Question about Toshiba Tecra A3 Notebook
Disable onboard mouse
I really want to disable my onboard mouse "that small button !" its pain now and i need to use external mouse. Due to conflict pointer is running marathon on my screen dont know what to do but i sure want to switch of on board mouse on my Toshiba Tecra 9100. Its old i know but still works ! Guys help me please.
Had same problem ,mouse constantly drifted even when connecting ext mouse\tried everything to solve.
Found solution in removing keyboard , the plastic strip at top of keyboard lifts to reveal 2 screws .remove these plus a central screw on the base of the laptop. Carefully lift keyboard and the thin flat keyboard cable slides into a connector on the motherboard.The two small black bits at side of connector push towards screen to release the cable.
I then put some thin tape over the first four connections(at left hand side of cable looking at laptop front view) on this cable. The connections stand out ,i think the cable was a different shade for these four connectors.
. These control the accupoint stick on the keyboard. They could also be carefully cut out. replace keyboard making sure to clip the keyboard cable in.
I can now use an external mouse without any drifting of the pointer ,only drawback is the accupoint stick does not work at all.
Posted on Sep 28, 2012
  • booboo931
    booboo931 Sep 28, 2012
  • booboo931
    be careful not to cut or cover rest of cable
    Guru:
  • 829 Answers
TouchPad Enable/Disable ( Fn+F9 )
Posted on Dec 24, 2008
Logitech mk320 mouse freezes
If you have a extern video graphic card
Please check if your motherboard has an onboard video. (INTEL motherboards for example) If so, go to the BIOS and disable it.
I had the same problem and not only with Logitec. I disabled the onboard video and no problem anymore! It has something to do with windows updates, I presume. But the problem is solved.
Jan 02, 2013 | Logitech 967437-0403 Keyboard
Well, my Netbook scrolls down randomly. Either up or down. No matter what I do it won't stop, I usually bang on the directional keys and it does stop for a short period. I really don't want to keep...
Sticky keys might be the problems.
1.Press SHIFT 5 times repeatedly
2.Cleanup the touchpad on the right corners ( unit OFF )
3.Seem the PgUp and PgDn keys STICKY >>> try clean it with a dry soft brush
Aug 16, 2011 | HP Mini 1000 Netbook
I have a sony vaio eb series white laptop. The trackpad seems to be disabled and the cursor does not move. However, if i connect an external mouse, the problem is resolved. How do i re-enable my...
Hello, you have to check on your keyboard if it has 'Fn' sign, then if it is there, hold on it and locate key that has a mouse sigh on it and hit on it and try your mouse again. onboard mouse.
Apr 02, 2011 | Sony VAIO EB Series White Notebook...
I bought an external mouse and now I can't turn the toutch pad off. It's becoming a pain for me when I'm typing. I did it once but I can't do it again. How am I supposed to go about disabling it?
Hellocrazybookworm,
To "Disable" the Mouse Pad, or ("Pointer Device").
  • Go to the Control Panel; select the (Mouse) in the Hardware and Sound category.
  • Next select the Device Settings, in the (Devices) block.
  • Click on, and "highlight the item you want to [Disable]" this being the "Pointer Device.
  • This will also "Disable" the "Mouse Pad."
  • Click the "Disable button," just below.
  • "Always ("click") on the, "Apply, and OK buttons before exiting.
  • *Note: Restarting the Computer, will configure "System" changes in the Computer.
  • To prevent errors from occurring. This is also important when, (Installing / Uninstalling) "Programs."
  • "To include (Enabling / Disabling) of Hardware."
    If this information helped? Return and give a "Helpful Rating," please!
    Thanks, paul7of9
Feb 23, 2011 | ASUS U52F-BBL9 Laptop
Mouse button is broken
Hi:
The touchpad and mouse buttons can be replaced, but it involves some serious disassembly of the laptop to do so, and I don't recommend trying it unless you have laptop repair experience.
A inexpensive alternative is to buy a wireless or wired mouse , and plug it into one of your usb ports. Most new mice , especially ones from microsoft come with software that disables the onboard mouse when you plug in a external one, and that would take care of your problem!
Oct 29, 2009 | Dell Computers & Internet
Battery light blinks when plugged in, does not work on battery
Check to see if it is putting voltage from the adapter with VOM. Most likely a bad battery
Oct 09, 2009 | Toshiba Computers & Internet
Right click not working
go into the mouse icon in the control panel and make sure its not disabled in there. If it is then enable it. If its not disabled in there then the board underneath your mousepad is bad. The right tactile button undernath the right mouse button is bad so the whole board would need to be replaced cause it comes as one whole board. You can get it directly from Dell or get one from Ebay.
May 17, 2009 | Dell Inspiron 1501 Notebook
Disable track pad when using the mouse on advent 6311
Do you want to disable the onboard touchpad while you use an external mouse?
To do this there should be a key sequence on the laptop like Fn+ F8 (or another key) it has a mouse symbol on it.
May 11, 2009 | Acer Aspire 3680 Laptop
Acer Aspire 3000 laptop
Hi, Try pressing the FN+F7 buttons together. This will enables or disables the touchpad.
Cheers!
Apr 12, 2008 | Acer Aspire 3000 Notebook
How to disable onboard VGA
I believe if you install an AGP card the onboard VGA is supposed to be automatically disabled. Did you buy an AGP card?
Nov 28, 2007 | Foxconn P4M800P7MA-RS2 Motherboard
Toshiba Tecra A3 Notebook Logo
549 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
