Question about HP Pavilion dv9000z Notebook
My HP laptop is stuck on its NVIDIA settings. I connected it to the TV via S-VIDEO.... and set the NVIDIA settings to "clone"... watched the movie... and now try to put the screen back to normal.. and wont work. I unplugged everything..... my laptop thinks its still on "clone" .... please help, the NIVIDIA settings disappeared and I cant get them back..
    Sergeant:
  • 287 Answers
HAVE YOU TRIED SYSTEM RESTORE? IF YOU CAN DO A RESTORE TO BEFORE YOU USED IT FOR YOUR TV IT SHOULD BOOT BACK TO THE TIME PRIOR TO ANY PROBLEMS. THIS IS JUST ONE FIX. THERE ARE MANY THINGS YOU CAN DO. JUST TRY THIS FIRST AS IT IS THE EASYEST. IF THAT FAILS GET BACK TO ME AND I WILL RUN YOU THROUGH HOW TO GET IT WORKING IN A LONGER VERSION.YOU CAN ALSO DOWNLOAD DRIVERS FOR NVIDIA AT NVIDIA.COM. IF YOU KNOW THE VIDEO CARD YOU HAVE.
Posted on Jan 08, 2009
How do i connect to my tv
need hdmi dvi or vga cable depending on what you have use you video card properties to set it up and there is software made just for doing that basically set you lets say nvidia nvidia control panel multiple screens or clone screen but there is software that does better for money of course
Mar 03, 2013 | HP Pavilion DV6700Z Notebook
How can i run my program on tv out which is running on my pc same to same as powerpoint show and tv play both at time.??
I assume you already have a cable (s-video) connecting your tv to the video card, on windows video settings you can select the clone mode that mode make the both screen display the same. on windows xp use right click on the screen select proprieties and on the last tab set the desire configuration you can extend or clone, use clone. on windows vista or 7 just use the shortcut WIN + P and use the duplicate mode.
For that normally you but boot your pc wit the video cable already connected.
After doing all you can set the proper resolution and configuration of the additional screen on the display properties.
Mar 13, 2011 | Nvidia GeForce FX 5200 Video Card Graphic
"No Signal" Message when using HDMI Inputs on 26" Proscan LCD TV
You MUST get HDMI Driver for your Video Card, it is NOT standard. You need to go to PC makers web site and download latest Video Divers for your PC, then you must set up Multiple Desktops, To do that you must first connect the TV, but leave OFF, connect up to PC, reboot, setup Video Card, turn ON TV, TV will have already been detected, On PC, Share the desktop, or Clone, whatever you wish, now reboot after saving settings. Now you set the TV for HDMI already and it should show you a desktop when chosen. You must select and setup TV, FIRST, then connect the PC. From then on, Turn the TV ON, then turn the PC ON, that way it will Always detect the HDMI port.
Apr 23, 2010 | Proscan 26LB30QD 26 in. LCD HDTV
What channel do i go to for svideo cable??
The TV doesn't output the TV as such, UNLESS it has what is called a "Monitor" Output Sockets on it. Then you can connect up to, say another "Screen" or Take the Outgoing Video, & Sound, and "Record" it to a PC, via a Video INPUT via a TV/Video INPUT card. BUT you cannot play the TV on the laptop, FROM the TV. like you wish to do. If your laptop has a TV card INSIDE your laptop, then you could use that and display the OUTPUT from that TV cards' tuner, on the TV. But not the "other" way around. That SVHS is ONLY an INPUT out from your PC. You can put you system into either "Cloned"mode, IE: Whats displayed on laptop screen,is also displayed on the TV, Or, you can have as you seem to now, Extended Desktop. I hope this clears things up for you. Also when using that SVHS connection the Audio comes OUT on the Red & White AV sockets on the set. So you need that cable and another pair for the Audio..
Mar 23, 2010 | RCA L32WD14 32 in. LCD Television
I have connected vga cable to laptop and tv. all I get on the tv is the wallpaper. How do I get the current screen contents to the tv?
At the rear or side of the PC there should be either or both of a 15 Pin DIN Plug, HDMI socket. or a Yellow RCA or 4 -7 pin DIN. Now IF these are present then YES you can connect to a TV. Now some TV's have a connector a DB15 MALE, so that the cable from the PC to the TV, is DB15. this plugs in directly, with appropriate DB15 cable. This, however, will ONLY take the VIDEO to the TV, Audio is delivered via the "Audio Out" Jack on PC, and Plugged into the AV Sockets on the TV, with a dual cored coaxial cable, they are Red & White. Some PC's also have a Yellow RCA Connector, OR a 4 -7 Pin DIN Socket, that requires a Special Adapter Cable (That generally came with the unit, and are colored and marked as to output) to use, for Video/Audio Out to TV. This signal is Composite or SVHS Video & Stereo Out. This connects up TO the TV's Composite/SVHS input Jacks and the Red & White Audio IN, RCA Jacks, &/or DIN SVHS socket.
First you need to know if your PC can output to a TV. Then you need to get the adapter & cables that connect the PC to the TV. Then you need the correct TV drivers installed for your video card. When they are all installed, you need to "Enable" that Monitors, the TV's, Desktop. You need to set either a "Cloned" display or "Spanned, Extended Desktop". Go to "Display Settings" Now ensure the TV/Monitor connected has the correct input/output display settings. Adjust the screens resolution via the resoloution "Slider", it is best to start with, 800x600 32 bit color. or even lower. and once working OK, THEN increase to max resolution, your TV can handle, find out from manual. Once it is all connected up. It should all just work great. Now, from then on, &, to get it to work every-time, the process is. Turn everything OFF. Connect the leads between PC & TV, Turn the TV, ON. Then, startup the PC up. It should "Detect" that it has TWO "Monitors" ie: One Monitor & One TV/Monitor, & you should see your desktop appear after a bit. Now you have screen 1 & screens 2. Now, if you are using "Cloned" mode, then whatever is displayed on the Master monitor, will be displayed on the TV. If you used Spanned, mode, in this mode, however, you will have to."Drag" the Video window, over to the TV, and it is though, you have one "Big Desktop". Now IF using Nvidia or ATI then BOTH of those have thier OWN, Control Panel, this, all then can make it all a lot easier to do it. So I would suggest that this method be used. But if you get stuck, or just want to do it by hand, then the the "By Hand" method is the only way.There is a great program called MultiMon, this allows great control over dual displays, and is well worth installing.
Feb 12, 2010 | Acer Aspire 5100 Notebook
HDMI LCD
HDMI is a great idea but has its limits try loading the newest video driver for your laptop from the actual vga card manufacture website not DEll but ATI or Nvidia whichever one came onboard that pc.
Dec 30, 2009 | Dell Inspiron Mini 10 Notebook
GeForce 7200 GS 256MB won't work with tv
"the tv works and I can see my extended desktop, but ONLY in 800x600!!! Also when I tried to watch a movie on the tv, it only showed a black block"
1. Tv's only support max of 800x600 (technically less)
2. Windows has a built in ANTI theft BS protection that makes viewing video through an alternate output show up black boxed.
Mar 16, 2009 | Nvidia GeForce 7200 Graphic Card
Need help watching a movie from laptopn to tv
What kind of help?
Connection?
  • if you have a S-Video connection use it (remember to use another cable for audio)
  • If your TV set has a VGA connection use it (always + audio cable)
  • If HDMI connection available use it
OR look for a special connector matching PC VGA port with RF modulated antenna signal on TV set or composite input. Here some detail
Jan 30, 2009 | HP Compaq nc6000 Notebook
Connecting asus notebook via hdmi to LG 42 plasma tv
best option to use s-video lead ...use fn + f-key that has little square printed on it ...hp mostly fn+f4
Jan 11, 2009 | HP Pavilion dv6000z Notebook
HP Pavilion dv9000z Notebook Logo
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
