Question about InFocus LP 420 Multimedia Projector
I am unable to manually adjust the image size
When i go to the image menu - the box on the left side "auto image" does not highlight and I unbale to manually adjust the image to fit my screen - I looked in the user manual and it tells me how to do it - but not what to do if it is not highlighted
  • 2,237 Answers
Change the resolution first. drop it on the computer side and see if that does it.
Posted on Dec 29, 2009
How do I change the size picture it takes ?
While you're in LiveView or Playback, press the MENU/OK button. Use cursor-left/right to highlight the camera symbol. Use cursor-up/down to highlight image quality (mountain with three stars below) and press MENU/OK. Select the desired image size.
The above is from the "Using the Capture Menu" section of the user guide (page 17 in my copy). If you need the guide or other documentation, you can download them from here.
Oct 14, 2011 | Cameras
I am using a Fujifilm FinePix JX250 digital camera. Not the best I know to photograph jewelry but cannot afford a different camera now. After I've taken the picture I open it in IPhoto. I make...
The following will help to get the best possible pictures from your Fujifilm FinePix JX250:
TO CHANGE FILE SIZE:
  1. Press MENU/OK to display the shooting menu.
  2. Press the Selector UP or DOWN to highlight the option IMAGE SIZE and press the selector RIGHT to change IMAGE SIZE to 14M. This setting has a image resolution of 4,288x3,216.
  3. Press MENU/OK to select the highlighted option.
  4. Press DISP/BACK to exit from the menu.
TO CHANGE QUALITY:
  2. Press the Selector UP or DOWN to highlight the option IMAGE QUALITY and press the selector RIGHT to change IMAGE QUALITY to FINE (Less compression than NORMAL, meaning better picture quality).
NOTE: The focus range of the JX250 goes from 1.5 ft. - Infinity (Wide Angle), 2.6 ft. - Infinity (Telephoto), also make sure to clean the lens and adjust the focus before taking the photos. If the subject is close to the camera, select Macro mode. If the subject is far away from the camera, cancel Macro mode.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
May 28, 2011 | Cameras
My screen has shifted to the left and now I have a 2" black bar on the right side. How did this happen and how can I fix it?
I had a similar problem...actually I expect it is the same problem. It solved itself as follows.
Press the menu button on the monitor and a window listing operations appears. Select the sizing option with the up and down buttons next to the menu button. When highlighted press the select button which is iconed with an "i" and box/arrow. This provides another menu of which the uppermost choice is "auto adjust" select this with up and down arrows, if not already highlighted and press the select ("i" box/arrow) button. The window changes to auto adjust and and "OFF" or "ON" toggle option. Mine was in the off position, which is to say that "OFF" was highlighted. I changed it using the up and down arrows so that "ON" was highlighted, then pressed the select ( "i", box/arrow) button.
The image refitted itself to the screen. End of problem. My monitor is the 20 inch one. It is possible your menu might be different, but I suspect they are pretty much the same. Good luck.
Feb 20, 2011 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Image size
Press MENU/OK then use left/right to highlight the camera icon. Use up/down to select Image Quality (the two mountains icon). Your choices are 7MP, 5MP, 2MP, and VGA (0.3MP).
Jul 07, 2010 | HP PhotoSmart M627 Digital Camera
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
My westinghouse monitor won't align on the screen. i have tried auto adjust already and it is still missaligned.
Ok, with the Auto adjust, but have you actually tried the buttons that actually manually adjust the screen, size, placement, width, height etc, This will allow you complete control over all aspects of your monitor. You usually select, menu, then step through with one button, and change up, down, side to side, with the left & right buttons.
Mar 02, 2010 | Westinghouse 22" Widescreen LCD Flat Panel...
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
Picture size
This setup can be found in your manual that came with the tv on page 38
you may also download it at the following address for free.
http://media.onecall.com/Image_Products/Sharp/LC_GD6UManual.pdf
Digital Setup
This setting allows you to set the image of Digital
broadcasting.
Video Setup
You can adjust the settings for Digital image.
Screen Size
Set the format of image of Digital broadcasting.
1 Press MENU and the MENU screen displays.
2 Press < > to select “Digital Setup”.
3 Press ^ v to select “Video Setup”, and then
press ENTER.
4 Press ^ v to select “Screen Size”, and then
press ENTER.
Press < > to select “Manual” or “Auto”.
Manual is default auto is optional
since all tv channels do not broadcast in the same definition auto would be recommended
Selected item Description
Manual
Broadcasts in formats other than
480i will be converted and
displayed in the 1080i format.
With 480i broadcasts you can
change the screen size to the
size of your choice.
Auto.
All broadcasts will be converted
and displayed in the 1080i
format.
Nov 27, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Accessing Continuous Mode
Some details first...
  • The continous icon looks like multiple papers stacked on top of each other (in contrast the normal icon for single shot is a square box with an S in it so you can get it back to normal)
  • The camera takes shots at 1.5 frames per second, or about three frames every two seconds for image size of 2272x1704.
  • The shutter-release button has to be held down
  • Continuous is not available in HI image quality
  • Shooting will slow when memory buffer fills.
Setting to continuous...
  • Put your camera in P, S, A, or M mode.
    • I suggest P mode, this is for Program mode and does everything as Auto does, but allows you to override settings (except Aperture and Shutter).
  • Press the Menu button
  • Access the Continuous menu
  • Select the Continuous menu option, again looks like layered papers.
Please rate as FixYa! ThankYa!
Nov 04, 2007 | Nikon Coolpix 4500 Digital Camera
Taking a smaller image from S80
In picture-taking mode, hit the Func Set button. You will see menus of options along the left side and bottom of the display. Tap the bottom of the scroll ring (the ring around the Func Set button) until the bottom option of the left menu is highlighted in red. This option sets the image size of the pictures you are taking. Change this size by rotating the scroll wheel. The 5 options are Large, Medium1, Medium2, Medium3, and Small. The image size in pixels is displayed above the bottom menu as you switch between sizes. When finished, hit Func Set again.
Jun 25, 2007 | Canon PowerShot S80 Digital Camera
Open Questions:
ricoh aficio sp C232SF / c231sf When enabled, initializes but does not print Ricoh Aficio SP C232SF / c231sf The situation is. When enabled is initialized, writes that greeedy and is in readiness. No mechanism at this time does not work, except the scanner line. Scanning Starts, black and white is faster than the ruler, the color is slow. The document feeder works off a sheet and hands. After all the manipulations on the display Processig shines indefinitely no mechanism works until you press stop. The same situation when you try to print reports or when sending to print from a computer. the driver stood on the USB bus. Using command center see it all, but printing is also not achieved. Sees the tray and the presence of paper. Now this is the strange print though, and no, the black toner decreases. Already there was an inscription about it on the display and in commands the center shows the decrease in black. Only black. If you press for example copying, will stand and-writes about the heating of the stove no mechanical work and after a couple of seconds is ready. Stove at this time safely lying on the table next to the machine. the line Lamp is normal, but no power is supplied to it. The power supply did not find any problems. In the service you start the registration-work out the engines of development and tape, and a couple of auxiliary. Tried to make init EEPROMy, tried to rewrite the data in it, as if installing a new one-no changes Any ideas and assumptions are accepted And for dessert - a main Board, engine and the controller changed. The situation is quite similar. Sew and successfully both through the grid and through the USB port. I don't know where to look
Sep 23, 2018 | Ricoh Office Equipment & Supplies
See all InFocus LP 420 Multimedia Projector Questions
146 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
