I have a remote control that needs the pin switch resetting. i dont know how they should be set. is there a way to find out or is there another pin switch in the light fitting that i can match?
There's two options, depending on the brand of remote. The most common is that the reciever located in the fan ceiling canopy has the same switches. Check how they are set and match it on the remote. The other option is that the reciever matches the frequency of whatever the remote is set to. To set this you have to turn off the circuit, wait a minute or so, turn it back on. Then on the remote, hold down the "stop" button for a few seconds. It should be set. I'd check the receiver first though. I should mention also, that when they come from the factory, the switches are usually all in the OFF position (or possibly all in the ON position). Unless they were changed on installation (which may be the case if you have more than one remote controlled fan) they are probably set that way. Try that first.
I have a remote controlled ceiling fan and light I purchased about 2 years ago at a Tuesday Morning....
(More)
I have a remote controlled ceiling fan and light I purchased about 2 years ago at a Tuesday Morning. The or light go on by themselves at various times. Changed the battery in remote but no change. Have you heard of this?
I have a ceiling fan that I believe is model Hampton Bay 52 In. White Redington III. It has a closed...
(More)
I have a ceiling fan that I believe is model Hampton Bay 52 In. White Redington III. It has a closed glass part at the top with bulbs in it as well as the 3 tulip shaped parts. The bulbs in the top glass part are starting to burn out and I can not figure out how to open it so I can change the bulbs. Anyone have any ideas?
I have a small ? 3 litre Butterfly Elite, model IS 2347 which I've never used, and I've lost the...
(More)
I have a small ? 3 litre Butterfly Elite, model IS 2347 which I've never used, and I've lost the instructions. Can I download them from somewhere, please? Jill Saint jsaint41@hotmail.com
The Remote control of the Viper Fan works normally when commanding the light on or off, and when...
(More)
The Remote control of the Viper Fan works normally when commanding the light on or off, and when commanded to turn the fan on low or off, but when you turn the fan on Medium or High, the fan will not command off and neither will the ligth command on or off. To add to the confusion if the fan is commanded to turn off from any of the speed settings, and the fan blades are turning slowly, it will turn of OK??? I have changed the remote battery for a fresh new one and the problem remains. _ HELP!!!
