Question about Evenflo Jenny Lind Crib
  • 3 more comments
  • Anonymous Dec 31, 2008
    I need the machine screws and cross dowels as well. I spoke with evenflo this morning and they told me they do not make these replacement parts. does anyone know if they can be purchased at a hardware store
  • Anonymous Mar 17, 2009
    I tried lowes and they do not carry the correct size dowels. I am going to try e-bay.
  • ljsmiller Mar 31, 2009
    I need the cross dowels too. The threading is stipped on it. Has anyone found these at a Lowe's or Home Depot?
  • Anonymous Apr 04, 2009
    I need a part called a "plunger" for a Jenny Lind Convertible crib. How do I order such a part and get it quickly?
  • Anonymous May 15, 2009
    I need a plunger for my jenny lind crib from 2003 and i cant find anywhere that sells it, including evenflo website
Plungers are still available on evenflo site and instructions can be downloaded for free ! The screws and cross dowels may be available on I'm currently checking to see if the size is right.
Posted on May 25, 2009
follow this link
you need a 1/4 X 2-3/16" machine screws, and a 1/4 dia 10 mm wide x 12 mm long cross dowel, best of luck
Posted on May 12, 2009
Need assembly manuel for Jenny Lind 012614 where can I find it online?? Every website takes me to another I am very frustrated....didn't think it would be such a ordeal to locate a manuel online???? Is...
Evenflo Jenny Lind Crib has been recalled.
When you call to get the kit to fix the problem (800) 356-2229 you could ask Evenflo directly!
Here are instructions without a manual...
1. Lay the headboard on the floor in front of you with the bracket holes and model number facing you. Use 2 ¾-inch wood screws to attach the L-bracket and the latch bracket to headboard. The L-bracket has 3 holes and attaches to the holes on the lowest section of the headboard. The latch bracket only has 2 holes and goes directly beneath the metal bracket for the mattress that is already attached. It should face toward the center of the headboard. Once you're done, complete the same procedure on the right side of the headboard. Then do the same for the footboard.
2. Stand the headboard up so you can attach the rails to it. First, place the cross dowel (the small piece of wood with a hole in the side of it) into the hole on the underside of the top rung of the rail. Then put a second dowel in the top side of the bottom rung. Line the left rail up with the headboard at a 90-degree angle, placing it in the brackets you just installed, and insert a 2 13/16-inch machine screw into each of the 2 holes on the front side of the headboard (the side that will face outward). Tighten each screw with your screwdriver until it hits the cross dowel. Then turn the cross dowel clockwise to lock it in. Do the same for the right side and then for the footboard.
3. Slide the mattress platform (the bottom of the crib) into the stabilizer rails (easy to distinguish, since they are the same size as the sides of the platform), putting the longer ones on the sides and the shorter ones on the ends. It will slide in easily. Use 5 ¾-inch screws to attach the hanger brackets to the corners of the platform. The holes are predrilled and you can only put the bracket on one way to match them up, so there is little worry that you will attach it wrong.
4. Put the support brackets (the straight, flat ones) on top of the predrilled holes in the underside of the stabilizer rails. Screw them in with ¾-inch wood screws. Then place the hanger brackets in the slots that were preinstalled on the headboard and footboard. Choose the level that will suit you best. Evenflo recommends the top two for infants.
5. Snap a caster (the round disc) on the bottom of each foot of the crib. Check that all your screws are tight to keep your baby safe.
Jan 29, 2011 | Evenflo Jenny Lind Crib
I need 4 cross dowels,2 13/16 machine screws, and 2 plungers to reassemble my jenny lind crib
You can call Products America at 800-205-9642 or 800-772-1041. They offer a wide verity of hardware for many cribs.
Nov 18, 2009 | Evenflo Jenny Lind Crib
Where to get dowels, screws and springs
Products America can help you with the hardware you are needing. You can contact them at 800-205-9642 or 800-772-1041 Monday thru Friday from 8am to 6pm CST. They will ask a few questions about your crib and possibly need measurements but should not have a problem getting you the hardware.
Oct 14, 2009 | Evenflo Jenny Lind Crib
Need the screws for a jenny lind crib
call MDB parts in california 14-323-728+9988 x120 .  you will probably need part number, serial number and manufacturing date from the label inside the crib.
Sep 10, 2009 | DaVinci Jenny Lind Crib
Jenny Lind crib instructions...
Jenny Lind is a style of crib, not the mfg
DaVinci makes Jenny Lind...
If you find your model, go to the Customer Care and click order parts
May 30, 2009 | DaVinci Jenny Lind Crib
Hardware parts for jenny lind baby bed
I need the 2 gate shows for the drop side and the hooks to hold the mattress spring. Please help!!!!
May 15, 2009 | Evenflo Jenny Lind Crib
Need screws to put baby bed back together (lost previous screws)
Simplicity for Children Ellis 4-in-1 Convertible Baby Crib
i lost all the screws and directions i need a new set does anyone know were i can any
Mar 24, 2008 | Evenflo Jenny Lind Crib
Evenflo Jenny Lind Crib Logo
971 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Shehu Pro
Shehu Pro
Rick Moore
Rick Moore
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
