1
There is toner/starter spilled onto a sensor near the drum, it mite just need to be cleaned, this sensor monitors the drums abililty to develope a image, if the cleaning does not work it mite be the sensor or the drum. The drum needs to be removed to clean the sensors.
Mar 23, 2009 | Konica Minolta Office Equipment & Supplies
Konica 7022 (code F-26-1) Pls call service 0870-2425050)
i have a konica 7022 it say call service code F-35-3, what's wrong with it, help me.
Mar 21, 2009 | Toshiba 2060 Copier
Error code f-51-6
this is your WRITE UNIT CODE.''''PRIT HEAD''''
you chould try to reseat all connectors ,and especially the write unit ,how handy are you?????
let me know
Oct 23, 2008 | Konica Minolta Di1610 Copier
107 people viewed this question
k24674
jasbo
jasbo
