Youll need to enter a diagnistic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, htne press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
green clean light won't go off
clean, green light flashes, nothing else works
same as donna's problem is this a product defect/weakness??
The dishwasher will not start. The green "clean" light flashes six times, stops, then one time, and continues. When I press either the start or cancel buttons those lights flash a few times, then it turns off.
