Question about Water Heaters
Radiator Leak rust
To temporary repair a rusty radiator leak, also what sort of boiler is Ariston MTS Genus 24 mffi
  • 152 Answers
What part is leaking ?what type of set up do you have? steam or water
make sure you completely drained and refill the system before use. your water level needs to be corrected or this will force water up the lines instead of steam
your radiators need to be pitched so that the steam (water) can return back when the system shuts off
as for the leak. where it is or what part is leaking
heres a manual for your system
hope this helps
Posted on Dec 24, 2008
Cracked radiator
Bottom line, any radiator leak repair in the coolant is temporary if it works at all. It the radiator is leaking/cracked, you should replace it soon before you're stranded somewhere.
Mar 24, 2014 | K-Seal ST5501 Multi Purpose One Step...
I have an ariston 20/24 mffi combi pressure rises when switched to central heating but pressure ok when asking for hot water ? expansion vessel ?
over heat limit stat on central heating circuit ? if hot water is ok and hot to temp when run for 5 minutes the expansion vessel is doing its job.remember hot water is the maximum demand for any boiler ,,heating is secondry?once you establish hot water at maximum rate then the only real problem is on you demand for heating??
Dec 10, 2012 | Water Heaters
Ariston GL6+ Occasional rusty water. Can this be remedied? Thank you Ed
Ariston GL6 6-gallon electric water heater has anode rod to prevent steel tank from rusting.
Once anode rod depletes, the tank rusts.
All tank-type water heaters have replaceable anode rod that can stop rusting, but will not repair damaged tank.
Open following links for resources + manual with parts number and illustration on page 7 and 10. Part number is shown as 570241 anode rod.
Jul 12, 2011 | Bosch Ariston GL6-plus GL6+ Point-of-Use...
Ariston ACO MFFI 35 E34 fault code present
This is the manual for your boiler. I hope the information contained in the manual will help you identify your problem.
Mar 30, 2009 | Water Heaters
Pilot light on boiler
The plumbers repair should be guaranteed, give him a call back.
It sounds to me that the pilot flame needs to be adjusted or the thermocouple is not aligned properly or there is a draft that is blowing out the pilot.
Good luck...
Feb 22, 2009 | Water Heaters
Boiler problems
heres a copy of the serviceing manuel for the unit. just click on the link and download the manual. good luck
Jan 11, 2009 | Water Heaters
Moved in house Monday & have a radiator leak due to bad rust...what's best temporary repair to hold for a few weeks b4 plumber available? What sort of Boiler is Ariston Genus 24 mffi ?
turn both valves off at each side of radiator and once the pressure balances it will stop leaking, there is no solution to this whilst using this as a radiator to heat the space, but will stop the leak.
Dec 24, 2008 | Water Heaters
Water Heaters Logo
290 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
