Question about JVC AV-32F704 32" TV
JVC TV Issue
This morning I got up and turned on our JVC AV-32F704 television and walked into the kitchen. I could hear the tv was on but when I came back into the living room I noticed there is no screen. It is black, sound only. I have tried messing with it but nothing seems to help. The TV is only a couple years old so I am not to happy at the moment. I do not think there is a repair man in our town so I am not sure what to do. Any suggestions? I am guessing picture tube but I have no idea. Thanks
  • Bert Mar 08, 2008
    Have same problem on a AV-32F703. Diagnosed and found it to be a short between G1 and G2 in the picture tube. Presumably some crud. Zapped it with a charged cap and a perfect picture came back -- for about 5 minutes then black again. Checked again and a 1K short was back between G1 and G2 grids. Zapped again but now picture is very bright -- appears to have a very high resistance short between focus and screen grid now. Probably splattered the crud onto the focus grid. Was worth a try.
  • mroberts19 Sep 27, 2008
    Same problem. No picture, but can hear sound. Did you get it repaired and what was the outcome?
    Genius:
  • 1,074 Answers
The problem with your tv is in the video circuit the ic or transistor needs to be replaced there is a box on the fixya home page just enter your zip code in the box and it will help you locate a repairman in your area.good luck.
Posted on Apr 14, 2007
SOURCE:
How do I tune in channels?
check first your antena connection and do auto scanning of channels to refresh the system memory hope it help
Apr 30, 2011 | JVC AV-32F704 32" TV
While watching tv the screen will go blank, sound
It might be a loose solder connection inside,try to prove it,the next time it goes blank,firmly give a whack to the back or bottom of the set,if it flashes back......sholud be a loose solder conn that a competent technician can find and repair
Jun 02, 2010 | JVC AV-32F704 32" TV
Blue Screen
I don't have a solution, but wanting to know if you ever resolved your problem? I'm having the same issue with my JVC 32" model # AV-32D500.
thanks
Jan 12, 2008 | JVC AV-32D500 32" TV
JVC AV-32F704
Is there any picture at all? No matter what the video input. Is this a CRT or LCD? If it is a CRT chances are the CRT is blown. Did you hear a pop the last time it powered up? Does the Menu come up?
Dec 31, 2007 | JVC AV27F476 27" TV
Screen is black.
Is it plugged in?
Dec 28, 2007 | JVC AV-32F704 32" TV
Older model jvc tv purchased late 90's
I am not receiving a satellite signal on my old model JVC model AV 32F704
Dec 21, 2007 | Televison & Video
JVC AV-32f704
the problem is your high voltage section in the main board of you tv,try to resolder the the circuit and components near the flyback
Sep 01, 2007 | JVC AV27F476 27" TV
Jvc tv
If you can take it back I would, if it is turning its self off it has issues. It may have been dropped and a board may be cracked, or some other issue. sorry.
Jul 07, 2007 | JVC AV-27F702 27" TV
JVC AV-32F704 32" TV Picture is blurry - cannot read any writing on the screen
You didn't mention if you saw fine white diagonal lines running through the screen from top to bottom. If so, you likely have a shorted Picture Tube which is not usually fixable. If there are no lines seen running through the screen, then it is possible the High voltage transformer which also has a screen voltage and focus control built in that could be bad. I would expect the cost of that part to be about $100, so the repair cost total could approach that of a new set I would guess.
Apr 12, 2007 | JVC AV-32F704 32" TV
Can't shut off closed caption
I have the JVC I Art 46" TV. The Close Caption was turn on accidentally by my grandson. After lots of searching for the original remote. I called JVC Customer Support. He told me to change the Close Caption settings to CC2 and T1. That fixed the CC without having the original remote.
Apr 10, 2007 | JVC AV-32F704 32" TV
JVC AV-32F704 32" TV Logo
180 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
