Question about Refrigerators
The freezer is working but the ref is not
I am in the philippines and 2 different mecanic could not identify the problem. When the unit is disconnected for 12 H.or more and plugged on again the ref start working good for 2 to 5 days and then the ref stops again. This happened several times .same ice was find between the coils and when dissolved the ref was working again. A mechanic changed the thermostat ,but it did not solved the problem. I am a senior citizen and in this very hot wheather the ref is vital for me and also to keep my medication cool . Please help and advice. Thank you .
    Problem Solver:
  • 6 Answers
Dani, your defrost system is not working. Call the mechanic back and tell him to go through the defrost cycle. Since you have this listed as a generic problem, I can only tell you what to look for. You are going to have a defrost timer, either adaptive or mechanical. A bi-metal and a heater. He needs to put the refer into defrost and go from there. Tell him to ohm out the heating element on the evaporator to see if it is good. If that's good, then he needs to see if it is getting voltage while in defrost. If it's not getting voltage, its either the bi-metal or the defrost timer. Simple process of elimination. If the bi-metal checks out, then it's the defrost timer. If he charged you for changing out the thermostat, tell him to apply the wrong diagnosis to the right solution. Tenbears. If its a GE, let us know because you have a whole differnt ballgame there.
Posted on Dec 24, 2008
Freezer is cold but food isn't frozen
Deforst freezer and ref. wipe dry. Reset controls to starting point.
Check temp. 0 in fez. 38-40 in ref. keep advancing settings until you reach temp. Also, vaccum behind unit
May 02, 2014 | Amana 22.6 cu. ft. Side-By-Side...
I have a Kenmore fridge with the freezer on the bottom model # 52600. What is happening is the fridge is not cooling but the freezer works.If you have any suggestion please e-mail me. thanks
if the freezer is ok,the damper of the ref side is close need to adjust or replace,2 is the sensor is the sensor is defective the ref side not cooling even the sensor of freezer side if defective may cause why not cooling in ref side,its hard explain to remove or to check the unit by its your self,much better call an service technician to check what the exactly coz why not cooling,and you get a warranty for the service compare you buy a part,but you dont know what how to test the part if is ok or not.
Jan 01, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
We have new Kenmore ref. We run both ref.and freezer on # 3 have home on 77 It appears my Ref. runs too much it stays on like 17 min and off 23 min My old ref did not run this much .Is there something...
Ted, there may be a difference between the two systems as you have observed. The designs are different from refrigerator to refrigerator and with the Kenmore, you're also dealing with multiple manufacturers. So, you can have a LG, Whirlpool, Frigidaire, Maytag, Samsung, etc. Kenmore doesn't manufacture any major appliances - they just stick their label on the front. I would keep an eye on it but the main thing is the temperature regulation. If it's regulating at the proper temperature I wouldn't worry about it.
Rich
Western Appliance Repair
Appliance Repair Meridian
Sep 30, 2010 | Kenmore Refrigerators
Freezer not working but refrigerator is...I smelled wires getting hot and unplugged the whole unit and waited about 30 minutes then plugged it back in and noticed the next morning that the refrigerator was...
refrigerator can not work unless freezer does / as the ref get's it cold form the freezer in 99 % of all f-ref units . so the burning smell may have been the def heater's look for frost build in back of freezer and possible a evap fan failure . / make sure the fan in freezer is woking .. mm
Jul 03, 2010 | Refrigerators
Fridge freezing everything
THIS REF. WORKS BEST WITH THE REF. SET ON 4 OR 5 AND THE FREEZER AT 2 1/2 OR 3. HAVING A HIGH FREEZER TEMPATURE CAN HAVE FREEZING IN THE BOTTOM DRAWER OF TH REF. MAINLY BECAUSE OF THE RETURN AIR VENT TO THE FREZER IS BEHIND THAT DRAWER.
Apr 25, 2010 | Maytag 21.9 Cu. Ft. Bottom-Mount...
Gladiator ref is not cooling properly
Check to see if there is cold air coming from the freezer to the refridgerator side through the vent holes The compressor maybe getting weak or the freon charge maybe low. Does the unit run a long time before it shuts off? 50 degrees is not cold enough for a freezer. You should be around 32 or less.
John
Sep 28, 2009 | Gladiator Freezer GAFZ21XXRK
GE side by side refrigerator. Fridge side not cooling - help!
Hi, they have changed lots of parts, were they defected, did they tested parts for faults or they just change parts, because it's available, there's always a reason why a certain part, go bad. so far you change most of parts in ref. check refrigerant (gas, freon) pressure, check compressor, for faulty suction and high side valve, it's possible your compressor loosing efficiency. or say if compressor normally pump 50 psi. now it's pumping 40 psi. is the refrigeration cycle balance ? is there restriction in your ref. system? is compressor running long enough? plug on ref. let it run for 1hr, listen to compressor for any clicking sound, fans and everything else could be working, be compressor not, compressor could be short cycling (not working long enough) also check voltage in receptacle(outlet) with digital multi-tester, get accurate voltage reading, let me know, could also be a faulty circuit breaker in house (building) not your ref. let me know, system could have very slow refrigerant leak, you could have a very small (slow) gas leak, that's why your refrigerator get hot first, then your freezer, there's a condensate line (loop) that passes through, ref body, close to doors to prevent door gasket from freezing, after few years sometimes develope leaks, cause by rusting. it's very possible there could be small leak in your system. let me know what happened.good luck.
Aug 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge part not working on Whirlpool Arc 7050 Fridge Freezer
If this is correct:
1. No ice build up on back of freezer wall.
2. Fan in freezer is working.
3. Items in freezer are frozen, ice cream is a good test.
Then:
Why is the cold air in the freezer not getting over to the Ref. side?
1. There is a channel (tunnel) from the freezer to the Ref, side and there is a door which regulates how much cold air from the freezer goes through to the Ref. side.
2. The control panel may have it labeled as "Freezer" setting, from cold to coldest. The coldest setting means the door is almost closed and will keep most of the cold air in the freezer.
3. Since your control panel is not working then this door must be almost closed keeping all or most of the cold air in the freezer.
Any service tech should be able to check the control panel and find the problem.
Jan 25, 2009 | Refrigerators
Ge profile buttom freezer cold refrigerator hot
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is that cold air not getting over to the Ref side?
1. The little door is not open.
check your control setting. You should be able to feel air coming through the channel on the Ref side.
2. The fan in the freezer is not working.
You can hear this fan running when you open the freezer.
3. The coils on the freezer side are clogged with ice which won't let the fan circulate the air over to the Ref side.
This is a failure of the defrost system.
Dec 17, 2008 | GE Profile Arctica Stainless Steel Top...
Refrigerators Logo
67 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
