Question about Minolta Office Equipment & Supplies
Dark background print in minolta EP2050 mach.
Print color is dark on the background of paper. ATDC was 140 vs 6.0 when it was printing faint(light) but after adding a small quantity of fresh toner to the drum, dark color retuns with background dark and ATDC current remains 0% even when adjusted to (atdc 130 or less) current remains zero
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
Replace controller/ interface board. The next step would be the regulator board. If you must keep resetting the ATDC and receive different values ( assuming that the ATDC is new) then the problem is back. What supplies/ controls the ATDC? The controller, but forgive me if I am wrong, there is a small interface board after the controller that the ATDC is plugged into.
Posted on Jan 05, 2009
Color printing is printed with a yellow background in bizhub c450
have you replace the Transfer belt.??? It also has a transfer roller for yellow. (Called First Transfer) since it is transferring yellow off the drum. You have replaced the yellow image unit???? 2nd transfer is to the paper!!!
May 18, 2016 | Konica Minolta bizhub C450P Laser Printer
Magental background on all prints looking like a pink papr instead of white
That sounds like a white balance issue to me. Do you use manual white balance setting or auto white balance?
Nov 05, 2013 | Konica Minolta Bizhub C550
Remove lines in print from Minolta Magicolor 2400w
check the fusing unit the hot part where the paper comes out? is the line a certain color replace that image unit.
Sep 22, 2012 | Minolta magicolor 2400W Laser Printer
I see where to change color density settings in thick paper. Can I do this for plain paper? (Normal printing is too dark.)
The only changes you can make are in the printer preferences menu, so if you have lightened it up there you have made the only adjustment allowed or provided for.
Jan 20, 2012 | Konica Minolta Bizhub c203 Copier
Minolta 2050 with ATDC set as 140 and current as 0%
Hello sir; replace auto toner sensor will be ok, that sensor is located on developer unit.
Dec 24, 2008 | Minolta EP4000/5000 CS/PRO Copier
ATDC: set is 140 but the current is 0%
you need to run F8 FIRST AND than F5
ATDC SHOULD BE SET TO 4.9
YOU MAY NEED TO RUN F8 few times untel you achieve 4-or beter ATDC VALUE
GOOD LUCK
COF37 error code
C0F37: Abnormally high toner density detected by Black ATDC Sensor
Toner density that is 4 % or more higher than the target level is detected ten consecutive times during a print1.gif cycle, ATVC, or image stabilization sequence.
The sensor for this error is in the black imaging unit not the toner hopper. See the steps below. If that doesn't work then visit my website1.gif for contact and I will sell you a full service and or parts manual on CD.
Step
Check Item
Result
Action
Imaging Unit Bk is installed correctly.
NO
Check and correct ATDC
drawer CN of imaging unit Bk.
Each of Imaging Unit Bk contacts makes
NO
Clean or correct.
good contact.
ATDC Sensor harness is open-circuited.
YES
Change Imaging Unit Bk.
Jan 20, 2008 | Minolta CF2001 Copier
Jammed Photocopier
I would suggest that a label came to be attached to the photorector drum. Unless you can remove this label the problem will continue
Dec 21, 2007 | Konica Minolta DiALTA Di200 Copier
206 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
