Question about Logitech Cordless Desktop S 510
Curser freezes cannot move curser from one spot to another w/o having problems of it not wanting to go anywhere. I cleaned the eye with a swab and it did not help. My cordless is only 2 months old
  • 15,935 Answers
Change the batteries. Re-sync the mouse. Re-try.
Posted on Dec 24, 2008
How to fix curser
It isn't a problem with the curser. What you describe there usually happens if you have software, graphical demands, a corrupted driver or the like that almost maxes out your hardware.
Either that or your computer needs a good decent cleaning and freezes because it overheats.
Feb 21, 2015 | Computers & Internet
Connects and clicks just doesnt move the curser
I presume you can see the motion sensing red LED or laser beam shining under the mouse. If not, that has gone bad, and it would probably be more economical to replace the mouse than to attempt a repair.
If the light is on under the mouse, try cleaning the lenses (both LED and photoreceptor) with a cotton swab dampened with isopropyl alcohol (rubbing alcohol). Don't scrub, just wipe the optics gently until clean.
Nov 11, 2017 | Belkin Mini Wireless Optical Mouse...
Hi my sony dvp-fx820 keep giving me "Can Not Play the disc"???I Message.I have other dvd player it also giving me same Message I Accidently Pushed the progressive button. I'v fixed the problem by...
Laser probably needs to be cleaned. If you can get to the laser eye, check for scratches. With a foam cue tip or lint free cloth, not a cotton swab, with very very light denatured alcohol wipe the eye clean of debris. Clean eye once again with a dry lint free cloth. Check again for scratches, if no scratches the eye should be clean. If this doesn't work, try flipping the player upside down and secure where player is steady. Push the play button and see if it will play. If the player works in this position, that means the mechanics that move the eye up and down are weak. The entire eye assembly needs replacing.
Nov 02, 2010 | Sony DVP-FX820 DVD Player
The wii console wont read games. it tells you to turn console off and read manual
the laser eye inside that reads the games is dirty, you can use a cd disk that cleans the eye when cd is inserted,which you can get anywhere for a few bucks like walgreens,kmart,walmart,jewel,best buy to name a few, sometimes you need to have someone open the wii up, with a specical tool and clean the laser eye with a q tip and a very small amount of alcohol on the swab, I have fixed wii's this way many of times!!!
Jun 28, 2010 | Nintendo Wii Console
Insignia model is-pddvd7 won't load dvd
Remove the cover and clean the glass laser eye with cotton swab and rubbing alcohol.
This will fix the problem if it is self-fixable. If problem persists, you may have to buy replacement or get new laser in yours
Jun 24, 2009 | Televison & Video
Phase linear uv8 DOSE NOT PLAY DVDS
Remove cover of player, you will see glass eye which is laser eye. Take rubbing alcohol and cotton swab and clean the eye with the alcohol soaked cotton swab. If this player is self- fixable, than this will do the trick. If cleaning the laser eye didn't help, than they player will have to be repaired or replaced.
May 04, 2009 | Televison & Video
CD SKIPS
  OK.  I think I can help.  There are two very simple solutions to a skipping CD player.  You have tried one already, that is, clean the laser-reading eye.  Lets assume you did that correctly and that is not the problem.         So, to continue, the machine must be opened. Equipment required: Jewellers screwdrivers, small number one screwdrivers, cottonswabs or Q-tips, Petroleum jelly, 100% isopropyl alchohol is ok but if you can use Denatured alchohol that is the best.        Using a set of fine jewelers screwdrivers or just a small #1 Regular or Philips screwdriver to remove the top cover of the CD player.  Don't force anything and place the screws in a cup so they are not lost or misplaced. I work in a plastic cafeteria tray to contain any dropped screws    The problem here usually occurs in trusty old CD players that have always worked fine and the problem (skipping) starts out small and gradually progresses to always skipping.  The problem and solution are mechanical in nature.    First locate the laser eye and check it physically for any optical obstructions (dust, dust-bunnies, lint, feathers, hair, lumber, etc.)    When you are sure the laser-eye is clean find two parallel small (usually 1/8" or about 3mm wide by about 3 to 6 inches long ) chrome metal bars that the laser eye rides back and forth on.  The eye assembly has a small contact-lens looking clear plastic lens mounted on a plastic carriage that moves from the center of the disc toward the outside as it tracks the disc.  It will have a small ribbon wire harness that can expand and retract with the travel of the laser-eye carriage.  Now look at the two-parallel shiny metal bars the carriage should slide on. The lubricant on these bars lets the eye assembly move smoothly without vibration (or skips) over the length of the two steel bars and your CD plays perfectly when they are clean and lubricated.  This skipping problem can occur if something sticky is spilled into the unit. Soda or beer dries out and if it gets on these steel bars the laser-eye assembly can vibrate and chatter as it tries to track over the CD's info causing skips.      So the solution involves carefully testing the unit with the lid off to see what is going on inside when the unit plays (or attempts to play) a CD.  If the obstruction to the path of the eye assembly is severe, the tiny drive gears can be damaged, broken, or stripped and the eye will not move smoothly without new parts (Factory Authorized Service Personnel are recommended in that case)   Use the Denatured Alchohol and swabs to completely clean and dry the steel track rods that the laser - eye slide on, take care to clean any built up old grease (manufacturer lubricant) that may build up on the holes on the sides of the Laser-eye assembly where the steel track rods go through it.  After cleaning the rods use a new swab to apply a TINY amount of petrolatum evenly to each rod.  I cannot stress enough how important it is to use as little lubricant as possible ONLY on the rods and NOWHERE ELSE!  It is very easy to get the petrolatum somewhere you don't want it.  Be Careful!  One mistake here could cost you the entire unit!  after application, physically slide the eye assembly over the bars to smooth out the petrolatum lubricant evenly. (in the event the eye-assembly doesn't manually slide, don't force anything and go to the next step). make sure you did not get any petrolatum where you did not want it, if you did clean it with cotton and good old, denatured alcohol and put a CD in and before playing it, advance the tracks from track 1 to the highest numbered track and back several times to smooth the lube more.  Play the CD and replace the lid and screws in the order you removed them.      Good Luck!
Dec 11, 2008 | Onkyo DX-C390 6-Disc CD Changer
DTI program liberary when recording is actioned causes set to fr
Phoned the manufactures and got a replacement set
Dec 08, 2008 | Televison & Video
3 yr Old CD Player not recognizing discs
Laser might not be faulty but just a dirty lens/ rail assembly.
If thou darest open the thing, clean the lens ( GENTLY) with a swab of glass lens cleaner. Clean the chrome runners for the optics assby with a swab lcaed with WD40 or silicone.
Aug 01, 2007 | Yamaha CDC-565 5-Disc CD Changer
Computers & Internet Logo
138 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
