Question about Hitachi 50SBX70B 50" Rear Projection Television
Unit cuts out after short period.
My 10yr old 50SBX70B flickers and cuts out after a short ON period. Changing outlets turns the unit back on for short period then repeats pattern. Suspect power supply and told its repair could amount to $450. Would it be worth it? Its a great TV when workung.
  • Hitachi Master
  • 5,138 Answers
Yes it could cost as much as $450.00.Your set Needs Both of the STKs replaced. Hope you can solder or get someone who can, STKs are convergence ics they also control power too! If you have in your set STK392-110s use the 180s 110s do not hold up They will be big black ICs
Posted on Dec 24, 2008
I have a Samsung Plasma tv (PN59D8000FFXZA) that after my neighbors house was struck by lightning it won't turn on. What steps should I take for diagnosing the root issue?
When it get hit with any surge usually the main Board is gone, to replace it and hope nothing else is wrong, you can get a 4k LED for probably same price
Amazon com 4k smart tv 50 inch Electronics
Jun 17, 2016 | Samsung Televison & Video
10yr old table saw smells hot and trips breaker
Maybe, but first rule out several other things. Has the saw been recently overloaded - heavy cuts with a dull blade? You may have a partially burnt-out motor (which means the insulation on the wire in the windings has partially melted.) Has it been used recently or used now with an extension cord or to an outlet wired with 15 ga wire? Is the saw arbor hard to turn by hand (with the belt removed)? Does the motor overheat with no load (remove the belt and let it run for 10 minutes)? Try running the saw with the belt on, but not cutting for 10 minutes.
Dec 10, 2012 | Craftsman 10" Table Saw
My 32inch lcd tv keeps flickering it started all the sudden
TRY THIS
    • 1 Turn the TV off with the front-mounted power button, not the remote. Unplug the TV's power cord from the wall outlet. Let an hour pass before plugging the cord back into the wall outlet. Turn the TV back on with the front-mounted power button and wait until it has fully restarted. Bring up a TV channel to see if the image being presented on the LCD screen is no longer flickering. A momentary power surge can cause the circuitry inside the LG-brand LCD TV to function erratically.
    • 2 Unplug the video cable from the video connection on the back or side panel of the LG TV. If more than one video cable is connected to the TV, disconnect all of them. Disconnect the other end of the video cable from the video source device that it's attached to -- a DVD or Blu-ray player, or a satellite receiver or cable box. Blow off the connections on the video source device and on the back or side panel of the TV with bursts of compressed air. Reinsert one end of the video cable into the video source device and the other end into the video input that it was connected to. Turn the TV back on with is remote to see if the picture is now free of flickering. A loose or partially connected video cable can cause the LCD TV's screen to flicker when presenting an image.
    • 3 Turn the TV off and unplug its power cord from the wall outlet. Place a power conditioner next to the wall outlet. Plug the power conditioner's power cord into the wall outlet. Plug the TV's power cord into one of the AC sockets on the power conditioner. Turn the power conditioner on. Turn the TV on to see if the picture is now free of flickering. The RF signals in the electric line that the LG TV is drawing power from can cause flicking through interference patterns being generated.
Oct 20, 2012 | Computers & Internet
The internet will cut out after short periods of time
Try changing the Ac adapter for the router and after changing it do a reset.
It should work perfectly
Jun 07, 2010 | D-Link DIR-300 Wireless Router
My Hitachi 50SBX70B wont stay on
i think you may have a bad flyback. i have an hitachi that did that and ha to change mine out.
Dec 28, 2008 | Toshiba 55H70 55" Rear Projection...
Compressor runs for a sec and cuts off for about couple of minites and runs again
no changing or turning the plug, wont make no difference to the compressor, it sounds to me like your compressor is overheating. have you clean the condenser?? they get durty.
Apr 03, 2008 | Carrier XHC101D Air Conditioner
Need help
If the green lites on bord lites up doesnt mean it is ok. If you check on that board in the middle at the back of the heatsink in the middle, there is two lights, green lights that is not lighting up. If i am wright. You have caps an a transistor on your powersup that is shorted. Take to somebody to fix powersupply.
Jan 24, 2008 | Hitachi 50SBX70B 50" Rear Projection...
Snap crackle pop
Check the Flyback, had same problem, replaced it and the unit worked good.
Oct 15, 2006 | RCA P46921 46" Rear Projection Television
Televison & Video Logo
93 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
