Question about HP Photosmart C3180 All-In-One InkJet Printer
Hp C3180 printer prints test page every time i turn it on
My HP C3180 printer wasn't working for a while, i JUST fixed it finally... and now it works, BUT every time i turn it on it automatically prints a test page... it takes forever, lots of lines and dots and bird pictures down the page....... how can i get it to stop doing this?
thanks!!!
  • Anonymous Dec 28, 2008
    I have the same problem with my printer.  Every time I turn it on, it prints a test page, wasting a lot of ink.  It grabs multiple sheets from time to time.  It also tends to jam quite easily, making it the most frustrating printer that I've ever owned.  I will never buy HP again.  I wouldn't even take one from someone.
You were being cheap when you ran out of ink and replaced only the Black Ink Cartridge.
Replace the Color Cartridge and the test page will stop printing when you turn it on.
Posted on Apr 13, 2009
  • roxy_music Jun 25, 2011
    This does work! And i have tryed everything,
None of the solutions I read here helped until I found this solution and it worked:
I suspect the page is a calibration page. If so you need to allow it to print and then place it face down on the scanner bed and press the scan button, the printer will then complete the calibration and you should not have to do this again until the next time you replace a cartridge.
Note that if either cartridge is not printing correctly the calibration may fail so you need to have good working cartridges for the process to complete.
Posted on Dec 02, 2009
  • 827 Answers
Hi Marin,
It wants you to verify that the test page was successful.
Maybe uninstall and reinstall the software, and when it does the initial test page process, it should ask you to tick a box or something to verify that the printing alignment was successful.
Try that.
Here's the user manual for future reference:
http://static.tigerdirect.com/pdf/HP_Photosmart_c3180_UsersGuide.pdf
Good luck :)
Season's Greetings!
Chris (ziraffa)
Posted on Dec 24, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
There isn't a solution. When the printer starts printing a test page evertime, placing the page in the scanner and doing another scan will have no effect. HP designers spend too much time drinking coffee and not enough time listening to customers. An alignment is totally unecessary anyway. Sorry, there should be an override but there isn't
Posted on May 21, 2012
Test page prints each time the printer is turned on
every time i turn on the printer it goes though the test mode. does not have to be connected to the computer. c3180
Feb 13, 2011 | HP Photosmart C3180 All-In-One InkJet...
Region codes for France for a photosmart c3180 all in one
Well I had the exact same problem with a C3180 bought in the USA and I moved to France. I called the HP tech support and after I bought 5 brand new cartridges upon their recommendation we haven't been able to print the 10 tap test page
I recommend that you try doing that before you call them otherwise you will be wasting your time
To print the 10 tap test page you need to press simultaneously CANCEL and START COLOR COPY. I couldn't print the 10 tap test page because the printer will not recognize the cartridges bought in France (START COLOR COPY and START BLACK COPY blinking + E in front of COPIES)
If somebody knows an alternate method to print the 10 tap test page, please share it as this is the blocking point with HP support
Thanks
Feb 10, 2010 | HP Photosmart C3180 All-In-One InkJet...
Test page prints every time I turn printer on
Maxkath,
Rather than retype something that has already been typed, I've copied the link to the knowledge base article below.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01336397&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
~Dave
Nov 18, 2009 | HP Photosmart C3180 All-In-One InkJet...
Everytime I turn my HP PhotosmartC3180 on, it prints a test page.
I think probably it's a print alignment page, if you read the page it will probably give you instructions to place the page on to the scanner at the top and press a button for it to scan and automatically set the alignment. Do so and it should fix it :)
Aug 04, 2009 | HP PSC 1315 All-In-One InkJet Printer
How do I deselect "print a diagnostic
you need to calibrate print head, look up to your manual, or try to place the printed test page in the scanner printed side down and hold scan button, after scan, problem should be solved
Jul 10, 2009 | HP Photosmart C3180 All-In-One InkJet...
My printer keeps printing the test page every time it's switched on
Unplug the printer and leave it for three minutes and then plug it back in. This will reboot it and it may cure the problem.
Feb 05, 2009 | HP Photosmart C3180 All-In-One InkJet...
I had the same problem and it was driving me crazy until I did this. Please follow exactly and IN ORDER.
1. Turn off the printer and wait 10 seconds. Turn it on again
2. Let the printer print the test page.
3. After the test page is printed, disconnect the USB cable connecting the printer to your computer. DO NOT turn off the printer while disconnecting the USB cable.
4. Place the test page on the scanner glass and press the SCAN button on the printer. The ON light will flash as the page is being scanned.
5. Remove the test page when the ON light is steady.
6. Finally, turn off the printer and wait another 10 seconds. Then turn it on again. No more printing test pages! Yay!
(You may now reconnect the printer to your computer via the USB cable.)
Dec 23, 2006 | HP PSC 1315 All-In-One InkJet Printer
HP Photosmart C3180 All-In-One InkJet Printer Logo
4,233 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
