Question about PfaFF Tiptronic 2040
Main motor jammed due to stuck bobbin threads
This is a recurring problem today. I cannot see any threads and have no clue how to remedy as the instruction book says NOTHING about this. Please help. I have had this machine about a year and a half and have only just recently started to use it. The first time this happened I was able to quickly remove a caught thread, This time, I have spent an hour on it to no avail. I have never had this problem with any of my other machines (Berninas), just with my two Pfaffs. Very disappointing for an expensive machine.Thank you.
    New Friend:
  • 186 Answers
If you are unable to get any stitches at all then it could be your hook basket has spun out of position and it needs to go to a repair shop.
Hopefully it is just a matter of cleaning out the upper tension discs from any lint or thread that is in there. (Make sure the presser foot is up when threading so the discs are open and the thread gets down into them completly and that the tension dial is not set too low or on zero).
I hope this helps, good luck!
Posted on Jan 31, 2009
I ran my Juki DDL 8700 without any fabric to test and the threads got sucked in and now the needle is jammed, when I turn the hand wheel it won't move the needle.
Loosen the needle. Once the needle is released, the threads holding it may loosen. Then gently try clipping jammed threads with tiny scissors and patiently try removing cut threads with tweezers..
Dec 21, 2017 | Juki Sewing Machines
The bobbin case on my singer feaherweight is stuck
Sounds like thread or lint has got on the centre spindle of the hook. and jammed bobbin inside case. unclip race and remove hook and bobbin assembly. remove feed dogs and all tangled thread. machine should then be freed up
Feb 05, 2014 | Sewing Machines
Bobbin thread gets jammed
Is it forming a stitch at all? Do you have your needle set properly and are you certain it is the correct size. it sounds like the hook isn't catching the loop formed by the needle. If changing the needle doesn't help. it might be time for a clean and adjust.
Dec 14, 2012 | Kenmore Sewing Machines
When I put the pedal down, the bobbin jams, and cuts the thread
try changing the needle
make sure the needle & thread & fabric are correct for each other
make sure ever thread guide is being used
try adjusting the top tension
Apr 01, 2012 | Sewing Machines
My ce4000 started jamming up thread under the foot and then it pulls the bobbin case and gets stuck so that it doesn't sew at all
If the thread is getting jammed under the FABRIC then it means the TOP thread is threaded wrong. Just the opposite of what we think it should be. If the thread is looping on the TOP of your fabric it's the BOBBIN thread that's not threaded right. If it's a front loading bobbin, the thread should go over the top of the bobbin to the right before placing it in the bobbin case. Hope this helps!
Aug 21, 2010 | Brother CE4000 Computerized Sewing Machine
The bobbin case sounds loose and the thread jams with the fabric and everything gets stuck.
That use to concern me too! I thought it signalled a problem, but my bobbin case has always been loose and that was not what was causing my thread and fabric jam. Usually what causes the jam is an incorrectly wound bobbin, wrong needle or old needle, old thread, or a slightly warped bobbin that is hard to see/detect. Change everything out--needle, thread, bobbin...this usually does the trick!
Mar 24, 2010 | Husqvarna Rose
My Pfaff 2140 giving message main motor blocked.
I have gotten the main motor blocked message several times. When I get this, I always remove thread, both top and bottom. I change the needle too. 75% of the time my problem goes away. If the problem is not solved, I unscrew the casing in the front of the bobbin, and look for anything that might be obstructing the bobbin. While I've had lots of "blocked motor" messages, I've never had to get a tech to ook at it. Sometimes, if you leave it overnight too, the sewing machine fairy will change something and the problem will solve itself in the morning. Re-thread, re-bobbin, re-needle. to start.
Dec 22, 2008 | PfaFF Creative 7570
No action
Remove the bobbin, bobbin case as well as the shuttle hook. There are black pins/holders that hold the shuttle hook. After you remove these 3 components, make sure there are no thread stuck in between the 2 hook pieces as well as the bobbin shaft. Most of them time, there are either fabric or thread stuck. If not, make sure the needle is not hitting the feed dog or the hook.
Feb 23, 2008 | Yamata FY920
Sewing Machines Logo
161 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
