Question about Video Game Consoles & Games
Ds lite slot repair
how did you removed the slot itself from the ds?
am afraid to damage others parts,as its soldered to the ds.
Thanks,
Lara
  • csjrohm May 11, 2010
    is it tipped or straight in?
I hate you all
Posted on Jan 06, 2009
DS Lite no longer recognizes games when they are inserted
My best suggestions for resolving the bent/ broken slot-1 pins are:
1) If under warranty then send it off to them for repair.
2) Find a local repair place and give it to them to repair it.
3) If you have good soldering skills and fancy a bit of DIY repair you can have a go at sorting it yourself.
To be honest its far easier to just replace the entire slot-1 part than it is to take the part apart and repair it, the cost of the slot- 1 is very reasonable from ebay.
I have a few guides written up to help you if you do decide to take the DIY option, they are as follows:
DS lite slot-1 replacement guide
DS lite dismantle guide
Hope this helps, any further help or advice you may need then feel free to contact me.
Regards,
SOD69
Mar 13, 2010 | Nintendo DS Lite Console
Tip
DS Lite Slot -1, games cartridge not reading games repair / resolution.
Has your slot -1 games cartridge reader stopped working? Is it being temperamental with your cartridges? Here are a few tips to get your DS lite back to full working order.
1) First try giving the games cartridges metal contacts a clean, ideally with a cotton bud and white spirit (if you don't have white spirit try avoiding anything soapy, if you can try to stick to an alcohol based solvant such as nail polish remover).
2) If that doesn't work you can try cleaning the cartridge socket (slot1), you can buy proper cleaning cartridges for the DS lite, or, if your feeling brave you can get a jaye cloth, dampen it with an alcohol based solution (same as what is used to clean the cartridge) make sure it is well wrung out so that the cloth is only slightly damp and thinly wrap it around a rigid ruler, which can then be gently placed into the slot to give it a bit of a clean.
3) If both of those fail you may find that some of the pins within slot1 are bent/snapped and so this will need to be fixed, If under warranty i'd suggest taking them in to get looked at. If they are not and you feel brave you can set about fixing it yourself, take the DS lite apart and have a look at the pins on the slot1 socket, if they are damaged you can buy a replacement socket on ebay, but be warned it is a tricky job to solder a new one on.
To solder the replacement slot -1 on firstly you will need to remove the old one, take care not to damage the pcb tracks when doing this as it will cause the replacemet process to be far more difficult and a purchase of a track repair fluid may be needed. Your best option is to de-solder it buy removing the exisiting solder to free it from the motherboard. Once you have done this you need to put the new one on, take great care not to fuse any of the pin connections together with the solder as this will cause the DS great problems and break it. Re assemble the DS lite and give it a try.
If you need help with taking the DS lite apart please refer to my other tips and tricks posted on here.
Just so you know I take no responsability for any damage that may occur whilst following these tips.
Regards,
SOD69
on Feb 08, 2010 | Nintendo DS Lite
DS lite plays some games but not others.
Chances are its the slot- 1... Have a look at my guide i've written to see if any of the tips I suggest help, if not there is a bit on replacing the slot- 1 part. I also have a guide on taking apart the DS lite if you need it. The replacement part is readily avaliable on ebay for very little money and so long as you have soldering equipment and a steady hand you should be fine.
Slot- 1 Trouble shoot guide
If you need any more help or have any questions please feel free to contact me via my profile page.
Regards.
SOD69
Feb 14, 2010 | Nintendo DS Lite Console
The top screen on my DS Lite lights up but there is no picture, the touch screen works fine and so dose every thing ellse.
Chances are the screens ribbon connectior has become loose or the screen has develouped a fault.
If its under warranty then send it in, otherwise you can take it to a local repair shop or do a bit of DIY.
Take the DS lite apart (a tri wing screwdriver is needed and can be found cheap on ebay), disconnect the top screen by lifiting the motherboards connector flap (located near the hindge) and then re-insert it, try switching it on again and see if thats sorted it. If not then you will need to replace the screen.
A new screen can be brought on ebay for a reasonable price, there will be a little soldering required as the speakers will need to be de-soldered from the old screen and re-soldered onto the new one (please take note of which wire goes where).
Remove the screws from the lid of the DS lite (4x screws hidden under little coloured squares above and below both speaker outlets) slide the top/outer part away from the hindges, it will move about 5mm and then you can lift it off... Gently pull the ribbon through the hindge so that it is free from the bottom part of the DS lite, pry the screen away from the shell (a small amount of force may be required to remove it) remove the front plastic part of the screen (with the respective DS lite coloured frame, de-solder the speakers, re-attatch them to the new screen, place the new screen into the housing along with the speakers and put back the wifi and mic to their original position if they got moved, you will notice a slot in the hindge where the ribbon goes in, this is for the ribbon to easily slide back into the bottom part of the DS lite... pop the ribbon through and then re-attatch it to the motherboard with the connector, pressing down the connectors flap.
Screw the DS lite back together and hope fully this has resolved the issue.
If you find that your DS lite now doesn't want to stay powered on please refer to my other tips and tricks I have issued on here.
I hope this helps and have to say that I accept no responsability for any damage that may occur to your DS lite when following these tips.
Regards,
SOD69
Feb 07, 2010 | Nintendo DS Lite Console
DS Lite Games will not stay in slot (retaining spring defective?)
Hi
You will need to replace the slot 1 card reader, these can be bought for around £5 on eBay. These need to be soldered to the motherboard, so some soldering skill is needed.
We offer this service at our repair center.
Dec 14, 2009 | Nintendo DS Lite Console
Replacement ds lite game slot
This is a VERY complicated thing to
do it take a high soldering skill
just look on eBay for a replacement mainboard
Dec 24, 2008 | Nintendo DS Console
Nintendo ds bent pins
The part with the damaged pins is the slot-1 port. I know it seems rediculous, but this part is too impractical for most people to attempt a repair.
However, if you are savvy enough to attempt the repair of the damaged pins on your DS Lite, here are my recommendations:
1) Cut a flap in the slot-1 port cover and straighten pins.
2) Replace the main board.
3) Remove the slot-1 port cover and straighten pins.
4) Remove the damaged pins from the slot-1 port and straighten.
5) Replace the slot-1 port.
All of these recommendations require disassembling the DS Lite using a specialized triwing (or Y) screwdriver and a lot of patience. The following video will help in disassembly: http://www.youtube.com/watch?v=HQlTpTLUyFQ.
Recommendations 3 to 5 all require solder work. Recommendation 3 requires solder work for 4 solder joints, 1 at each corner. Recommendation 4 requires solder work for up to 17 solder joints, one for each damaged pin. Recommendation 5 requires solder work for all 21 solder joints.
Dec 10, 2008 | Nintendo DS Lite
Ds lite pins
From outside is pretty difficult to straight the slot 1 pins as it is small and you need very thin pliers and light source plus lots of patience.
With a plier you can straight the bent pins to its right position, but make sure the pin is not out of its place as all the pins are V wedge shaped and the pin comes from the slot bottom, the edge fits in a small hole then goes up to make contact with the game cartridge contacts. No one stay out when inserting a cartridge or you'll have a bigger problem.
If there are many bent pins I find more easy to open the DS, desolder the damaged pins and pull em out of the plastic enclosure to repair it, put it in again and re solder. No one option is easy... Sorry...
Nov 16, 2008 | Nintendo DS Lite Console
Nintendo ds lite - son putgame cartridge in wrong way and has bent a pin on the console - fixable or not?
The part with the damaged pins is the slot-1 port. I know it seems rediculous, but it is too impractical for most people to attempt a repair to this part.
Aug 27, 2008 | Nintendo DS Lite
Broken ds lite. the games were inserted into slot 1 the wrong way round. the pins are bent.
Jun 27, 2008 | Nintendo DS Lite
Video Game Consoles & Games Logo
611 people viewed this question
Top Video Game Consoles & Games Experts
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
