Question about Hotpoint BWM12 Front Load Washer
MY HOTPOINT BWM12 1200 SPIN WON'T DRAIN, - Hotpoint BWM12 Front Load Washer
  • Hotpoint Master
  • 3,463 Answers
You need to check and clean filter first.
You will find the filter is normally located behind a removable plastic cover at the front right side of the m/c.
Make sure the drain hose is not kinked or restricted..
Make sure you have not selected rinse hold..
Obviosly make sure pump is actually working.
Plz rate this solution .Thanks.
Posted on Dec 24, 2008
Washing machine won't empty making buzzing noise and coming up with f.05
looks like your drain filter is clogged. There could be cents, matches or something like that. All this stuff do not let to spin drain motor clearly.
Apr 13, 2013 | Washing Machines
Htwp1---mww top load won't drain or spin
Lidswitch is what I would say Based on your model number posted.
The liswitch has 2 wires. a green safety wire and two live wires. Bypass the lid switch by jumping the 2 live wires as seen in this video:
http://www.youtube.com/watch?feature=player_embedded&v=XAnQ6Ovvnuc
Nov 12, 2012 | Hotpoint Hot Point HTWP1000MWW Top Load...
My hotpoint 430 washing machine won't drain and very noisy when it spins.
first u check the water pump at the bottom side of the washer open it u will see a nub open it and u can also drain the water 4rm there but it will mess the floor up then if it continues contact ur engineer about the spin mayb the load in it is much or u set the washer balancing
Jul 26, 2011 | Tecnik TKL9260 Front Load Washer
What does f-5 mean when flashing at me and won,t let me have my washing out the machine also washing really hot after a fast spin programme
if water is in drum then door wont open,drop drain hose to floor level into bucket to drain manually, then check filter or pump is it running ok if not is it stuck some thing in it , hot wash is cold water inlet ok or is this due to again faulty pump ...
Jun 25, 2010 | Hotpoint Aquarius WD640 Front Load...
Will not go onto final spin on its own
check drain hose lid switch ....plugged pump or drain hose last timer
Aug 14, 2009 | Hotpoint WMA48 Front Load Washer
Should there be a ball in the drain hotpoint
yes the ball should be in there,but shouldnt cause you any major problems if removed.
Aug 03, 2009 | Hotpoint Aquarius WF220 Front Load Washer
My mothers Hotpoint WM 52P will not drain water out or spin???? Does this mean brushes??? poppywitch
no take the sump hose off from the tub off the machine and check for blockages the machine wont spin unless it can drain the water out
Jun 05, 2009 | Hotpoint Aquarius WF220 Front Load Washer
WM 22 will not spin
yes.dose it drain,see it must drain before it can spinso if water is standing in it it wont spin and that would mean your pump is ither blocked or reciving power but not working.
Jan 01, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Please help me with my washer
Hello browneyez070
Welcome,
You said, your Hotpoint top loader washing machine won't spin water out. Model VBXR1O6OVOWW?
Common causes before considering repairs.
Water won’t drain
Drain hose is kinked or
Improperly connected on it.
Solutions
• Top of drain outlet should be less than 8 ft. above floor.
• Straighten drain hose and make sure washer is not sitting
Let me know if these measures help.
Huuum
Oct 15, 2008 | Hotpoint VBXR1090B Top Load Washer
Hotpoint BWM12 Front Load Washer Logo
219 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
