Question about Sony SLV-N50 VHS VCR
Snowy picture on VCR with only certain channels
I try to record a certain channel and it will not record without a snowy picture, yet when you watch the channel live it is clear. This would be channel 41, which is well within the ability of the VCR. If you set the VCR up to record back to back on 2 different channels I.E. channel 6 then channel 41 the first will be clear but the 2nd (41) will be all snowy with the picture barely visible. Or set up channel 41 by itself it will be snowy. What is going on?
  • 24 Answers
The problem is definitely in the VCR because you ruled out a cable fault with the clear picture on the TV. If you know how to solder and aren't afraid to get your hands dirty, open it up and find the part number on the tuner then go over to a place like MCM or MAT Electronics and find a replacement. It'll probably run about $30.
Posted on Dec 28, 2008
  • 4,234 Answers
In all likelyhood, you have a bad ground somewhere in the cable. Try other channels through the VCR. If the ground is the problem, there will be a cluster of channels that are snowy with the rest being clear. Check the cable itself and all of the connectors along it.
If the cable and connectors are good, the tuner or power supply of the VCR could be faulty and cause this as well.
Dan
Posted on Dec 24, 2008
All 3 of my Seiki TVs have snowy pictures on cable network. THOR Industries says SEIKI are bad & are switching to Quality Brand--They say I will have to buy a QUAM Filter for these Seiki TV's---WHY ?
I assume you try to watch cable TV without box? Unfortunately some time ago government passed the law that cable companies are not longer required to provide basic programing in Clear QAM. Which basically means no free basic channels from cable company. Only way now is to get free channels is to use over the air OTA antenna. On most cable providers in USA you are not going to receive any channels without box. This is reason for "snowy" picture.
Mar 03, 2018 | Seiki Televison & Video
I'm using a coax cable from symphonic vr-701 to tv and trying to record. it acts like it is recording but just shows snowy image on playback
Coax from wall to coax in on VCR and Vcr Coax out to in on set.
Whatever channel vcr is on this way it will record and pass to set.
Check first you have playback from VCR to TV alone, could have dirty or blocked video heads which in record will just record no watchable picture. Hookup or blocked video heads are most likely.
Dec 13, 2012 | Symphonic Televison & Video
Since today i have had a snowy sound On channels 1-5 the picture is there, they are ok on just normal tv and they are ok through a vcr but not dvd recorder.....i have tryed settings,changing scart...
Hi, Unfortunately I am a bit unclear on the snowy sound issue but what your describing otherwise sounds like you are trying to watch tv via the dvd recorders built in t.v. tuner, this is possible usually just with a coaxial connection. ( a cable tv cord ) The out to t.v. terminal on back of recorder must be connected to the in from ant./cable on the back of the tv set. all other connections are for higher definition playback. Thanks for trying FixYa, I hope this helps, and good kuck-Prodzilla
Apr 13, 2011 | Televison & Video
CANNOT DUB FROM VHS TO DVD. IT RECORDS A SNOWY PICTURE AND NOT WHAT'S ON THE VHS.
you've got the record chnnel set wrong,play a VHS see what chnnel it plays on then set that channel as your record channel, or find a sync button on the unit or remote.
Nov 23, 2010 | Toshiba D-VR4 DVD Recorder/VCR
Recording
With your setup, the VCR gets its input from the cable box output, which will be on either channel 3 or 4. It depends on how you've set the box. The channel you are watching on TV or want to record is picked on the cable box.
The VCR will only ever see a channel 3 or 4 signal, so it must stay on that channel. That means when you record, set the VCR to record on channel 3 or 4, the box OUTPUT channel. The biggest mistake people make when they have a cable box is to set the VCR to record on some channel other than 3 or 4, and the result is snow. There's nothing on any other channel for the VCR to record. You also need to have the cable box turned on and set to the channel you want to record if you set the VCR for timer recording. That's another pitfall people meet.
This should get your recording going.
Mar 30, 2009 | Memorex MVR2031 VHS VCR
Sony SLV-640HF Problem
I would be inclined to say that there are only two likely problems that you may be encountering. Either you are getting a bad signal feed, or the connectors on the cable are getting old and need replaced. The connection to the cable can break down over time, especially if they have been connected and reconnected several times. I cannot rule out problems caused by the transition to DTV, but that doesnt seem likely if there are only a few channels affected. As far as "selective failure" of the VCR's built-in tuner, I would say that that is also a very unlikely source for the problem If the tuning components inside the tuner had gone out, I would expect to see a problem on all channels watched through the system. If you are having this problem on all channels of the sony, then the tuner could surely be the problem, but if you haven't used it much that would indicate a problem at manufacturing, however since at least one of the machines is working fine on some channels and not on all of them, I would suspect the connections or the signal from your cable company. Contact them first ands see if they are having signal issues, if not try replacing your connectors.
Dec 26, 2008 | Sony SLV-N55 VHS VCR
1996 RCA Color TV model G27720tn
If you are on cable, first run the cable wire from the wall directly to the TV, eliminating any cable box and/or VCR. If channel 2 is snowy but the rest (especially 3-6) are clear, it is most certainly a cable problem and not a TV problem. The TV uses the exact same circuits for channel 2 to 6 (VHF-LOW) so if the tuner was bad and 2 was snowy, 3, 4, 5 and 6 would be snowy too. Bring a second TV into that room, disconnect the cable wire from the RCA and connect it to the second TV. Is channel 2 on the second TV as snowy as it was on the RCA?
Aug 18, 2007 | RCA 24V511T 24" TV
Intermittent snowy pictures under Channel 51
Probably needs a new tuner or something associated with the tuner.
May 31, 2007 | RCA F36673ET 36" TV
Snowy picture on certain channels and only sometimes
Hello, the best option for you is to put another (small) TV instead of plasma to check whether your cable is OK. If you need more info please advice. Arpi
Mar 16, 2007 | Philips 23PF5320 23 in. HD-Ready LCD...
TV intermittently goes snowy.
time for a new tuner probably about 150-200 bucks to fix
Jun 13, 2006 | Mitsubishi PD-4001 40" TV
Sony SLV-N50 VHS VCR Logo
122 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
