Question about ASUS A8N-E Motherboard
CPU fan fail or speed too low
Hi! There are a few days that my computer is not working properly... When I turn on my computer I used to get a warning message "chipset fan fail or speed too low". Opened the sides, cleaned the fans and turned it on. The first time I turned it on it was working correctly, the second time I got a message "CPU fan fail or speed to low" Opened the sides again, cleaned it once more, turned it back on...same problem. I made a research oven the net and found that the CPU fan needs to be replaced as soon as we purchase the product, well I didn't (and I already have it a year)! Now, my computer is not as noisy as it was before but all fans are working properly as I checked in the BIOS. My motherboard is an ASUS A8N-E one. By the way, on the device manager I have a question mark under PCI bridge and the whole section of "other devices" in general has question marks. How can I fix them? Thank you in advance.
  • just_godlike Sep 20, 2008
    When i start my computer, it starts beeping and a message "CPU Fan speed too low" appears. If i restart it, the error does not show, but after few hours being off, the message appears again. I tried to enter BIOS and disable the warning, but i cant find where is it. Need help.
  • Anonymous Nov 23, 2008
    me too
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 9 Answers
I bought the same motherboard this past year (used) and installed it with AMD Athlon 64 fx-57, Antec P180 case, 550 w power supply. I had the case cover off to check the fans when I first fired it up. The AMD oem cpu fan hesitated at power on for a few seconds, which worried me. It started spinning normally and I then shut the system down and waited a few minutes before restarting it. It spinned up fine so I put the cover back on. I started getting the same error you mentioned, so I updated the BIOS to 1013 version. That didn't solve the problem. I ended up disabling the warning in the BIOS as I got tired of seeing it, as I could see the fans were all spinning and the CPU temperature was at about 26 to 34 on cold boot.
I recently checked on this problem and seems many others with this board have this problem. One fellow said he mailed off a question the the problem to ASUStek and they replied that it is just a glitch, that the fan is "smarter" than the BIOS, as it will hesitate to spin fully at start up if the CPU is cool. The suggestion was to disable "Q Fan Controller" in BIOS. I did and don't get that warning.
As for the yellow question marks under manage in Windows, you need to install the drivers for all of those devices, and they will be on the disk that came with the motherboard. I use the latest drivers from the ASUS site, but the only one I couldn't install was the ACPI ATK 0110 Virtual Device that came out in 2007. When I try to unpack the .rar file it says Corrupt Headers and refuses to use the driver from that file. So, I use the driver from the disk.
Posted on Oct 19, 2008
    President:
  • 2,961 Answers
The pci bridge refers to the pci slot controller, which is the white slots that are used to fit cards like modems, firewire cards, usb cards and soundcards. Your motherboard cannot recognise these as all the drivers for the motherboard must be re installed. All the other devices that are not recognised by way of '!' and '?' marks are probably using the pci slots but are unable to works as the pci slots are not controlled. You can download all driver for your motherboard here http://support.asus.com/download/download.aspx?SLanguage=en-us
Posted on Apr 13, 2007
    Brigadier General:
  • 6,966 Answers
Hi, on the CPU fan issue maybe you want to try to revive it. Unplug your PC, You may have to lay it down on its side. Remove the cover to expose the motherboard. Remove the 4 screws holding the fan on top of the heatsink in place. For convenience you can remove the three wire terminal connected to the mb. Working on the fan, use a clean paint brush to remove dust and accumulated grime and dirt. clean as much as possible. underneath the fan is a paper sticker, scrape it off. beneath that is a spindle about the size of a matchstick. if you turn the fan blades, it also turns. put a few drops of oil such as WD40 to clean and lubricate the spindle and bearings. you may have to slightly push the fan in and out to force the oil deepers inside. add soon as the level goes down. sometimes, the spindle/bearing is not immediately seen. it may be covered by a rubber seal which you canpry off. thereafter, proceed with the oiling proces. Reassemble back and screw in place. Hoe this works out for you. Regards
    New Friend:
In Asus bios in Power tab at Harware Monitoring u have the option to set the minimum cpu fan RPM when cpu is cool. if u didnt change it then its set at 20%. try put it at 30%. this might also help.
i have fan issues too once in a while with an Asus p5ld2 moba with intel dual core on it. the fan was starting at very low rpm like about 930-950 RPM and everything was indeed pretty cool, no heat but was making noise.
ennoying:D
Posted on Jan 12, 2013
This problem is caused because you have enabled the option "Auto Fan Speed" and "Enable CPU low speed advice". When you turn on your computer in most cases the CPU fan turns on for a while, and before the boot beep it stops. This will happen when the case is cool, then, the message of the low speed CPU fan appears. To be sure that is what i'm saying try to run for 20 o 30 minutes the pc and then reboot it. If this message does not appear this is the problem. The possible solution is that you can get inside the bios and dissable the option of low speed CPU warning or somthing similar, or you could also try to disable the option of auto speed CPU fan. I hope this could help you.
Posted on May 12, 2007
How to solve CPU fan not connected
Posted on Dec 16, 2009
Fan slow down and them high speed
change the fan ASAP, since the zooming noise and the slow performance will affect even the processor and you might end up replacing the processor as well if it persists. So get the fan ASAP and problem will be solved.
Sep 30, 2013 | Gateway GT5622 PC Desktop
Overheating issues with laptop
Following are the reasons for overheating, just take care of these things::
Stop Overclocking your CPU
Make sure your Heat Sink is placed properly above the processor
Clean the Processor fan, Heat Sink and other peripherals
Use High Speed fans
Use CPU Heat Sink Paste in the processor
Make sure your dint restrict the speed of CPU fan.
Use proper ventilation in your room
Shut down your computer at least two hour a day
If it didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of overheating
Sep 23, 2013 | Toshiba Satellite Computers & Internet
PC won't start up
It may be worth trying to re apply the thermal paste to the processor, make sure you remove power from the machine before you open it up. The CPU may have failed, but they don't fail very often, so try the paste first, it will only cost a few GBP for a couple of applications.
Sep 23, 2013 | Sony VAIO VGC-RB34G PC Desktop
Laptop lgr40
1. Stop Overclocking your CPU
2. Make sure your Heat Sink is placed properly above the processor
3. Clean the Processor fan, Heat Sink and other peripherals
4. Use High Speed fans
5. Use CPU Heat Sink Paste in the processor
6. Make sure your dint restrict the speed of CPU fan.
7. Use Additional Cooling Units
8. Check your SMPS
9. Use proper ventilation in your room
10. Shut down your computer at least two hour a day
Let me know if it helps you.
Use system utility tool like RegInOut to remove unwanted files , fix registry and windows errors which cause of heat problems
Jul 03, 2013 | Computers & Internet
My computer is beeping every so often it beeps about 3 times and it does it fast please tell me why
It only mens that there's an error on your computer.
Beep codes are use to check or identify which computer part/s causing the problem.
Beeps
Error Message
Description
1long, 2 short Video adapter error Either video adapter is bad or is not seated properly. Also, check to ensure the monitor cable is connected properly. Repeating (endless loop) Memory error Check for improperly seated or missing memory. 1long, 3short No video card or bad video RAM Reseat or replace the video card. High frequency beeeps while running Overheated CPU Check the CPU fan for proper operation. Check the case for proper air flow. Repeating High/Low CPU Either the CPU is not seated properly or the CPU is damaged. May also be due to excess heat. Check the CPU fan or BIOS settings for proper fan speed.
May 11, 2011 | Toshiba Computers & Internet
Why does a fan keep turning on and off every few seconds
Hi!
Usually what you'll find is that the fan will turn on and off as the computer heats up and cools down. The fact that it turns on and off every few seconds could imply that either: a) Your computer heats up and cools down very often (not likely) b) Something is causing your computer to not sense the correct heat c) There is something impeding your fan from working properly (most likely).
I would recommend using an air duster to blow all of the dust out of the fan area and see if that improves anything.
Additionally, you can download free software which will monitor your CPU temperature, and that should let you know if you're within a reasonable range (Google for specific numbers).
Good luck! -SJ
Mar 03, 2011 | HP Pavilion A250n (DF253A#ABA) PC Desktop
When turn on my computer after a seconds the system is shutting down.. i don't know what to do, is there a problem with the processor?
A overheating CPU will shutdown and won't start up again until the CPU has cooled down.
The overheating problem (ie. thermal shutdown) is most likely caused by a faulty CPU fan or dust clogging the CPU fan and heatsink.
Check the BIOS CPU fan speed could be set too low, check the fan speed/temperature setting.
If this problem is not fixed, then the CPU will eventually fail.
Check the fan to see if it spins freely, if not then replace the faulty fan.
If the fan and heatsink are cligged with dust, loosen and remove the dust and use a can of compress air to blow away the dust.
Sep 22, 2010 | Computers & Internet
Cpu fan noisy/chip fan fail error messages
pils,
Yes. This sounds like a fan issue. The noise often comes from bearings failing within the fan. Also, a failing bearing can make things harder on the motor as it brings the fan up to speed. This is likely the reason that you see increased warnings during the fan speed check while booting because it comes to speed more slowly as bearing wear increases.
I give this a 90% chance that your CPU fan is causing the issue. Since a decent CPU fan will cost you ~$20 online, it's not much out of your pocket if you happen to uncover another culprit.
I'll keep an eye on this post. Let me know how things go.
Apr 03, 2008 | ASUS A8N-E Motherboard
Trouble shooting
OC failure = over clocking failure. Make sure the CPU fan is clean, free from dirt & dust. Check CPU fan plug is connected correctly. If the CPU fan still stops after a few seconds replace the CPU fan.
It's harder to find just a fan to fit your heatsink, which sits on your CPU. It is easier to find a new heatsink \ fan combo for your Intel. Use your manual to find what Intel chip is on your board. Use that information & search google for a heatsink & fan combo. Pay close attention to how your current heatsink is mounted to the Gigabyte board.
Mike
Mar 24, 2008 | Computers & Internet
Processor over heating
This is normal behavior. Fans normally only run when they are needed, and your computer has multiple temperature sensors that direct this behavior (they are primarily located on the CPU, which could explain why the fans all worked when you took the CPU out). You should only be concerned about the fans stopping if your computer is, indeed, overheating.
Nov 14, 2007 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
ASUS A8N-E Motherboard Logo
14,347 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
