Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint wt960 lcd screen failure
I have a Hotpoint WT960 which is only about 2 years old. The LCD screen started flickering about 2 months ago and is now fading rapidly. Can this be fixed? The machine itself works fine but obviously once the screen fails I will have a problem. Any advice or suggestions would be apprciated.
  • Anonymous Apr 15, 2009
    where can i get the LCD part
    Scholar:
  • 86 Answers
Hi, I have experienced this problem on several hotpoint machines with led display's. There is really only one solution for it! If there are no wires hanging off then the answer is in the board, And you will need to replace it. It is a non servicable part and cost around £40.00+++.
Good luck.....
Posted on Dec 28, 2008
Can I fix a flickering band on VP2250wb?
It sounds like one of the backlights are going, or one of the inverter transformer and there are two capacitors near the inverter transformers that do give trouble. The monitor would need to be dismantled to investigate the problem and it will involve money, since it is four years old I would be inclined leave it alone until a new one is required.
Apr 15, 2012 | ViewSonic VP2250wb LCD Monitor
Hi..i am using compaq presario cq 40 and screen is flickering.i had it checked and they told me lcd is the problem but they didnt even bother to check.they just turned it on and they told me that i have to...
When it flickers, can you still see the text when the screen goes dark?
May have to use a bright flashlight set right on the display to see
the text on the screen beside where the light sits.
That will tell you if it's the backlight.
You can also look at a grazing angle into one of the edges to see if the
backlight is flickering when the display does.
When it's cold, does it start with a slight pinkish color? That can be
a sign of backlight going bad.
Anything interesting happen when you flex the cable by moving the screen?
I'm not saying it's impossible, but I've never seen software cause
consistent screen flicker. And if the vga port doesn't flicker, sw is
even less likely the problem.
If you bet the odds, you'd bet on a bad display cable.
Won't hurt to try replugging it.
If that doesn't help, then your monitor may be dying....
Jun 20, 2011 | Computers & Internet
I have used a new Samsung 932 GW monitor now for 11 months and so far there have been no problems until a day ago. The monitor image has become dulled and is flickering at a rapid rate which is literally...
Yous symptoms indicate a failing power supply. Since it is less that a year old you need to contact Samsung for a warranty replacement. The power supply can be repaired but if you open the case to do it then you void the warranty. If you need additional information about a repair please contact us at the email address below.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Dec 09, 2009 | Samsung SyncMaster 932GW LCD Monitor
The screen on my dell inspiron nootbook started flickering last month, two weeks ago it started to turn completely dark at times and today 3 min after i turned it on a blue screen popped up and it told me...
windows dose not control any flickering unless the driver is being updated if thats not the case your flourecent bulb might be getting old inside the lcd!
Aug 29, 2009 | Dell Inspiron 1525 Laptop
Polariod FLM-3232 Screen Flicker & High Pitch Squeal
replace all the capacitors in the power supply
board.you will see the capacitors bulge out on the tops.change all of them with a higher
voltage.
Aug 08, 2009 | Polaroid FLM-3232 Television
Razr inner screen fading, flickering
take the phone and have the LCD replaced on the phone.
Jun 27, 2008 | Motorola Mobility RAZR V3
Can see screen for one second
I had mine for almost 3 years and last month ran into the same problem and i take good care of it. I turn it on it stays on for a 1-3 sec and goes black. can't figure out what it is
Apr 19, 2007 | Liquid Video L17LCD2 17" Flat Panel LCD...
Hotpoint Ultima WF860 Front Load Washer Logo
1,473 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
