Question about HP Deskjet D2360 InkJet Printer
Printer green light is blinking and printer doesn't work
I tryed all the suggestions for the solution of similar fault but as soon I switch on power (either the pc cable is connecter or not) the light start blinking and printer doesn't acept any command. At power on anyway It makes the procedure to check the cartridges.
  • russel_sam1 Dec 24, 2008
    how may i able to troubleshoot this problem. kindly helpme.. ty
  • 300 Answers
You will find steps for resolving the issue you are having here. Hope this helps. Please remember to rate this information.
Thanks
Posted on Jan 08, 2009
Green blinking light codes
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
Jan 31, 2015 | Televison & Video
Green light blinking very fadley pc will not turn on
Sounds like you might have a partial power supply failure. Try unplugging the power supply from everything. Ther should be a switch on the back that is red and says something like 115/220 just flip that switch over to 220 and wait 5 minutes then switch it back to 115 and replug everything in and then try it. If it doesn't work then unplug everything again and let it sit for about 30 minutes (this resets the power supply) and reconnect the wires and if that doesn't work try getting a new power supply. In partial PCB (Power Supply Board) failures the problem is that trere isn't enough power going to the system to start up so sometimes resetting the PCB will fix it temporary. You should get a new one anyway. that one will fail completely soon. Good luck!
Mar 15, 2012 | Dell Computers & Internet
Cannon i865. Operator Error message and blinking orange light (5 blinks). Switching off power does not reset. Also used reset technique from this site, this does not seem to work. Any more ideas?
5 flashes indicates a faulty printhead or possibly a problem with the p/head contacts. Try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt.
If that doesn't work it may be that the waste ink tank is full. Try this ...
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 23, 2011 | Canon Office Equipment & Supplies
32 inch Crystal liquid tv's opc and power light flashes green
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 30, 2017 | Sharp Televison & Video
Yellow light blinks 7 times with 1 long green blink
Jennifer, According to an answer by kev1952 on 19 Sept, to my similar error condition ( "repeating sequence of 7 orange and 1 longer green flash of power LED" ) in a Canon i550 printer, and assuming that what you called yellow I called orange, then you too may have a printhead fault. kev1952 recommended to try to get it cleaned and checked at an ink refilling specialist service.
gp26, on 21 Sept 2009
Aug 17, 2009 | Canon PIXMA iP1600 Printer
Flashing lights and no printing
If the two lights are blinking persistently and the carriage is moving freely when the cover is opened then the logic board has problem and should be replaced. However, if there is some restriction of carriage movement or cracking noise, the optical cable should be replaced. Good luck
Apr 29, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Canon i560 printer
I have similar problem. I found this solution that may help you. My problem insists tho.
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
May 28, 2008 | Canon BubbleJet i560 InkJet Printer
No picture or sound - Error code with Six blinks
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206
Sep 24, 2006 | Sony KP-57WV600 57" Rear Projection...
HP Deskjet D2360 InkJet Printer Logo
83 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
