Question about Samsung SH-S182 DVD±RW Dual Layer Burner
DVD draw sticking
I have a problem with my cd rom draw and dvd draw , when i press the button my draws want to open but thay are sticking , and when i try it with the eject on the my computer window is the same (sometimes the trays open)
can you help
thanks
Martin
  • 56 Answers
Sounds like the gears are worn!! next time you get it open look underneath and you will see some round gears. put some vaseline on them, not too much and open and close the drawer a number of times to work the grease in. all equipment needs lubrication of some sort !!
Posted on Feb 08, 2009
Does the Toshiba Satellite C55-A-14W Laptop have a manual over ride button to open the DVD/CD Driver Draw Tray
If the DVD drive does not have an "Open" button, press firmly on the right side of the DVD drive tray and then release it to open the drive. To force the DVD drive to open, straighten a paper clip and insert it into the small hole on the outside of the DVD drive; push and hold the paper clip until the DVD drive opens.
Jun 20, 2017 | Toshiba Office Equipment & Supplies
Tip
CD/DVD drive drawer fails to open ?
I've often seen this problem on Fixya, there's a quite well known solution.
The CD/DVD drive drawer on your PC (laptop or desktop) won't open when you press the button.
Look closely at the front of the drive, usually, just below the draw itself but still on the front bezel of the drive, you should be able to spot a small hole.
This is the manufacturers fail safe release mechanism, all you need to do is straighten out a paper clip, or use something similar, a push it into the hole, quite firmly. This should release the draw and it will pop out part way.
Invariably after doing this, the drive draw starts to function again normally.
on Jun 03, 2010 | Computers & Internet
I can't get the draws to open to play my dvd's
If the open button doesn't respond, you mu...
  1. Step 1: The paper clip. Straighten out one leg of the paper clip.
  2. Step 2: The small hole. Find the small hole on your CD drive, it is usually near the button.
  3. Step 3: Stick the clip into the hole. Stick the clip into the hole and gently push until the door opens.
  4. Step 4: Finish.
How to open jammed CD DVD drive
Oct 02, 2015 | RCA RTD217 Theater System
I dont know how to open my cd rom driver
if you mean you cant open the cd draw
on the font of your cd rom will be a button press it in to open up the draw or
make sure all leads that are attached to your cd/dvd have secure connections and are not faulty or just replace them they could be faulty ?
you might have to physically unplug the cd/dvd drive restart your computer this should activate the found new hardware wizard
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jun 19, 2011 | Computers & Internet
HP Pavillion - DVD & CD drive will not open!
More or less in the centre of the draw front of both drives you should see a small hole.
Get hold of a paper clip and straighten it out, or use something similar, and press it into said hole. It should release the drive draw.
May 02, 2010 | Computers & Internet
Dvd-rom drive doesn't open
Sounds like the drive eject motor is broken, maybe time/easier to by a new DVD Burner?
Mar 20, 2009 | HP (350208-001) CD-RW/DVD-ROM (Combo)...
Problem with cd-r/dvd rom
does the light come on on the drive ? have you tried straightening a paper clip an putting it in to the little hole to push the draw open this may make it work if its stuck or try right clicking the drive in explorer and choosing eject from there
good luck
Jan 23, 2008 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
Dvd rom automatically eject & loading frequemtly
I'm afraid when a drive starts to eject the draw especially on boot up, it's a sure sign that the unit is faulty and needs replacing.
Jul 11, 2007 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
Samsung SH-S182 DVD±RW Dual Layer Burner Logo
141 people viewed this question
Top Samsung Computers & Internet Experts
asber
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
