Question about Ariens 34 In. Zoom Series Riding Mower
Auger frozen Ariens 5520 lightly used, about 4 years old. The engine starts easily, but auger would not turn when the clutch was pulled in. I kept the clutch engaged long enough to smoke it. I never checked the lubricant level in the auger gearcase. I have a feeling the gears in the gearcase were frozen, or possibly the shaft. I remember seeing some lubricant leakage under the machine when it was relatively new. I think it may have been the gearcase lubricant, which means I used the machine a few times low on lubricant. Now there is a grinding, unhealthy sound when I pull in the auger clutch lever at the handle, and the auger remains frozen. By the way, the machine had not been used this season, and there was no water or ice buildup. How should I proceed to diagnose, and what would be the solutions? I Have some experience repairing motorcycles and cars. Thanks, Tony Gagliardi, Huntington station, NY
  • drtonyg Jan 11, 2009
    Thank you to trippssmengi and mrfixit-jerr. Turns ot that the auger of my Ariens Snowthrower was stuck by a stone which had lodged itself between the "fan" , which is behind the auger, and the housing. The smoking was from the rubber belt. This fix involved simply dislodging the stone!
    drtonyg@optonline.net
  • Mark Tripp
    Mark Tripp May 11, 2010
    With the belt off try to turn the impeller by hand, if it does not turn then you will have to take the mahine apart to check inside the gear box.If it is the gears it will be easier to get the whole gear box assembly which includes the gear box, auger shaft and probably the worm shaft. If you go to www.ariens.com you can get a complete breakdown fo your machine which will help in getting the machine apert and back together.
2 Suggested Answers
SOURCE: Craftsman 247 88190 0 snow blower auger frozen
my auger and impeller froze too. fixed by clearing all snow, ice,stone build up behind impeller it works fine now.. hope that helps
Posted on Jan 19, 2009
Why does my ice auger want to keep spinning and wont stop when you pull the cord it turns the auger
Pulling the cord will only start the engine. Your problem is with the centrifugal clutch. Check the clutch for broken springs. GOOD LUCK FRIEND.
Mar 02, 2015 | Jiffy Model 30 10" Ice Auger
Both augers turn when not trying to clean snow,as soon as I try to use it and snow gets to the augers,only one auger moves on my ariens 520 snowblower
It sounds like the auger always turning is the auger engagement handle/line/connections are not adjusted correctly. They/it is too tight causing the auger to engage before it should. It may be up at the handle where you loosen a jam nut, screw in or out a threaded shaft, and retighten the jam nut. (If you have ever adjusted a bicycle brake it is similar.) (I have a craftsman, made by MTD, and I think I saw MTD also list Ariens.) Or it could be an adjustment somewhere else (but I'm not sure where).
As far as one auger moving and the other not, you may have a shear-pin (shear bolt as the manual calls them) on each side of the auger's shaft (my craftsman has one on each side), and the one on the side that stops turning is sheared off. (It moves without snow present due to the driveshaft inside the outer auger shaft turning, but it won't turn under load (snow).) You may confirm a sheared-pin by turning the machine off and try to turn the auger blade. If it turns somewhat easily, that's a bad shear pin. Remove the old shear pin. If the old one is as long as the new one, that aint the problem. The shear pin in the image is one kind. Mine appear as a straight bolt (no grooves), threaded the entire length. You will have to rotate the auger blade until it aligns with the hole in the shaft. Use a nail that fits and rotate the blade until the nail goes in. Remove the nail and screw in the shear bolt:
The auger clutch control up at the handle looks like this:
25398197-u3i4ko1tk2s0xlbbi4fvvtzj-2-2.png From my manual
Auger Control
  • To check the adjustment of the auger control, push forward the left hand clutch grip until the rubber bumper is compressed. There should be slack in the clutch cable.
  • Release the clutch grip. The cable should be straight. Make certain you can depress the auger control grip against the left handle completely.
  • If adjustment is necessary, loosen the hex jam nut and thread the cable in (for less slack) or out (for more slack). Recheck adjustment. Tighten the jam nut when correct adjustment is reached.
Here's another view of that:
I hope the above info helps you take care of both issues.
Feb 03, 2015 | Ariens Garden
932 ariens shuts engine down as clutch is engaged to throw snow
Your problem would be in a safety shutdown switch.
some Ariens blowers have a two handed safety switch whitch is located on back of blower right lower side (inside of body)
You have to remove 4 transmission pan bolts to see it.
The other location is under the metal face plate between the handle bars.
Some of them have a third handel on right side of handle bars that has to be depressed to run auger .
Mar 01, 2014 | Ariens Garden
Fix ariens snowblower 520 dies when engaging the auger lever
Your front end is jammed. Its either frozen or there is a rock or something jamming it up. Before you start engine reach down chute and turn back impeller that throws the snow out of blower. Should turn freely. when its free its fixed. You will probably need a new belt.
Feb 17, 2014 | Garden
Auger does not engage on Ariens Model 924121 sno- Thro
first check shear pins in the auger ( try to turn big auger by hand, engine off)
then if they are good then try to turn impeller by hand, engine off
youll need to turn it a few times before the larger ones turn, but thats what you want
if they dont turn then you have sheared the gear box gears
be sure belts are good tooo
Dec 15, 2013 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
Ariens snowblower impeller not throwing snow
Sounds like you have a broken or partially broken shear pin in the auger.Check along the auger[machine off]and see if there is what looks like a bolt anywhere along the auger shaft.If there is [and there will be] remove and inspect it and you will see why the auger is not working.Next time,never clean out a chute or auger while the engine is running,people loose limbs this way.
Feb 13, 2010 | Ariens 34 In. Zoom Series Riding Mower
Why does only the right auger turn?
You most likely have a shear pin sheared on that side.
If you engage that slip diff., it engages both wheels like a posi-trak.
Dec 26, 2009 | Garden
Jan 19, 2009 | Ariens 34 In. Zoom Series Riding Mower
Ariens snowblower auger wont turn
Just finished repairing my ariens, 6 years old with aluminum gear box. Same problem encountered. The problem turns out to be the BRONZE gear driven by the worm shaft. Shear bolts did not shear and bronze gear broke about 5-6 teeth. This is why you can move the auger a half turn or so, there are no gears in one area of the gear and as the gear turns to engage the worm drive it will stop. The fix: the cast iron replacement from ariens! About $200 including shipping, got mine from Jack's Small Engine (MD). Fairly easy repair if you are mechanically inclined. Buy yourself a set of roll pin extractors ($20 from Sears), new roll pins, new woodruff key for shaft. You will also probably have to press 2nd stage impeller from shaft with hydraulic press & heat (took mine to my local auto garage). What stinks is ariens seemed to have admitted the design problem with the aluminum gearbox, yet won't help with repair cost! Anyways, I learned a lot about my snowblower for future repair (belt replacement)!
Dec 21, 2008 | Garden
Ariens 34 In. Zoom Series Riding Mower Logo
216 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
