Question about SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready Plasma Television
Will not turn on with remote
To turn the TV on while its on standby, with the remote the Tv after a few seconds it clicks twice and the red light(standby) goes out and i can,t get the the Tv to turn on. I tried to reset the TV by unpluging it from the outlet for a while still do not respond, leave it unplug for days and still no connection. Whats the problem i really needs help. Do i need to buy a logic board? and if i do where can i get the part. Please Help
  • 8 more comments
  • Paula Seeraj Apr 16, 2007
    I have tried different outlets, and i also had a tech check it, but everytime he leaves it working and when we turn the tv off the problem still exist.
  • Paula Seeraj Apr 19, 2007
    I tried your solution, but the problem still exist.
  • cmorin333 Apr 16, 2008
    I have the same TV, same problem.
  • olivwen Sep 02, 2008
    My TV will not turn on .I get the clicks and the red light goes out but nothing.I have un plugged ,I ve turned button on and off under neath TV.Still nothing.Its been happening for a few days .When we do get it to go on.As soon as we shut it off same problem occurs and now I think it is finally done.I can't get it to go back on I've been trying all day.
  • Fidget252 Sep 25, 2008
    I have been having this same exaxct problem with my tv for a few weeks now (figures I just had Verizon Fios installed with HD). I takes longer and longer each time to get the tv to turn on. As soon as we turn it off the same problem everytime. Must be a defect on the manufacturers end. Class action? Count me in too!!!!!!!!!! The unit costs too much just to trash it!!!!!!!! They should provide home service free to fix them since it seems a lot of people are having the same problem.
  • dleewo Nov 09, 2008
    I just started to experience the same problem a few days ago. I did some searching and I saw a post where someonme suggested replacing 2 relays on the power board. I have opened up the TV and got the part numbers. I just ordered 2 relays (about $2.50 each) and I'll try replacing them when the parts arrive, but I would welcome any other suggestions.
  • Anonymous Dec 17, 2008
    I have same problem I called too lets call everyday until we get a refund for this **** tv class action count me in who is coordinating
    email me EvoX101@yahoo.com
  • kris bhola Feb 23, 2009
    does not make any sense to fix this tv because once you pay 450 for the power board the tv itself ends up burning uo and the goes black.
  • kris bhola Feb 24, 2009
    same problem here with my SVA 42" Plasma. I took the board out already and wanted to replace the 2 relays, 4 capacitors and power supply chip semiconductor but i didn't because I read somewhere that once you do that the tv screen itself burns out shortly after that and turns black. so i do not know if the fix is worth it at all.
  • kris bhola Mar 01, 2009
    Well this is a huge problem with these TVs. I had the same problem and I kept checking on here until I finally saw some who had gone to a website and found a power board for $139 instead of $350 - $450 on this website www.adc-ast.com. It will be here in a few days and I iwll be sure to let folks know how it works out. If you are interested and you go to the site, once there, just put in the board part number in the search box and it will go right to it. The board part number is LJ44-00025A this is for the 42" the other one there is for the 50" model. I figure I would try this first before buying a new TV. if I get another couple of years out of it then $139 will not be such a big waste of money after all compare to what SVA or Samsung sites wants for it, $450. they are simply nuts. Just the fact that they know that the boards are bad, they should be at minimum selling them at a huge discount if they are not going to do anything else to help folks. Anyway, I will let you guys know how this works out for me. I hope it does the trick. Keep your fingers cross for me. By the way this price includes shipping as well. Well you pay $139 for the board and shipping is free.
    Thanks,
    Triniboy
    Problem Solver:
  • 3 Answers
Read my post on getting a new board for $139.
Posted on Mar 01, 2009
    By the way, the board is made by Gateway so forget about looking fo a Samsung board. Gateway makes the replacement board for all the other companies that use them in their tvs.
  • kris bhola Mar 03, 2009
    Ok folks, I got the new power board today from www.adc-ast.com and I installed it and the tv is back up and running like it did before. It is working fine and I did not cough up the $450 that they wanted at the sva parts site. All I paid was $139 from the site above. If anyone has any questions, please feel free to contact me at bhola_krishna@yahoo.com. I will be more than happy to answer any question that I can. Good luck to everyone on their fix.
    One more thing. When you take apart the tv and put it back together again make sure you lay it flat on the screen on a level surface on a blanket or something to protect the glass covering. this was a simple straight forward fix. Just lots of screws. about 16 perimeter csrews and 14 bracket screw on the outside. Once back cover is off you must remove the 4 large frame screws and the 4 smaller screws at the bottom of the bracket on each side. Once the bracket is gone ther are about 12 small screws that hold the board in place. Be carefull taking these out make sure you hold onto the board as it will fall once you remove the last one. There are about 7 ribbon connections that must be removed. I used a marker and wrote on the housing and the ribbon numbering each connection so that the reconnection was clear without mistakes. I did this because there are extra open connectors and you do not want to reconnect to the wrong one. Once you start to reassemble, if your screw holes for the brackets do not match up with the inside frame holes you can stick a screw driver in the hole to move the bracket around on the inside. Fairly simple. I also pulugged my tv up once I had the new board in with a coupke of crews in place to test it before reassembling the whole tv. Make sure you turn on the power button on the bottom becuase I forgot and almost had a heart attack when I hit the remote and nothing happened. then turn on the tv with the remote pointing it to the area from the back where you know the red sensor light is. It will work from the back. Then just tilt the tv up and see if you get the video screen with the little box in the middle like you used to before. Once you see that then you are back in business. Reassemble the rest and you are back in action. hope this was helpful to you all. Thanks to the person who found the website with the boards for $139. You are a life saver. Remember once you go to the site just put in the board model number and it will come up. Make sure you choose the 42" board if you have a 42". There is also a 50" there too if you have a 50" Well good luck again.
    Problem Solver:
  • 9 Answers
Hello to all you frustrated TV owners, like myself. I am hearing all the complaints about Samsung part# LJ44-00025, which sounds like it is a defective board. This part can range from $140.00 to $500, depending on where you purchase it from. There are some places that charge different depending on the brand, when the parts are completely indentical. Therefore, I am taking ownership, or willing to support someone, who has already started a claim against Samsung, and including the companies, who placed this part in there TV's.
Please submit you name and contact info to samsung.lj4400025a@yahoo.com
Name
Address
Phone
E-mail
I will send out a Questionaire Form to include you in the claim. I must have the information to validate our claim.
Please spead the word!
Shawn Moffett
Dallas, Texas
mercompany@yahoo.com
Posted on Apr 05, 2009
    Problem Solver:
  • 5 Answers
I got my unit apart and looking for tech info got the service manual from gateway - http://support.gateway.com/s/Manuals/HomeTheater/GTW-P42M203.pdf this is their model which is the same as this SVA. It will make it a lot easier to fix!
Posted on Mar 24, 2009
Buy the power supply board for $139 on the links provided in some posts. I did and now my tv works.
  • Fidget252 Mar 05, 2009
    Before we pulled the power board out of the unit, I took pictures with a digital camera so that we knew exactly how everything was connected to the board. We also marked the cables and sockets. The board got to us very quickly from www.adc-ast.com and at $139 you can't go wrong trying it out. It worked for us and a couple of others on this forum so if you held on to the tv this long, go for it and have an extra set. Good luck and thanks to the person who originally put up this web link.
I managed to fix my TV by replacing 2 relays for $5. Here is an article I wrote describing what I did along with some photos:
http://www.derekleewo.com/wp/2008/11/12/repairing-sva-hd4208tiii-pdp/
Posted on Nov 13, 2008
I agree with the idea of a class action suit.
Posted on Dec 23, 2007
Initially, I thought that my problem was exclusive, but after reading about the various problems that other consumers have encountered, I asked myself, why is the American consumers been subjected to this level of abuse? These foreign companies dump their inferior products in our markets. We purchase them and within a very short period, we are stuck with a hundred pound of trash right in our living room - with no recourse. I too have tried to reach SVA and I am still awaiting a reply. I am also stuck with a 4208 TIII-PDP(Trojan horse)that does not come on. the light double clicks but that's the extent. In a case like this I believe that the consumer's problems need to be address and there should be some kind of recall rocedure. If the manufacture cannot address our valid issue then they shoud not get our business.
Posted on Jun 16, 2007
    Genius:
  • 1,074 Answers
Have a tech check your tv the problem is in the power supply or related circuit.good luck.
Posted on Apr 14, 2007
    Problem Solver:
  • 5 Answers
Hi i got free tv from CL and it didnt turn on at all. i opened up and i can see 3 green leds and one red. when i try to turn on main power switch one green light turns on and when i press power botten one green turns one and red led but no vedio at all. there is 2 relays next to each other one turn one and one is not. I found out that Transistor: TOP224Y on heat sink is burn and i found one at digi key and order and i bought 2 from ebay from china, and im waiting for them to see if this will fix problem. that transister trigs relay for high power for plasma screen. so it sgould fix problem. i will update then i get them
Posted on Feb 08, 2010
    Problem Solver:
  • 14 Answers
I fixed Mine ($30 pdp on ebay lol) 4 $8 bucks it turned out to be a bad smd diode(1Amp) and a shorted scr (I replaced with nte5406) by the red error led I'd suggest to look 4 shorted diodes not ones by transformers but the more isolated circuits. also a few bad samwha caps that read high voltage potential (hypot) between gnd and the body of the capacitor (although not uncommon but I replaced them it Just in case) shock hazard. IMO its is a poorly designed power supply that needs some retrace jumpers to correct some of the flaws and even afterwords still some bias noise in picture but its expected in such an old tv.
Posted on Jan 27, 2010
Wimpete,
Is this powerboard Samsung PDP-PS-421S(v1.5) really supported by Samsung, then where can we source the board, or can we call samsung and see if they can give us some info.
I also feel that SVA should do something about it and also think Samsung should own up to the board and us help so we can repair the board our selfs.
perfect
Posted on Nov 03, 2008
Same problem TV is A SVA HD4208TIII-PDP 42 in. I can unplug mine and watch it for anywhere from 2Hrs to 10 min depends on how long it feels like. the power board is a Samsung PDP-PS-421S(v1.5)
I also feel that SVA should do something about it but I also think Samsung should own up to the board and give us the plans so we can repair the board our selfs.
Bill
Posted on Nov 02, 2008
Mine is the same way i got a t v on my wall like a picture an its broken wont turn on with the remote i did everything like u all said an there isnt nothing a 42 inch junk on the wall
Posted on Oct 29, 2008
Seriously, I have a 42-inch plasma sitting in storage because it's useless now. We are all having the exact same problem, and we're just the people who came to this site. I bet if we advertised something online, we'd find a hell of a lot more people who have this problem. Is anyone here a lawyer? Does anyone want to take on the task of finding out how to file a suit? If I didn't have 3 jobs, I'd already be starting. If enough time passes that I get fed up enough to start a lawsuit, I'll post.
Cate
Posted on Oct 23, 2008
  • cmorin333 Nov 03, 2008
    I had no idea the board itself was Samsung. Did you open the TV to find this out? Samsung is a much bigger name and could stand to lose a little more if it were to get out that these TVs have this defect and no one is doing anything about it. A very close friend of mine works for a Fox news station. If there is definite information that Samsung built these boards that are crapping out, I think we should be calling them about this too. And if they don't want to listen, then we call our local consumer affairs departments and television news stations. We seriously need to get the ball rolling here, but we have to get everyone involved. The more of us reporting this stuff to SVA, Samsung, Consumer Affairs, The Better Business Bureau and our local news stations, the more support we might get. Is it worth it if going online and/or making a quick couple of phone calls gets your TV working and/or replaced? I think it is. But one person calling isn't going to do the trick. We need to all get together on this. And if someone coming here designs websites, maybe you can build a site that includes the exact make and model number requesting others with the same problem to add their info to some sort of mailing list so we can see how many people are really experiencing this and just haven't come to this particular site. The bigger our numbers, the more people will have to listen.
    ~Cate
  • cmorin333 Oct 22, 2009
    It worked. I got that part and replaced it in my television. It works again. Thanks to the person who originally found this part and provided instructions on how to fix this TV. I have been waiting 2 years to get my TV working again! It cost me 150 bucks and only because I opted for 2-day shipping. It's 130-something with the free shipping.
    Thank you, thank you!
    ~Cate
I'm too, irritated by the same problems. My TV is clicking but not turning on. A tech came by on Friday; TV turned on and worked just fine. Now two days later, its not turning on. I agree with a class action who wants to start?
Posted on Aug 25, 2008
Same Problem on mine as well, has anyone had any luck with a new power supply???? Class action I'm in
Posted on Feb 16, 2008
I have the same problem and called there tech support ((714) 646 7024) and the guy said they could fix it if I pay for shipping both ways and all parts and labor. He stated if the TV is use too often the power supply goes out and will need to be replace (part only is $450.00). I purchase mine July of 2005 not saying much for the SVA products to only last around 2 years.
Posted on Jun 28, 2007
Same problem here.
Poorly designed power board.
Count me in on class action.
Ihave same problem red ligh stays on no picture this is not right can we all email or call sva same time and let them no we are serious?
Posted on Sep 28, 2008
I've got the same tv and the same problem. It works fine when it turns on; unfortunatly mine doesn't anymore. Is there any hope sva will "man up" or are they just going to be corporate slimbags...
Posted on Sep 25, 2008
I'm stuck with the same problem. SVA needs to own up, and help us with this design defect. Class action suit?
Posted on Dec 19, 2007
Code for sony tv
Make sure your TV is on.
press "TV" on your sky remote
hold down both "SELECT" and then "RED" button until the little LED blinks twice on your sky remote. (should be for about 2 seconds)
press "TV" again
enter the code "0000" on your sky remote
the little LED should blink twice again. (if it didnt, restart the process)
if it had blink twice, then press the "STANDBY" button on the sky remote - your TV should turn off. (if it didnt, restart process again)
if it did - press "SELECT" the little LED should blink twice again, and hey presto - you is programmed wink.gif
Apr 25, 2013 | Radio Shack (15-2147) Remote Control
Looking for a sky remote control code for beko.
Hello
The three digit Sky remote code for Beco TV are:
514 398 065
Four digit code is:
0125
1* Turn your TV and SkyHD box on and press tv on your remote control.
2* Hold down select and the red button together until the red light on your remote
control blinks twice (this is after about two seconds).
3* Press tv again.
4* Key in your TV's brand code. The light on your remote control blinks twice.
5* Press standby on your remote control.
If your TV switches off, press select.
The light on your remote control should blink twice.
If your TV does not switch off, press tv, then press standby.
Repeat the sequence of pressing tv then standby until the TV switches off,
then press select.
If the light blinks three times, your remote control has checked all the possible
settings for the code you used. Check you have the right code and start again
at step 1.
*6 Turn your TV back on and press the tv guide button on your remote control.
The TV Guide screen appears, meaning the remote control settings have
been reset.
Aug 12, 2011 | Televison & Video
What is the code for LG 37LE4500 TO WORK WITH SKY REMOTE CONTROL
I also have an LG TV. I used this 4 digit code: 0742.
TO PROGRAM THE remote USING THE 4 DIGIT CODE:
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
Mar 12, 2011 | LG Televison & Video
How do you tune Sky+ remote into Sony KDL46W5710 Television
The Sky+ remote should automatically default to Sony TV's. Leave the batteries out for a few minutes and try again. The Code for Sony is 0000.
Or try this :-
With TV and sky box on.
Press the 'TV' button on the remote.
Hold down the 'select' and the 'red' button (of the four coloured buttons) together, until the red light on the remote blinks twice. (takes 2 seconds)
Press the 'TV' button again.
Now enter four zeros, the red light on the remote should blink twice.
Press the 'standby' button (top right).
If the TV turns off, then press 'select' and the light should blink twice again, job done.
If the TV does not turn off then press 'TV' followed by 'standby' again.
Alternate pressing 'TV' 'Standby' until the TV turns off.
When it does, finish by pressing 'Select.
Check the red light on the remote, if it blinks 3 times, then it has run out of options for 0000.
Dec 19, 2009 | Televison & Video
I want to find the Sky remote code for this Tv.
Just got an LG 42LH2000 and code 0206 works
May 16, 2009 | LG Televison & Video
How do i key in code for digibox
TO PROGRAM THE remote USING THE 3 DIGIT CODE:
1. Turn on the TV receiver
2. Press TV on the Sky Remote Control
3. Hold down SELECT and the RED buttons together for approximately two seconds, until the RED LED on the Sky remote blinks twice.
4. Enter three digit code from list for the receiver (early versions now flash twice).
5. Press select to enter code structure (the LED will flash twice if a valid code has been entered).
6. Now press the STDBY button and test other functions.
Repeat if necessary until a code is found that works most common functions.
1. Turn your TV on.
If at this point the LED on the Sky remote control blinks three times then all possible codes for that make of receiver have been checked. Repeat from step one, ensuring that you enter the correct manufacturer code.
At the end of the sequence, if you see the TV Guide screen, the remote control setup process is complete. If you did not see the TV Guide screen, you must now complete the following steps.
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV.
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
If after trying this, you still have problems, call your broadcaster's help desk. For your broadcaster's help desk number, select the Telephone Numbers option from the Services screen.
Dec 19, 2008 | Computers & Internet
TV REMOTE CONTROL NOT WORKING
1. Turn your TV on.
Oct 17, 2008 | Philips HDD065 MP3 Player
Sky remote
hi turn your tv on then if you get your remote point it at the tv then press tv on the remote then press the red button aswell as the select button together waite till the led on the remote blinks twice then press tv again on the remote then press the off button on the remote keep pressing tv then off pausing a second or 2 till the tv goe's into standby, once the tv goe's into standby press the select button till the led on the remote blinks twice then your remote should be programed into your tv. hope this helps.
Sep 20, 2008 | Audio Players & Recorders
I NEED THE CODE FOR ALBA TV MODEL NO. ALCD15TV8M
There are two code types for sky remotes, Brand Codes & Direct Codes.
The codes for Alba are:
Brand - 0043
Direct - 037, 065, 246, 399, 263, 064, 446
There is a small difference in the way they are set.
To program using the 3 digit code - Direct Code
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Enter the 3 digit code
5) Press the select button to store
Press TV and any number to test, If this does not operate the TV set try below.
To program using the 4 digit code - Brand Code
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting
If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
Feb 18, 2008 | Televison & Video
GE 31GT740 clicks off and on
Dead, led flashing red/green at first, then going to red standby
Replace C604 (1000uF, 16v) elec. cap. It is in the decoupling circuit for the 5 volt supply
Reverts to standby from switch on via TV or Video
No 5v rail because FET MTP3055 o/c. (BUZ71 will do nicely)
Goes straight to standby, after a quick burst of power
Replaced R952 (39K), had gone slightly high
Nov 23, 2007 | GE 31GT740 31" TV
SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready Plasma Television Logo
1,494 people viewed this question
Top SVA-USA Televison & Video Experts
Steve Allison
Steve Allison
Marvin
Marvin
pracash
Level 1 Expert
Are you a SVA-USA Televison and Video Expert? Answer questions, earn points and help others
