Trying to connect desk top computer and lap top computer
I have Att as internet server...I want to network by connecting the desk top and the lap top without purchasing additional this possible?
  • 8,637 Answers
There is only two ways to possibly connect both the desktop and the laptop in the network. That is to purchase a router so you can connect them both or a route with a wireless and then the laptop (Which most new ones have a wireless capability installed) can connect wireless from anywhere in the home. If you already have a Cable or DSL Modem it may have a wireless capability. Otherwise you would have to get a wireless modem. Hope this helps. Bud
Posted on Jan 06, 2009
I can't get my desk top to connect to internet it tells me my ip address is not right but my lap top goes through my desk top and i don't have any problems getting on line.
your dell needs a network adapter card or wireless card installed is that the case(look in b ack)
if no wireless, then it needs an ethernet cable plugged into modem/router from cin bell and then in back of dell
please advise your network configuration
May 28, 2012 | Dell Dimension E310 PC Desktop
My desk top will work with the router but the lap top which is wireless will not connect. the message I get is failure to establish a successful connection which my be due to poor signal strength or an...
You will need to check the wireless settings of the router.
If your network is secured then make sure that you are typing the correct network key.
also make sure that the DHCP server is enabled on the router.
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Nov 07, 2010 | Linksys Wireless-G WRT54G Router
No Internet via zoom X6 wireless router to desk top, lap top ok.
Access your zoom router by using the laptop which still has access to the router.
Your going to have to open your Wireless Network Connection Status window located under your network settings.
If you see this window your going to left click the (details) button
Now you should see a IP DNS server address
for example:
Type that address onto the address bar of your web browser.
it should take you to your router setup page.
There you will need to check if the lan port is enabled
Feb 04, 2010 | Zoom X6 Adsl Modem/router Rohs...
DIR 615 router. Host computer can not find network.
I dont know your router personally but what you need to do is setup a network bridgefull explanation is given here
Oct 27, 2009 | Computers & Internet
Go into network set up a shared Internet connection using ICS (Internet Connection Sharing) You can use Internet Connection Sharing (ICS) to share an Internet connection among two or more computers on a network. First, you need one computer, called the host computer, that is connected to the Internet and that has a separate connection to the other computers on your network. You enable ICS on the Internet connection. The other computers on your network then connect to the host computer, and from there to the Internet through the host computer's shared Internet connection.
If your computer is connected to a network, network policy settings might prevent you from completing these steps.
On the host computer (the computer whose Internet connection you plan to share):
  1. ? to open Network Connections.
  2. Right-click the connection that you want to share, and then click Properties.getcontent.aspx?assetid=18abb370-ac1e-4b6b-b663-e028a75bf05b&documentset=en-us&renderkey=signed1 If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Click the Sharing tab, and then select the Allow other network users to connect through this computer’s Internet connection check box.
Jul 22, 2009 | Computers & Internet
Can't connect to internet
check the IP settings, DNS server Settings etc any required, as well also do check if the network cable is propery conected and is working on an other system
if the router is connected to a modem then then connection from the modem is generally connected to the port named INTERNET in that case try connecting that to one of the ports numbered 1 to 4 and connect the systems to other ports
pls rate if it was any help
Jul 07, 2009 | Dell Inspiron 1525 Notebook
Although cable to desktop connects to internet, my router from desktop to laptop via router won't connect.
Desk top to internet is OK.
How about Destop through Router connection to Internet OK?
Assuming you want to connect wireless from Lap top to Network, need to configure correctly for wireless in Router.
If you connect Lap top to router by wire and it didn't work that mean your router is bad.
Jul 03, 2009 | Linksys WRT160N Wireless Router
Lan internet
the easiest way to setup internet on the laptop, is to go to control panel, and launch the network setup wizard. this will enable you to setup a new network, and scan for a local area network connection. this will also give you access to the troubleshooter. to solve any connection problems or issues, should there be any. If your using a wireless method. Your PC must also be able to transmit/receive wireless Signals. If hardwired you,ll have to use the network setup wizard, as this will auto determine I.P And any other DNS settings et,c.
Hope this Helps Mike @ compurepair.
Jan 14, 2009 | Toshiba Satellite Pro L300 Notebook
Linksys router vs. hp computer
First of all u should ensure that DHCP server is configured for your required number of computers. this problem seems that you have less clients configured in your DHCP server, existing in router configuration.
Dec 28, 2008 | Linksys Wireless-G WRT54G Router
I connect to wireless router but cannot connect to internet
can you connect to the internet if you use a ethernet cord to connect directly to the router?
If so , check the password you provided to connect to the network.
Aug 24, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
115 people viewed this question
