Question about Beverage-Air Beverage Air DW49-S Horizontal Bottle Cooler
Clogged drain in a beverage aire mod# dw49
The drain assembly is incased inside of the unit and i need to find the best way to access the drain assembly.
    Scholar:
  • 81 Answers
I like to use compressed air, sometimes a wire may work to clear the drain line. It will require some dissassembly of the unit to gain good access to the drain. Clean everything once dissassembled, it will save you trouble later. Hope this helps.
Posted on Jun 28, 2009
Why doesn't the dehumidifier portion work?
HAVE YOU CHECKED FOR ANY OBSTRUCTION IN THE CONNECTION?
Jun 20, 2015 | Beverage-Air DW49 Stainless Steel Beverage...
Water dripping on everything inside - seems to be collecting on outside of upper fan housing. Drain hose is not clogged.
You need to shut it off and get the ice to melt off the coil. With that accomplished, put a thermometer inside and don't put the temperature below 37 degrees f. Hope this helps and good luck.
Jul 05, 2014 | Beverage-Air Beverage Air MT12 12 Cu. Ft....
Rattling sound when unit is on. Fan barely spins (if at all). Funky dry smell comes from the unit. I need to know if this is the Condenser Motor or Compressor or what? Or all?
Which fan barely spins? Is it the one inside the unit or the one by the compressor. Does the compressor come on? Need some more information
Mar 11, 2014 | Beverage-Air DW49 Stainless Steel Beverage...
I have my moonroof drain clogged backside how can I clear it?
You will have to access the drain assembly to try to blow the debris from the assembly with compressed air. This will require some disassembly to get to the moon-roof drain assembly. Most moon roof units can be accessed by removing the headliner.
May 28, 2011 | Toyota Camry Cars & Trucks
I own a beverage air sp48-12 prep cooler. it has a water coming out from where the temp control switch is. what could be the problem?
The condensate drain line is likely clogged. You will need to disassemble the evaporator panels inside the refrigerator. A small brush or wire can be used to dislodge any debris in the tube. When this line is clogged the condensate water has no place to go. Water will follow the path of least resistance which in your case is where the thermostat is.
Jan 22, 2011 | Beverage-Air SP48-12 Commercial...
I have a Bevair DD58 and it won't stay cold. I
the three weeks kinda tips us off to a leak in the sealed system
check your sradder valve for a proper seat
and make sure your joints are clean and complete
Oct 13, 2009 | Beverage-Air DW49 Stainless Steel Beverage...
Looking for age on Beverage Air Horizontal Bottle Cooler
Call Beverage-Air and provide both model and serial # to the parts department and they should be able to identify the year the unit was manufactured - 800-845-9800
Matt - coolergaskets.com
Dec 09, 2008 | Beverage-Air Beverage Air DW49-S...
With the BevAir DW49 does a lower number mean colder or warmer?
1 is usually the warmest setting. The higher the number to colder the setting. Start in the middle and make minor adjustments allowing considerable time in between to dial in the temp of your unit.
Dec 04, 2008 | Beverage-Air DW49 Stainless Steel Beverage...
Refrigerators Logo
189 people viewed this question
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Marvin
Marvin
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
