Question about Polaroid i1035 Digital Camera
Is there a playback option on the i1035 and, if so, is it with sound?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 73 Answers
Yes, of course. Press the button bellow your zoom until it gets you to the play back mode (one click from picture mode) to see your pictures with included sound!
---John
Posted on Jan 03, 2009
No sound is coming out when usb is connected
Modern computers have various speaker options, much like amps. What you need to do is to find your actual speaker setup, and then place that as the default rather than the windows default.
Instructions for Windows 7, although others should be similar - Click on the windows start button (Lower left hand corner) - Control Panel - Sound (If you change your 'view by' option to small/large icon, you'll find this easier) - Playback tab
Here you will notice a color meter beside different speaker output options. One will be active when you play music, but no sound will come out as your speakers aren't actually connected physically to that device. You have two options here.
1) Easiest, but may cause problems in future if you change your speakers - Double click on the speaker, and disable it.
2) This option requires a bit more work, but will leave everything else enabled. - Double click on a speaker that doesn't have the meter moving - Advanced Tab - click the test button. If you hear sound, then this is the speaker setup you want. If not, try the next one. - close that pop-up window for the individual speaker, and go back to the main sound menu (Playback Tab) - single click on the speaker that works, and towards the bottom of the playback tab is an option to set it to default. Click on that.
Dec 25, 2010 | ION Audio iTTUSB Turntable
I lost my installation disc for my polaroid i1035 camera. can i download it? or what are my options? Its been over 6 months since purchase. thanks.
You can download pictures from your camera to your computer by using a memory card reader
You can use your computer's built-in memory card reader, if it has one, or you can purchase an external memory card reader as shown in the attached image
To do this, kindly remove the memory card from the camera and insert it into a card reader. Connect the card reader to the USB port of your PC.
Now, the memory card will be shown as a 'Removable disk' in "My Computer". You can browse the images and copy the images to your computer.
Hope this solves your problem. Thanks for using FixYa.
Sep 23, 2010 | Polaroid i1035 Digital Camera
Can I move internal memory to memory card?
In playback mode, go into the menu and there will be an option to "copy" the internal memory contents to a memory card.
Sep 08, 2010 | Polaroid i1035 Digital Camera
My Polaroid i1035 won't stay on. It comes on when
That usuallymeans an internal problem. So it needs to see a repair shop. Check for warrenty repair and replacement cost. Sometimes it is almost cheaper to just get a new camera.
Mar 23, 2010 | Polaroid i1035 Digital Camera
I cant hear playback as im recording, can you tell me why?
newer laptops and pcs use an HD audio chip. sigmatel or realtek or IDT usually. their configuration is held in the registry. some functions may not be configured to even display.
1st step is go to control panel and select the sound icon/option.
that will open a tab view for you sound card configuration, looks different in vista vs xp.
under XP you want to select the recording options to view and make sure which input is recording.
then you want to select the playback view to see which items may be muted or available for playback. You will be looking for input or mic depending on what you are using.
under vista there are a recording and playback tabs.
under vista you can right click on the area of a tab and select the option to display disabled devices, which you can then enable. depending on the sound card driver, the playback device can be selected and a new set of tabs can display monitor tab and/or volume controls with perhaps a check box for record monitor.
you can double click a device (i.e. playback device) to see it's properties and it will display a set of tabs that may include an Input monitor tab or a Enable Record Monitor Checkbox.
if not then it means the driver was not configured to support the function. this is usually a registry entry binary value named like EnableRecMonitor set to 01. The registry is tricky so if you don't have the back ground, look for a newer driver that may have the option enabled for your sound card...
Jan 06, 2010 | Sony Acid Pro 6 Professional Music...
How to use i1035 as a webcam?
Apparently, you can't. The owner's manual (http://mediacdn.shopatron.com/media/mfg/1848/spec_file/14070180.pdf) gives no indication that this camera has webcam capability.
Oct 11, 2009 | Polaroid i1035 Digital Camera
I have recently purhased a Polaroid i1035 digital camera and regardless of the setting(s) all of my pictures taken with this camera appear "grainy" or "fuzzy". I did not experience this problem with my...
It may have something to do with your settings.
Press the button with the diamond on it (at the bottom right hand cornner)
  • there will be a variety of different options that will help you take pictures in various conditions
In picture mode, press the ok button
  • go down to "awb" for more configurations and settings dealing with your conditions
(I might recomend the use of a tri-pod to hold it steady)
----John
Dec 09, 2008 | Polaroid i1035 Digital Camera
Cannot locate Playback mode for Polaroid i1035 Didital Camera
It may have something to do with your camera running on auto, internal, or sd option for your memory storage.
When you get to your black screen, try pressing the "w" in your zoom to see if you have taken any pictures. You did find the playback mode...so congradulations.
----just an idea
John
Dec 03, 2008 | Polaroid i1035 Digital Camera
Polaroid i1035 Digital Camera Logo
46 people viewed this question
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
