Question about Brother DCP-110C All-In-One InkJet Printer
I have a Brothers Printer/Scanner.... I have not had a problem scanning until today. I can make a copy but cannot scan a copy and set it to file. wont scan i have a 110 brothers printer
  • Chip Loon Ng
    Chip Loon Ng May 11, 2010
    Are you able to copy?
  • 622 Answers
Check if the ip address of your computer changed...and see if you can print... if you cann't print... then its a network issue... if your ip address changed then its a network issue... if its connected via usb... then reinstall the scanner and see if that helps...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Posted on Dec 26, 2009
Have a brothers mfc 420cn using windows
go to printers and faxes (where the printer is displayed). make sure the printer is turned on. you should see a place which indicates some thing like get pictures from scanner. click on it to scan. additionally open my computer to see if the printer scanner image is showing. you right click and select get pictures using wizard from the right click context menu.
good luck
Jul 04, 2010 | Brother MFC 420CN All-In-One InkJet...
Why my scanner does not work?and my printer works?i have a printer mp 140 canon
Thats like asking why your engine works but your tires are flat. You need scanning software on your computer for the scanner to work, but if you just want a copy you press copy. It won't scan until it knows where to send the scan and how you want it scanned.
Nov 13, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Its telling me no scan option
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab1
Jul 16, 2009 | HP Officejet 5610 All-In-One InkJet...
SCANNER SAYING NO USER ID
This means that you have not set up any users in the address book in the printer.
Copy is simple, it will scan the document and print out a copy of the scanned image.
Scan however, is trying to make and store an image file of the scan, but it needs to know WHERE you want to scan it to. The printer does not know where to send the stored image unless you create a storage location for it. This is done with the address book that is stored on the printer.
The material below is how to set up the scanner settings of the printer.
Printer Settings Utility Using the Printer Settings Utility window, you can set up the fax system data options, and create and edit Phonebook entries from your computer. You can also configure the destination launches when you access Scan and then PC.
When you install the Dell software, the Printer Settings Utility is automatically installed.
For information about installing the software, see "Installing Software in Windows".
To open the Printer Settings Utility:
  1. Click Start software25.jpg Programs software25.jpg DELL software25.jpg DELL Printers software25.jpg DELL Laser MFP 1815 software25.jpg Printer Settings Utility.
The Printer Settings Utility window opens.
  1. The Printer Settings Utility window provides several features; Directory (Phone Book, Address Book), Fax Setting (Fax Cover Sheet), and Scan (Destination, Resolution, Scan Color, Show Preview).
The Scan Section The Destination Section To configure the operator panel display scan destination list that appears when you access Scan and then PC, click Destination and the Setting button. Using the destination list, you can select a software program that an image can be scanned to.
Oct 07, 2008 | Dell 1815dn All-In-One Laser Printer
Two black vertical lines appear on copy, pdf, and scan results
  1. Unplug the power cord and the phone line from the wall.
  2. Open the control panel.
  3. Pull the roller lever forward, and then lift the white roller out of the All-In-One.
  4. Note: The scan lens is located under the white roller.
  5. Use a clean, lint-free cloth dampened with water to wipe the white roller and the scan lens.
  6. Reinstall the white roller.
  7. Reconnect the power cord and the phone line.
  8. And then try to copy if get the dame line then its the hardware problem in the printer you must need to replace the scanner unit in the printer ..
Good luck..
Sep 01, 2008 | Lexmark X4270 All-in-One Multifunction...
Hp scanner 3030
i have a hp 3030 all in one is there.. printer, xerox, fax is working properly but scan is not working .. kindly solv this problems..
Aug 31, 2008 | HP LaserJet 3030 All-In-One Printer
Brothers mfc-210c
there are two option u can do. if you can't open the scanning program chances is that you haven't installed or you don't installed it correctly.... in an all in one printer you should install a scanning program that is included in the disk when you bought the printer...
the scanning program include the scanner driver that is needed for that operation....
Jan 19, 2008 | Brother MFC 210C All-In-One InkJet Printer
My brother mfc 210c won,t scan or copy
I just called Brothers product support and found out that these machines WILL NOT scan or copy or do anything until the ink cartridges have been replaced. So there is no other solution.
Nov 26, 2007 | Brother MFC-5840CN All-In-One InkJet...
Scanner
Download and install full software and driver package for your machine from brothers web site, it sounds like you have installed the print drivers but not the scanning software.
Oct 27, 2007 | Brother MFC-5440CN All-In-One InkJet...
Brother DCP-110C All-In-One InkJet Printer Logo
168 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
