Onlt picks up via the tools and the floor brushes are not spinning?
SOURCE: The brush is clean and spinning but it isnt
You mentioned pet hair. Remove the brush cover and check for a plug (possibly pet hair). Sounds as though you have a plug somewhere and it's not allow the suction to pull it through. Also check your filter and clean or replace as necessary. Hint; Never let you container get over half full, it reduces the suction.
SOURCE: Bissell upright vac, brush on bottom does not rotate
The front brush motor will not engage until the power is turned on and the handle is in the down position. In the upright position the brush motor wont engage. Typical faults will be the belt is broken and needs replacing or the fornt brush motor needs replacing.
SOURCE: brushes don't spin and not picking up water
Depending on your model, the belts may be worn or broken. You can get replacements here:
ProHeat Replacement Belts
SOURCE: My Bissell Pet Eraser brush only rotating on the
it sounds like something is backwards. the brush should only rotate when using it on carpet, it should never rotate on the bare floors. check the belt for propper installation
SOURCE: my bissell proheat brush will not spin or pick up
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
