Question about Huffy 16 In. Girls Dora The Explorer Single Speed Bike
Girls Huffy 16" bike - back wheel does not spin freely. It tightens up after a few spins.
  • 1,995 Answers
If the other side wheelnut is tighten mounted , Use on the other side to adjust a real cone wrench to fixate the pre-set cone without slack and mount the fixating small axle nut (but tight enough) against the pre-set cone. thats the problem because if this is not fixate it will allways become tight running after a few kilometers the rear wheel does not turn smoothly and your bearing can become damaged. rings and extra tight fixate of wheelnuts does not help without a cone wrench this problem cannot be solved. by wheels with coaster brake.
Posted on Mar 09, 2016
Try the bearings. Try a different wheel and rim. If its not the wheel then the crank bearings( ones the pedals are on) could be bad or the chain could be not set right.
Posted on Jan 02, 2009
Huffy 12' bike front wheel doesn't fit
Mine had the same problem and there was no way bending the fork was going to work. It turns out they had installed an extral washer and nut on the axel. Take one off and retry fitting it. It may only go on one way. Make sure, before you tighten it, that the wheel turns freely.
Dec 25, 2012 | Huffy Disney Princess 16 in. Girls Bicycle
Girls skeleanimal bike brake is stuck so back wheel won't move
It's a Huffy. 'Nuff said.
Manuals here - http://www.huffy.com/Support/OwnersManuals.aspx
If the cable isn't passing freely inside the cable housing it won't relax brake pressure when the lever is released.
http://www.parktool.com/blog/repair-help/linear-pull-brake-service-v-brake-type
Jun 19, 2011 | Schwinn 20 Inch Girls Starlet Bike
Hi, my daughter pricess bike won't ride. am not what is wrong. newly prchsed and assemble. please can you help?
will the pedals move forward? they should cause the chain to move and the crank in the back to cause the wheel to spin, if this isnt happening, look at the chain and make sure its correctly on both sprockets, if the pedals still wont spin, they may be too tight on the crank.
May 05, 2011 | Disney Princess 16" Girls Bike Huffy...
Will not go when pedaling does something got to be tighten
Actually, it would seem something needs to be dislodged from unwanted contact somewhere. LOOK at it. Do the wheels spin freely by hand? WE can't see it.
Mar 27, 2011 | Huffy 26 in. Cranbrook Cruiser Bike
Hello, I bought my little girl the huffy 12in disney princess bike (blue) already assembled from walmart. she tried to ride it today, but when she pedals the back wheel spins, but the training wheels and...
ONE AT A TIME, loosen the nuts securing the training wheels to the rear axle and slide each one upward a little bit so it float a little bit off the ground when the bike is vertical, then retighten the nut.
As she develops her handling and balance skills she'll need less help from the training wheel. So you can gradually raise them a bit higher as she masters balance and then she'll develop the 'lean' for turning. Ultimately, you remove them entirely.
I hope she's wearing a properly-fitted helmet.
http://www.nhtsa.gov/people/injury/pedbimot/bike/easystepsweb/index.htm
Jan 27, 2011 | Huffy 12 in. Girls Disney Princess Single...
Hand brakes are loose and need to be tightened so they will stop the bike. How do I tighten the hand brakes?
loosen the anchor bolt the hold both brake shoes against the wheel rim pull the cable tight and tighten the anchor bolt
Aug 07, 2010 | Huffy Disney Princess 16 in. Girls Bicycle
16" Girls Mongoose Pizazz Problem!!!
some bikes are like that. The rear wheel only spins with the pedals. Try pedaling backwards and see if the wheel goes back. If it does then that is normal.
Jul 13, 2009 | Mongoose Butterfly Summer 12" Girl's Bike
The handle bars is twisting around away from the front wheel
tighten up the castle nut that holds the wheel yoke to the frame.
Jun 19, 2009 | Huffy 16 in. Girls Disney Princess Single...
Rear wheel not running smoothly.
Thank you for using fixya, the problem that you are encountering may be attributed to the freewheel (rear) or the hub to axle assembly on both front and rear.
Im currently using a Haro Flightline and used a few. When this kind of problem occurs, you may want to focus on the following:
crank set: remove the chain and check if it rolls freely, if not, try to open the case and look out for broken ball bearings or misalligned parts, then lubricate it.
Rear wheel assembly: remove the chain and the whole assembly from the bike, then check if it rolls freely. If not, same method, check the bearings and the freewheel. allign and lubricate it.
Jan 04, 2009 | Huffy 12 in. Girls Disney Princess Single...
Childs 12 inch mongoose is new, but back wheel does not spin prop
The bikes are pre-assembled by a machine that overtightens the rear axle.  I had the same problem with my daugher's 12 inch huffy princess bike and my other duaghter's 16 inch Schwinn bike.  If you loosen the nuts on the back axle it fixes the problem.  I have read that the idea thing for these bike is to have them re-assembled and re-lubricated by a bike shop, but I thought this might cost as much as I paid for the bike.
Dec 14, 2008 | Mongoose Butterfly Summer 12" Girl's Bike
Huffy 16 In. Girls Dora The Explorer Single Speed Bike Logo
297 people viewed this question
Top Huffy Cycling Experts
Michial Gueffroy
Arturs Kalnins
Arturs Kalnins
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
