Start up problem with Evesham LCD TV AV320PD
When switching TV on it seems to continuously loop through the start up sequence, red light, amber light, green light, back to red again...
Switching the unit on and off several times and waiting eventually gets the TV on but will it start at all tomorrow of the next day?
Many thanks
Mark Phelps
Cardiff
skotkolr
  • 558 Answers
SOURCE: Philips LCD TV - Red blinking lights
I would check the capacitors on the power pack for failed or blown ones. doing this work will require soldering skills
FYI
Posted on Apr 09, 2009
SOURCE: Sony Bravia LCD TV stand by red light flashes 13times
Really? Nobody has a better solution? I have the same problem and the tv's about a year old. That's it!
Crazy!
Posted on Jun 24, 2009
  • 5 Answers
SOURCE: LG 47" LCD shuts down several times w/ blinking red light.
Granger1212 we had the same problem. We called LG and although our LG was out of warranty by 4 months, we were asked to supply our proof of purchase and LG sent a serviceman to our home and in 2 days we had our television back working wonderfully. It's the power supply, call LG and BE NICE, I'm sure they will fix it.
Posted on Dec 13, 2009
toolkits
  • 1099 Answers
SOURCE: LG 32" Plasma TV power-on problem
Your power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
hope this helps...
Posted on Jul 02, 2010
budmrtn
  • 11361 Answers
SOURCE: Hi, I have a 37lc46 LG LCD which takes ages to
Replacement power supply is used?
You need to verify the DC output voltages of the power supply first and make sure this power supply has no bad caps with leaking/bulging tops. It goes into standby can also be that it detects fault some where in the set.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Posted on Dec 07, 2010
Tv won't turn on. Stuck in loop of red standby light clicking on /off.
sounds like the unit has entered a protection mode where a short has developed somewhere inside the tv. This response is the power supply in the tv trying to start up - seeing the overload and shutting down to protect itself, this loop will continue until the short has been resolved - best to get it repaired by a technician
Aug 13, 2010 | Samsung LN52A530 LCD TV
Samsung ln40a530 blinking red light, no video
Blinking lights are usually an error code. Do you have a manual that will decode the number of blinks? Its not always the power supply.
Apr 21, 2010 | Samsung LN40B530 40 in. LCD HDTV
Monitor goes to standby after booting up.( Amber light)
I'm going to guess that your monitor has different imputs and maybe you aren't selecting the right one? There is usualy a button to change imputs on the monitor. If there is no signal and you've checked all the channels, the cable your using might not be functional or your monitor might be broken.
Apr 18, 2010 | HP mx705 17" CRT Monitor
Turning on green light starts flashing only to hear a click and then the red light starts flashing... tv will not come on.. i can hear a fan that seems to start up...
The power up sequence is being interrupted and this could either be the main power supply or a protective shutdown of the supply because of a downstream failure. The clicking you hear is the activation and dropout of a relay.
If the flashing seems to be in a pattern, it may be telling you what has failed via the coded flashing. Any Sony service (or service tech) can tell you what the problem likely is if there is a pattern to it.
Nov 29, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Top up tv+ digital tv stopped working.
i had same prob, tried unplugging three times
then unpluuged for 5mins
, plugged back in left it alone, ie didnt touch remote or front panel, until it settled down ~15mins, green light came on (doesn't normally)
and everthing seems ok now
May 03, 2009 | Televison & Video
Akia 27 inch tv wont turn on
Power packs can be repaired, and most time it is simply capacitors. I don't charge an arm and a leg
Mar 26, 2009 | Akai LCT2715 27 in. LCD Television
Unable to boot at all
Overheating problem. Pls get a technician to clean the processor and apply a fresh layer of processor sealant and also clean all the fans.
Jun 08, 2008 | Evesham Voyager 6400 PC Notebook
Red blinking led
My 42" Philips LCD did the same red blinking sequence last night. All was seemingly fine after unplugging it for a bit. An online search, though, has me worried that this may be the start of (potentially fatal) power supply issues. Anyone have a clue what that sequence means?
I've got one week left on my 1yr waranty, so I'm a bit concerned! :(
Thanks!
Jan 15, 2008 | Philips 32PF7320A 32 in. LCD Television
Televison & Video Logo
228 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
