Question about Nintendo Pokemon Emerald for Game Boy Advance
Problem in mirage tower
How can i cross the cracks in the mirage tower?
i keep on falling.
Now, don't you worry.
I have a solution for you, go to Mauville city and take a mach bike. Take the bike and ride on the crack but make sure that you don't ride on it more then once.
Posted on Dec 25, 2008
How to Get Crackdown Achievements Easily?
    -Complete game
    -Go to the ***-Gen's second tower with lift
    -At the top trash the place then pick up a monitor and throw it from top of tower
    -Get achievement
    -To get your first code ever found hold down RB RT LB UP on d-pad and X
    -Free fall glitch go back to the ***-Gen's second tower, trash it and pick something up but don't move and he will look like he is falling
Oct 20, 2016 | Video Game Consoles & Games
Why does Frigidaire tower assembly get stuck in lower dish rack?
It could be cracked or warped. they are not expensive and easy to replace.
Oct 06, 2014 | Dishwashers
2007 ignition coil keeps cracking
The crack you refer to is a carbon track laid down by the high tension spark jumping to earth from the coil tower, caused by a damp atmosphere and a bad insulator on the king lead, the carbon track can be scratched out or filed off and then coated with ladies nail polish, problem solved till the next time! Could try a coil cover, if you can't get hold of one, get a rubber glove and cut one of the fingers down to make a tight fit round the lead, then tape the glove over the coil tower. (that's a trick that works in rainy Manchester UK)
Jan 08, 2014 | 1997 Dodge Intrepid
I have a 1990 f150 300, 6 5 speed. The shift tower turns in place is there a key lock or key way that holds it in place?
there is a pin on bottom of shifter that has sheered, or the plastic ball it sets in has cracked, Id just go to local junk yard and get a used shifter to repair it, and can be changed in minutes
Jun 10, 2010 | 1990 Ford F150
In summer y? looking that a water fall on road?
This is due to mirage effect, it is most common in desert where traveler get the wrong feel of oasis, but actually that is due to mirage effect.
Mirage is formed because air with less temperature having greater refractive index than the air with higher temperature, as light passes faster in warm ,less dense air than dense, cold air. The rays get diverted and band when passing from cold to the hot and vice versa By this phenomena, we get the mirage effect and illusion of water on road or desert is generated
Feb 25, 2010 | Ectaco English-Hindi Language Teacher...
REPLACE SPARK PLUGS ON MY 99 MIRAGE AND IT RAN PERFECT FOR A WHILE THEN IT STARTED PUTTIN AND SPITTING BLACK SMOKE FROM THE EXHAUST...WHAT COULD THAT BE?
if you have replaced the spark plugs yourself you may have cracked the ceramic on a plug... this will cause a misfire, remove all the plugs and check them very carefuly for cracks etc.. and carefuly replace them but dont drop them into the holes and dont overtighten them and start them with your hands before useing a ratchet.
Feb 10, 2010 | 1999 Mitsubishi Mirage
95 Impalla wont start when it rains
clean and spray all ignition plugs will busty penatration oil , check all body gounds for good contact , clean if signs of rust should help
Jan 20, 2010 | 1995 Chevrolet Impala
Electrical Problem With My 2002 Mitsubishi Mirage.
have the altanator tested with the lights wipers radio all on it is probably weak tighten belts if not cracked if cracked replace. see the regulator is probably bad it controls how much amps and voltage the alternater puts out thats why i put out first thing to do. its very important to have a good connection at battery no corrosion and good terminals not cracked or broken if in doubt replace them 3.00 to buy
Oct 19, 2009 | 2002 Mitsubishi Mirage
What cracks? I can help, I just need to know more about your problem.
Dec 24, 2008 | Nintendo Pokemon Emerald for Game Boy...
Manifold mirage 1998
I had the same problem and welded mine back together. It is running like brand new again. I can do this for yours as well. Please send me picks of the manifold (w/ cracks) and I will let you know a price. christian_brennan at yahoo dot com.
Sep 25, 2008 | 1998 Mitsubishi Mirage
Nintendo Pokemon Emerald for Game Boy Advance Logo
118 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
