Question about Pentax ME Super 35mm SLR Camera
Pentax ME Super Shutter and Rapid Wind Button...
Found my Dad's old Pentax ME Super camera in great shape, but the shutter and the rapid wind button seem to be stuck. Inside the camera, the inside mirror stays up and makes things dark looking through the viewfinder. i have tried putting new battiries but still viewfinder dont work. Are these potential deadly problems?? Don't remember him having any problems with it. Help. Scratching my head!
    Scholar:
  • 185 Answers
Anmolag,
it could be the rubber bumper next to the fresnel lens has become sticky. very gently ( after removing lens ) try to bring mirror down without forcing it. it should release easily.
if not, rotate the select knob off auto. open film door and check that the shutter is fully deployed, shutters should not be overlapping.
remove screws from bottom cover and remove cover, keep camera up side down so that re-wind button stays put. there is a locking lever under the take up spool ( gray ) . with a pin move lever toward film door and bring advance lever fully to the right , then let it go so it returns quickly.
the shutter should have fired. if not the camera will need to be repaired. get an estimate first as there are no new parts available.
Posted on Dec 27, 2008
This Yashica FR's film advance is loose and does not wind the film, the shutter button does not work either! It has a new battery in it. Any help would be greatly appreciated. I'm not sure if I'm miss
yashika is a really cheaply built brand of camera, they always have been. as cheap as they have gotten now you might as well come up to the digital age. but if you are one of those hard core old school photographers then you can find some good canon, nikon or pentax film cameras on ebay really cheap. i wouldn't mess with this one any more
Feb 22, 2013 | Cameras
Pentax me super shutter won't open. won't wind, wont take a picture :(
Have you not used it in a while?
This could be one of two issues:
One, it could be the battteries. The ME super is not a fully mechanical camera like the mx, if the batteries are depleted then the shutter sticks open as it does not know how long to stay open. Turning the selection wheel to 125X usually unsticks it.
Two, the lubricant that pentax used in the 70's and 80's has a very bad tendecy to polymerise and turn sticky and solid. This turns the camera inoperable. Pentax repair service routinely provide cleaning for affected cameras.
Hope this helps, its a great camera
Jan 12, 2011 | Pentax ME Super 35mm SLR Camera
Pentax me super can not advance the film advance
if the re-wind button is not stuck in, then the tab on the advance shaft is broken off. this small piece of metal will jamb the gears eventually.
take or send your camera to a repair shop for a cost estimate before repair as there are no new parts available for this model .
Jun 08, 2009 | Pentax ME Super 35mm SLR Camera
Film won't advance
Pentax ME Super was one of my favorite camera, small and clean shutter release. But it has been about 25 years since it was manufactured. They happen to use rubber break within shutter unit and as any rubbers, it started to deteriorate and melt between the shutter-blades. This prevents the complete cycle of the shutter and jams the winding. You may be able to unjam the winding but eventually you have to overhaul the shutter unit. Overhaul charge is around $100 in US repair market. -James
Mar 31, 2009 | Pentax ME Super 35mm SLR Camera
Pentax ME Super Shutter and Rapid Wind Button won't release
Common fault due to perished rubber parts. Can be usually be repaired, but do not try to force the camera, that may cause damage which can not.
Go to http:/www.mypentax.com for information on how to service this yourself. The author can also advise by mail, and can service these cameras too.
Nov 23, 2008 | Pentax ME Super 35mm SLR Camera
Film advance broken.
Press the rewind button and wind the film advance lever, It will set to its place. Release the rewind button, press the shutter release button.Once again try wind the film.( provided your camera is not fitted with motor wind )
Mar 27, 2008 | Pentax ME Super 35mm SLR Camera
Film will not advance
Pressing the rewind button wind the film advance lever,if it is free It will set to its place. Release the rewind button, press the shutter release button.Once again try wind the film.( provided your camera is not fitted with motor wind )
Then your winding gears need cleaning
Jan 18, 2008 | Pentax ME Super 35mm SLR Camera
Wind up film button
This is a common problem with the older Pentax SLRs : shutter / mirror box needs servicing . The problem is caused by perished rubber parts. Although the problem is easy to fix, it has to be carried out by a pro because the mirror box has to be removed from the camera so that one can have access to the shutter and the side of the m-box where the problem is. Costs ? +- $150.
Nov 04, 2007 | Pentax ME Super 35mm SLR Camera
Pentax ME slr (old hand film wind )
the film might not have been catching onto the wheel it has happend to me befor
Oct 05, 2007 | Pentax ME Super 35mm SLR Camera
Shutter wont fire, or auto focus
This sounds like mirror box motor problem ( see enclosed shot from our workshop ) : this cocks the shutter and controls mirror mechanism and when the drive dosnt work properly ( small nylon gear on the motor goes ) camera will develop the the sort of problems you describe.
Can be repaired but will cost $ 150-200 so it is relatively expensive repair.
Jun 01, 2007 | Pentax MZ-50 35mm SLR Camera
Pentax ME Super 35mm SLR Camera Logo
656 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
