Question about Intel D101GGC Motherboard
System wil get stuck 2min after starting the system in desktop
Motherboard is intel D101ggc , processor is intel p4 2.66ghz, ram is 1gb ddr and 128mb pci express 16 graphics card.graphics card is from nvidia. if there is problem in motherboard please suggest me a good substitute for it.
  • 1 more comment
  • Anonymous Feb 10, 2009
    I have the same problem. Intel sent me 2 replacement motherboards and 1 replacement D945 3.4 dc processor. I have changed heat sink, memory, hard drive and nothing works. All parts work when installed separately on other computers. It worked well for 15 months with XP Pro, then I switched to Vista.....
  • Dick
    Dick May 11, 2010
    Any update to your issue yet?
  • Dick
    Dick May 11, 2010
    Is this a new setup? Are you overclocked? Do you have the latest drivers installed? Have you changed the bios settings for maximum compatibility?
    President:
  • 1,223 Answers
It can be RAM or the VGA try them both
Posted on Mar 07, 2009
Emachines t3516a memory upgrade
The eMachines T3516 uses an Intel D101GGC motherboard,
http://www.ascendtech.us/intel-d101ggc-lga775-800fsb-motherboard_i_mb4intd101ggc.aspx
Two Ram Memory slots.
Maximum Amount for EACH ram memory slot is 1GB.
Maximum TOTAL Amount for the motherboard is 2GB.
Ram Memory used is DDR Sdram at 333MegaHertz, or 400MHz.
That is PC-2700 and PC-3200 respectively.
Uses Non-ECC, low density, Unbuffered, CAS Latency of 2.5, and 2.5 Volt.
Regards,
joecoolvette
Oct 01, 2012 | E-Machines T5082 PC Desktop
My PC has D101 GGC INTEL motherboard, and 2.66GHz Intel P4 processor and DDR SDRAM 1GB. My system starts but hangs very frequently and is extremely slow. Sometimes it doesnt boot and usually takes very...
when booting long press the delete button to enter bios, when your in, select the boot section and disable quick boot, then save and reboot, bios will check the memory or ram of your desktop.
after the test when the system reboot the same and didn't said ram fail or test fail the ram is working good.
now I'm sure that your running out of memory or lack of memory,
try to clean up your disk or delete unused files, or update the memory
probably your ram is ddr 1 pc333/400
Mar 21, 2011 | Intel D101GGC Motherboard
I have a intel 845GL motherboard with 1.7Ghz
2 x 184-pin DDR DIMM socket support up to 2 GB
recommended: 1GB x 2 DDR 333
http://www.svbinternational.com/motherboards/motherboard_845_chipset.htm
contact ur system admin/vendor for more details....
Nov 02, 2009 | Computers & Internet
Finding Intel 845GVSR & 915GLVG Compatible Motherboard & Proc
you can use intel dg41 mbd , dualcore processor,1 gb ram,160 gb hdd or use intel atom for support contact 91-9645071021
Aug 11, 2009 | Intel D845GVSR Motherboard
Does my computer compatible to upgrade RAM?
Yes. It should easily adapt a 1GB Ram. The 32bit processors can genarally take upto 3GB of RAM
Feb 22, 2009 | E-Machines eMachines Desktop PC
Vista compatiable
intel doesnt list any vista drivers for that motherboard on there site so you might run into problems with the intergraded devices such as the ethernet,audio,chipset, & any intergraded video
You might be able to use the xp drivers but if theres problems it wouldnt be supported by intel
Nov 26, 2008 | Intel D101GGC Motherboard
Vista
hi!!
yes!! if you update
try to update your driver
download the latest driver
click the link below
http://www.intel.com/support/motherboards/desktop/d101ggc/
Nov 20, 2008 | Intel D101GGC Motherboard
IS DDR SDRAM IS DDR II RAM OR DDR
No. DDR replaced the SD in RAM so SDRAM and DDR RAM are two completely different things but each ram type has its own frequency hence you get SDRAM 100(mhz) and SDRAM 133(Mhz) just like you get DDR 1 RAM at 266(mhz) and 400(mhz) and DDR 2 RAM at 533(mhz) and 800(mhz). Therefore as you can see how these things differ, but if your mboard takes SDRAM that it can take and frequency of SDRAM but you must ensure that all the frequencies of all your RAM modules in all your slots correspond otherwise you will have problems, meaning that if you decide to use 133mhz RAM then all your RAM modules that you use must be the same. Let me know how you go. thanks
regards
Feb 06, 2008 | Intel D101GGC Motherboard
Intel D101GGC Motherboard Logo
119 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
