Question about Samsung SCX-4216F All-In-One Laser Printer
I have opened the above door and have cleaned the mirrors front
I HAVE OPENED THE ABOVE DOOR & CLEANED THE MIRROR FRONT OF DETECTORS .AFTER REINSTALING THE DOOR THE PRINTER GIVE THE MESSAGE " SCANNER LOCKED". PLS HELP ME.MY PRINTER IS SCX-4216F/XSG.
  • 77 Answers
Check the cables connected to scanner pcb monted left side of the machine. there is a flat cable connected to the pcb from scanner unit. layer of contacts may not be correct. check, clean and re-inatall the cable.
Posted on Jan 31, 2009
2 Suggested Answers
SOURCE: fixing of scx-4216f
scx 4216f scaner lock problem
Posted on Oct 10, 2011
Wing mirrors will not adjust
Wing mirrors have a certain range of electrical adjustment. Manual adjustment by pushing with fingers can make electrical adjustment inoperative. The solution is to make finger adjustment to get back to the electrical range.
May 22, 2016 | Cars & Trucks
How d I swith passenger side mirror on a power mirror on a 2004 Jeep Grand Cherokee limited edition
no symptoms posted (broke glass or ???) can we be on same page?
"how do I switch," verb switch , the mirror as switches inside, too.
please say what that word means. switch and the failure.
1: remove and replace with new.
2: move right to left and left to right side.
why would you do that #2
fold away mirrors/ Export only (this is usa forum so..)
these,NASA grade mirrors are very complex... not just glass and plastic. heaters ,motors, memory , etc.
the FSM cover all tests for the mirror, including scan data.
ill quote the FSM now , 8 steps (just 1 fail,not heat, not memory failure or fold failure)
ONE MIRROR INOPERATIVE
(1) If the one inoperative mirror is on the passenger
side, go to Step 2. If the one inoperative mirror is
on the driver side, go to Step 3.
(2) Check if the passenger front door will lock and
unlock using the power lock switch on the driver side
front door. If OK, go to Step 3. If not OK, go to Step 6.
(3) Disconnect and isolate the battery negative
cable. Remove the trim panel from the front door.
Disconnect the 12-way mirror wire harness connector
from the door wire harness connector.
(4) Using two jumper wires, test the mirror as
shown in the Mirror Test chart (Fig. 2). If the mirror
tests OK, go to Step 5. If the mirror does not test
OK, replace the faulty mirror.
(5) Disconnect the 12-way door wire harness connector
from the door module connector receptacle.
Check all of the circuits of the door wire harness
between the connector for the mirror and the connector
for the door module for opens or shorts. If all of
the circuits are OK, replace the faulty door module.
If any of the circuits are not OK, repair the open or
shorted circuit(s) as required.
(6) Use a DRB scan tool and the proper Diagnostic
Procedures manual to test and repair the faulty Programmable
Communications Interface (PCI) data bus
communication between the two door modules.
(bar stool answer) all cars. mostly
pull door skins
unplug motor conn.
unscrew mirror base from door.
extract mirror,
Mar 07, 2015 | 2004 Jeep Grand Cherokee
Replacing mirror
On GM cars their is usually a small triangle plastic piece above the panel in the front of the door. remove screw and plastic piece. then look for 3 10MM nuts. Undue and pull off mirror.
Jan 05, 2014 | Oldsmobile Cars & Trucks
Looking through viewfinder i see dirt & black specks
It depends where the dirt is. Following the light path, look at the rear surface of the lens. A dirty rear lens surface will have the most affect on picture quality or what you see in the viewfinder of any position in the light path. Like all optical cleaning procedures, hold the lens with the rear lens surface facing the ground so gravity will work with you. Start by blowing clean air on it using canned air or a blower such as a Rocket blower or ear syringe. If that is sufficient, do not continue the sequence. This holds true at the conclusion of each step because the more aggressive your cleaning becomes, the more risk there is of damage. If it is still dirty, gently brush it with a sable or camel hair brush. If that is not sufficient, gently wipe it with a dry lens photograph lens tissue (do not use coated tissues) or a microfiber cloth. Finally, as a last resort, dampen a corner of a lens tissue or microfiber cloth (do not put the wet solution directly on the lens) and gently wipe with a circular motion. Finish by wiping with a dry section of the tissue or cloth. Although the front surface of the lens is not as important, repeat the process for the front surface.
If you still see the dirt in the viewfinder, are two possible remaining locations; the bottom surface of the prism located above the mirror or the mirror.
Clean the prism first and avoid cleaning the mirror if possible, or any contact with the mirror. The prism can be cleaned following the sequence outlined above. If that doesn't work, the problem is the mirror.
CAUTION! The mirror is front surfaced and is very susceptible to scratches and other damage unlike a conventional mirror which is rear surfaced with the glass protecting the coating. Aggressive cleaning should be avoided.
Carefully follow step 1 of the lens cleaning procedure (air) and step 2 (brushing) if necessary. As far as the third and fourth steps, I would not use them myself because of the risk of mirror coating damage. It would be better to take your camera to a qualified repairman.
remove the lens and look above the mirror at the bottom of the viewfinder prism. If it is dirty, clean it as you would clean a lens surface. The next place to look is the mirror.
CAUTION! The mirror, unlike the mirror over your bathroom sink, is front surfaced and there is no glass between you and the delicate and easily damaged coating. Hold the camera with the mirror facing down so that gravity will work in your favor. If that does not work, I would stop and take it to a camera repairman because you do not want to risk scratching the surface by using lens tissue or cleaner.
Feb 05, 2013 | Nikon F100 35mm SLR Camera
Replace passenger mirror
glass and motor availbable separately
Removal
NOTE: Do not remove the mirror assembly when repairing the individual mirror part. Individual mirror parts can be installed without removing the mirror assembly.
  1. Remove the front door trim panel; refer to Section 501-05.
  1. Remove the outside rear view mirror access water shield.
  1. Remove the speaker.
    1. Remove the screws.
    1. Disconnect and remove the speaker.
  1. Disconnect the outside rear view mirror electrical connector.
  1. Remove the outside rear view mirror.
    1. Remove the nuts.
      • Feed the outside rear view mirror wiring through the opening in the front door.
Oct 26, 2010 | 2003 Ford Ranger Regular Cab
How do you install the door mirrors on 1997 buick lesabre
Most times you can remove the small interior trim piece that is located in the front corner of the door right above the door panel. Then you can access the three 10mm nuts retaining the mirror assembly, If the mirror is powered their is usually enough wiring harness that you can access the connector without removing the door panel....
Oct 19, 2010 | 1997 Buick LeSabre
Ford f-150, 2006, right side power mirror needs to be replaced. need instructions
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1- Remove the mirror trim cover above the front of tRe door panel.
2- If you're working on a,model with electric mirrors, remove the' door trim panel and the watershield .
Follow the harness and disconnect the electrical connector from the mirror.
3- Remove the dust shield and rubber plugs for access, then remove the mirror retaining nuts and detach the mirror from the vehicle.
4- Installation is the reverse of removal.
Nov 19, 2009 | 2006 Ford F-150
Ford expedition side mirror (instalation giude)
SECTION 501-09: Rear View Mirrors 2003 Expedition/Navigator Workshop Manual REMOVAL AND INSTALLATION Exterior Mirror Removal and Installation
  1. Remove the front door trim panel. For additional information, refer to Section 501-05 .
Front Door Trim Panel —Expedition Removal and Installation
NOTE: Left front door shown, right front similar.
  1. Remove the door handle bezel.
    • Use service notch.
  1. Remove the window control switch plate.
    • Use service notch and disconnect the electrical connectors.
  1. s3j~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: To avoid damage to the door trim panel, lift the door trim panel by pulling directly upward on the armrest to disengage the panel clips.
    Remove the two bolts and three screws, and remove the door trim panel.
  1. Remove the weather shield.
  1. Disconnect the exterior mirror electrical connector.
  1. Remove the exterior mirror.
    • Remove the nuts.
  1. To install, reverse the removal procedure.
    • Install top nut first.
Exterior Mirror Motor Removal and Installation
  1. Position the mirror glass to obtain a gap at the top edge of the mirror and carefully pull the top edge of the glass away from the mirror housing.
  1. Disconnect the heated mirror electrical connectors.
  1. Remove the exterior mirror motor screws and exterior mirror motor.
    • Disconnect the electrical connectors.
Oct 26, 2009 | 2003 Ford Expedition
Need diagram to replace left mirror on 1998 Ford F150
you don't need a diagram above your door panel tword the front of the door there is a panel pop it off and there are three taps that wold the mirror on.
Apr 06, 2009 | 1998 Ford F150 Regular Cab
Fixing of scx-4216f
pull it apart and reassemble correctly.
Dec 25, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Samsung SCX-4216F All-In-One Laser Printer Logo
261 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
sahoo_sanjay
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
