Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Grinding gear noise
Machine makes a grinding gear noise and won't rum. any clues? thanks, nina
    Problem Solver:
  • 7 Answers
Sounds like the transmission is out
Posted on Apr 16, 2007
I have a 1989 z24 cavilier and i just changed the slave cylinder and now when i start it and press the clutch it makes a grinding noise. When i try to put in gear it wont go in any gears and makes some...
hi i was wondering if anyone can tell me whats going on with my 89 z24 cav i just replaced two shifter cables on she's a 2.8l 5 speed and now when i starts her and lets the clutch out she dosen't engage at all but she has no noises and no grinding goes in gear fine but just won't move hope someone can help thanks
Jul 04, 2012 | Cars & Trucks
TAPPING NOISE, NOW IT WON'T GO INTO GEAR WITHOUT LOUD GRINDING NOISE AND ACTS LIKE TRANSMISSION WON'T ENGAGE TO DRIVE
If it is an automatic transmission, first check the fluid level. If it is low, fill it up and try it again. If the level is fine, then there is a bigger issue and you should seek a professional's help.
Jun 18, 2017 | 1996 Buick Century
My Kenmore 80 series washer won't spin, and it just makes a loud gear grinding noise. What could this be, and how do I fix, in the simplest form please I'm chick... :)
rebecca it is probably the motor coupler. Move or slide ur machine over and if there is ruber filings under it then it is the coupler.
Apr 04, 2012 | Kenmore 24032\24036 Top Load Washer
Car won't start but makes a grinding noise like when the car is started already
This sounds like a damaged starter drive gear and engine flywheel gear.
Feb 25, 2012 | 2001 Pontiac Grand Am SE
Lx425 has grinding noise but won
replace the starter gear. the starter is probably fine and alot cheaper if you just relplace the gears.
Jul 14, 2010 | Toro Garden
Makes a grinding noise near the drum. Copier works, but makes a "gear-grinding" noise near the drum area. Can't tell what's doing it.
Un load the drum unit, check the drum/s gear, is it wear off, if so change it along with the drum's drive gear at machine base, check also the gears of developing unit
Jun 29, 2009 | Sharp AL-1540CS All-In-One Laser Printer
Loud grinding noise when paper is feeding through machine
Mine was indeed a gear problem. Took off the top cover and poked around. Found two areas that may have caused the grinding.
1. The lower roller shaft had slid to the left out of it's groove. By removing the handset cradle (3 release tabs are accessed underneath the toner hatch.) I could loosen the "gear box" (a black contraption with all the gears inside) and then snug the bottom roller into proper position.
2. I removed the "gear box" to look around. Don't know if I dislodged one of the gears while doing so, but noticed one was dislodged ;-)
This required opening up the gear box by removing 2 screws and lifting off the motor. Then i could get at a gear that had come loose from a claw sort of piece. Note: the teeth of the loose gear needed to be on the motor side when sliding it back into the claw thingy. It seems to use a metal clip for friction control and perhaps proper spacing.
I noticed "some" wearing of gears, but doubt this is an issue. This machine has been used VERY hard for years and now, just by re-aligning things, it works once again.
My googling barely found any mention of troubleshooting this machine, so I shudder to think what finding parts would be like.
Jan 19, 2009 | Brother IntelliFAX 2800 Laser Fax
Grinding noise from hell - no spin, no agitation (except my own!).
Please see the following link for all possible troubleshooting tips:
http://www.repairclinic.com/0088_11_1.asp#Level1_3
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Oct 04, 2008 | Washing Machines
Major problems when trying to print, Jamming alot & grinding noise
If the paper is an accordion type jam, you should replace the 4 small rollers, the upper feed roller, the upper feed guide, and the lower rollers. all of these are listed on hp's part surfer website.
RF5-0425-040cn, RF5-0434-000cn, RF5-0432-000cn, and RF5-0438-000cn respectively. Basically, get a new exit output assembly part number RG5-0456-180cn.
Does this help?
Jul 09, 2008 | HP LaserJet 4 plus Printer
Gears grinding with Brother Intellifax 4100
Does it only make the noise when printing. Do you hear the noise when sending out faxes? I have heard grinding noises onlt when using poor quality toner refills, or the fuser gear and or drive gear asm is stripped. First try a known good OEM toner.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Mar 22, 2007 | Brother IntelliFAX 4100 Laser Fax
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
85 people viewed this question
Sal De
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
