Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Microphone Problem My problem is, I cannot use a microphone on my PC. I tried one belonging to a friend. I inserted it into the pink holder at the back of the PC. but nothing happens. Should I have a certain card installed or what. On Users Manual P64 you give a description on No 7. What do I do.
  • dustdevil Apr 06, 2008
    insprion 1600
    Trying to Skype, I can hear the person I am calling, they can not hear me. My mic is turned off and how do I get it back on?
  • 247 Answers
The pink socket on the back of the pc is almost certainly a part of the special card you thought you might need, so probably no need to go out and buy new hardware. Usual cause of this sort of problem is in the pc settings. Open "volume control" on the computer (right click the system tray icon, and select "open volume controls" on older Windows versions, pick it up off Start_Programmes_Accessories_Entertainment on newer versions) and check that the microphone level is turned up far enough, and is either "enabled" or "not muted" (be a little careful, as the playback and recording levels and muting are controlled on separate screens - you can switch between them using the properties box on the options menu). Hopefully this will get you going. A.
Posted on Apr 13, 2007
Microphone
on your computer, there is a pink colored jack that is situated at the back of your desktop or at the side of the laptop. That is for microphone use. If you have a microphone , try to connect on that port... Give us feedback if this helps....
May 09, 2010 | Computers & Internet
How do I plug my BA745 Boston speakers into a MAC desktop with one headphone outlet in the back?
I have the same speakers. It should have two plugs, one green and one pink. the pink plug is for a microphone. On the side of the speaker with the control knobs, you will find a headphone jack and a microphone jack. Unless you plan to plug a microphone into the pink microphone jack on the side of the speaker, you don't need to plug in the pink plug that goes to the PC. This is basically a microphone extension cord that runs through the speaker cord. That's all the pink plug is for. The green plug, on the other hand, is for your audio out. take the green plug and plug it into your computer's head phone outlet and you're good to go. You can use the speakers with any device that has a headphone jack. Just make sure you use the green plug, not the pink plug.
May 03, 2010 | Boston Acoustics BA745 Computer Speakers
I plugged my Microphone in the pink slot and it doesn't work on Vent, nor does my computer picks up the microphone
Make sure the Front Pink In is enabled.
Find the Volume icon in your Taskbar (little speaker, Right Click - Open Volume Control) or in Control Panel / Sound and Audio Devices. Find Device Volume / Advanced and uncheck the Front Pink In Mute box and slide the volume UP.
Mar 24, 2010 | Dynex Voice-Certified PC Desktop...
Where do I connect speaker to GX100?
Look at the "back" of the computer-casing.
Look for 3 similar holes (green, blue, and pink).
Insert your microphone into the PINK hole.
Insert your speaker-connector into the GREEN hole.
If you have a cassette-deck with "line-out" connectors,
connect it via the BLUE hole.
Nov 09, 2009 | Dell OptiPlex GX100 (GX100CEL500) PC...
Where do I plug in my microphone
I just borrowed this picture. Anyway, you plug the microphone jac on the PINK slot. Green is for the speakers or the sound output.
Aug 24, 2009 | HP Compaq dc7100 PC Desktop
My friends can't hear me, but i hear them.
Do you have a microphone attached to your PC? They won't be able to hear you if you do not have a microphone attached to the pink plug on the back of your computer.
May 21, 2009 | Logitech Webcam
Logitech microphone
have you checked the settings under control panel/sounds and audio devices?
open that up click the voice taband under voice recording press the volume button, check to see if the check box has a tick in it under microphone and that the volume is turned up. try the test hardware button to test your mic and adjust the levels from within the wizard.
hope this gets you headed in the right direction
Apr 23, 2009 | Computers & Internet
External Microphone - Not working
good day
have you tried inserting the microphone plug to the red/pink socket in your sound card?
Sep 20, 2008 | Compaq Presario 700 470024-192 Notebook
A4tech PK-7MAR
hello,
1. double click on volume icon on the lower right corner of your screen.
2. click on options, properties.
3. another sub window will appear.
4. in the box, look for mic volume and check on the box.
5. click ok after checking the box
6. another column should appear which is the mic volume. under the mic volume uncheck the mute box.
7. you should be able to use your mic now.
Note:
make sure you inserted the pink plug on the pink socket at the back of your computer.
Hope this post helps :)
Jul 02, 2008 | A4tech PK5
GE PC microphone with detachable laptop mic
On the back of your PC, there should be these colorful inputs. One is green, one is pink, and one is light blue. Plug it into the pink slot.
Apr 22, 2008 | GE HO97880 Consumer Microphone
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
231 people viewed this question
Clive
Clive
Alun Cox
