UMC401 oven The digital timer resets itself when I put the oven into the ON position (turning both Progran and Temperature knobes on).
  • prblau Dec 24, 2008
    The oven was switched off and pluged out for few days, but it didn't help.
    What is ERC? Where can I get such part?
    Genius:
  • 1,011 Answers
Dear Sir/Madam,
When timer is stopped, press both HR and MIN
buttons simultaneously to clear count down
time, the timer will reset to 0:00:00.
Press START/STOP button to begin the count up
Press START/STOP button to interrupt the
count. Press START/STOP button again
to resume the count.
Press both HR and MIN buttons simultaneously
to clear count up time, the timer will reset
to 0:00:00.
thanks
goodluck
Posted on Dec 24, 2008
    Guru:
  • 449 Answers
Most of the time turning the breaker off for a few min will be a temp. solution but it it comes back then the ERC which is the clock itself needs to be replaced
  • Jerry Parmanand Dec 24, 2008
    ERC is the touch pad or clock assembly quick way to check if it's bad. you can buy from ebay.
    - Disconnect power to the range.
    - Gain access to the back of the ERC (electronic range control, or "clock").
    - Unplug the touch pad ribbon connector from the ERC. This will be a flat wire about 1 ½" to 2" wide.
    - Make sure everything is clear and will not short out when power is turned back on. Replace any covers removed to gain access to the ERC.
    - Turn the power back on to the range.
    - Watch for the F-1 and listen for the beep.
    - If you get the F-1 and beep, replace the ERC.
    - If after approximately 60 Minutes you do not get the F-1 fault, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock control as one part so F1 = bad clock control.
    Warning: If you do not feel comfortable doing this test or making this repair please contact a qualified appliance repair technician.
    Sergeant:
    Novelist:
  • 327 Answers
My oven turns itself off when on fan forced when I put temperature to 225 why I am left with stuff in oven no fan it comes back on after round 10 mins
Pls be more specific with make and model to get a better answer. But it sounds like it can be a problem with your safety thermostat that is set lower then 225 and that couse the oven to switch off and when it cools down to the temperature that the safty stat is set on the oven will reset and start working agian
Jun 29, 2015 | Ovens
AEG oven switches itself off after 35 mins
does it turn off after the oven has got upto temperature if it does it is probably that your thermostat has gone as this cuts off as a safety feature if your oven gets hotter than the thermo setting then it will shut off to protect from over heating or causing a fire hazzard with high temperature are you sure you havent changed the timer as well cus you can set a timer for your oven to switch on at certain time and to also switch off after a certain time if you still have the manuall have a look through the timer section if you do not have a manuall then check on your makers web site these should have a manuall online for you to check first i would check that the timer is not on if i can find you a manuall online i will post back hope this is some help.................
Nov 04, 2007 | Ovens
I have lost my manual for a Simpson Appolo Atlas Stove
call manufactuerer and ask if you can order one or try to do so online
Dec 22, 2009 | Stoves EC500DOA Electric Kitchen Range
I need an owner manuel for Caloric Range Model # EST 345 I can'g figure out how to run the self cleaning oven cycle.
you might try the following, although it is the instructions for an old model, it may be relevant;
"The actual self-cleaning process is initiated by a simple 5 step procedure: 1. Set the range clock to time of day. Note: on models not equipped with an automatic oven timer, the self-cleaning cycle is preprogrammed for a 21/2 hour cycle. Use Steps 3, 4 and 5 only. 2.Establish the length of cleaning time by:
A. Setting the start time. Press and turn the start dial of the automatic oven timer clockwise to the desired starting time. B. Set the stop time. Press and turn the stop dial of the automatic oven timer clockwise to the desired stop time. Max time is 3 hours miniumum 1/12 hours. 3. Set the oven selector dial on the control panel to "Clean" 4. Set the temperature control dial to "off". If you temperature control dial has a "Clean" position, then set the dial to "Clean" instead of "Off". 5. Remove oven racks, broiler pan and broiler grid from lower oven. Close and lock the oven door by moving the latch lever as far right as it will go - into the locked position. If the lever is accidently dislodged restore it to the locked position. Otherwise, the self-cleaning process will not take place. Shortly after the cleaning cycle has begun, the oven temperatur reaches a degree in excess of the normal broiling temperature. The red "Clean" light will come on and the clean cycle will start. In a few minutes the door lock lever, which you have placed in the locked position, will automatically be secured to prevent the oven door from beging opened during the cleaning cycle. This latch remains locked until the clean cycle is complete and the oven temperature reduces to normal baking and broiling temperaturs. NOTE: Prior to self cleaning cycle operation, the oven and surface lights must be turned offed. The upper oven can be used."
I found this here; http://www.appliance411.com/archive/21155_caloric_oven_lost_cleaning_manual.shtml
Nov 18, 2009 | Ovens
Oven turns itself on???? Timer beeping when family woke up???
Sounds like someone messed with your timer... Easy reset: turn the breaker off and back on...reset clock... woo hoo!
Jul 30, 2009 | Whirlpool RBS305PDS Electric Single Oven
Oven turns off if too hot
There is a temperature switch that shuts the power down if the temperature goes too high. This is to prevent a fire if your thermostat sticks on. Sometimes the switch will become weak and open the circuit at too low of a temperature. Replacing the switch should solve your problem.
If you need more assistance, post a comment with the model and s/n of your stove.
Thanks,
Tim
Jun 28, 2009 | Ovens
Ariston oven error code F8E0
solved by rotate the temperature knob!!!
maybe would be a problem of the potentiometer or knobe of temperature
Jun 28, 2009 | Ariston Technologies Ovens
The oven won't come on, the digital timer just flashes continuous
Hi
have you tried setting the clock as the oven wont work if the clock is not set. hope this helps
regards dan
Mar 19, 2009 | De Dietrich UMP404 Powerclean Stainless...
Temperature gauge won't elevate past 350 and timer is messed up
somehow you have entered into the oven calibration mode at least that is what it sounds like. Normally if your press the clear button or reset it should come out of that mode you also could try to turn your breaker off for 15-30 min and then turn it back on. I dont think I would recommend cleaning cycle if the oven control is acting up.
Nov 05, 2008 | Whirlpool GBD307PDS Electric Double Oven
Oven switches 'itself' off without the timer
I sorted it it is a simple solution, if you take the top of your oven you should see the problem...it will be big and black..dont spend a ortune getting it sorted i brought the part off ebay for less than a fiver.. just cant remember what it was called..very simple to fix though.  Mike
Dec 19, 2006 | Electrolux EOB6632 Electric Single Oven
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
