Question about Blueant Supertooth Light Bluetooth Speaker Car Kit
Blueant supertooth not pairing to samsung omnia i900
Hi I have tried everything that i can...i have turned on the bluetooth on the phone and made it visible it does recognise the bluetooth and I have saved this.
I have reset the phone and tried this.
I have reset and tried from the start on the blueant.
It's as though the blueant can't see the phone.
  • Shabeer Ali Mar 16, 2009
    I have pairing problem with my bluetooth headset from TECH and Samsung omnia.
    Iam not able to detect the bluetooth in samsung omnia.
    Please help
  • gurpreetjani Apr 06, 2009
    my blueant is not working my cell phone. I have blackjack II samsung phone. The error i get is device not open. Can you please help me.
  • 827 Answers
Hallo Stu,
Try following the below instructions, if you haven't already tried them..
First Time Pairing to your Bluetooth Mobile Phone
When you turn ON your Supertooth Light for the first time, it will automatically go into Pairing mode ready to be found by devices in Bluetooth searches. This will be the case until you have successfully paired a phone. If you have already paired a
phone, please go to the next section.
1. Power ON your Supertooth Light. The Bluetooth Indicator (3) will turn a blinking
red/blue, The kit is now in pairing mode.
2. Go to Point 3 in the next section, “Pairing to your Bluetooth Mobile phone”
Pair the SUPERTOOTH LIGHT to your Bluetooth mobile phone to create a “Pairing”
link, or audio connection between the two. This has to be only done once when first connecting each new phone.
1. From OFF, Press and Hold the Accept Button (1).
2. While holding the Accept Button (1), switch the kit on (Press-and-release the
Microphone Shaft (5)).
3. The Bluetooth Indicator (3) will turn a blinking red/blue, when you see
this, release the Accept Button (1). The kit is now in pairing mode.
4. While the kit is in pairing mode, access the Bluetooth menu of your phone. Turn on the Bluetooth function then execute a Bluetooth search, or discover. (See your phone’s manual for specific instructions.)
5. When the phone displays the list of Bluetooth devices, select ST LIGHT.
6. When the phone asks for the password, enter 0000 and press Ok.
7. Set the ST LIGHT as a trusted/authorized device, if this is option in your phone.
Important Note: The kit is now paired. Most phones automatically connect to the
kit after pairing. With some phones you need to connect manually after pairing.
Go back to Bluetooth > Paired devices > highlight ST LIGHT > press
Options > then press Connect.
When connected you may see the Bluetooth Symbol on your phone change
slightly, either inverting in color or changing to a headset or car symbol. The kit
is now ready to use.
Repeat steps 1 -7 above for each new phone you want to use with the
Supertooth Light.
This was copied from the user manual, which you may or may not have already.. Here's a link to a .pdf file of the manual which you can also save to your computer:
http://www.blueantwireless.com/downloads/supertooth_light/supertooth_light_manual.pdf
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Posted on Dec 24, 2008
    New Friend:
  • 10 Answers
I finally managed to get my i910 Omnia to work by using the teeny weeny on screen keyboard instead of the Samsung keyboard. If you can see the password characters as you type them in just know it isn't working. The characters have to appear as **** then you know you're making headway.
Posted on Jun 15, 2009
How do you pair an iPhone with the blueAnt st3?
Step 1: Activate Pairing Mode on the Supertooth 3
Make sure the Supertooth 3 is turned off.
You can tell if the Supertooth 3 is on or off by looking at the light on the front. If the light is on or flashing, then the Supertooth 3 is on: turn it off by holding down the Multi-Function button (the green button) for about 5 seconds, until you hear the voice announce that the Supertooth 3 is powering down.
With the Supertooth 3 off, hold down the Multi-Function button for about 6 seconds, until the light on the front of the unit starts flashing red and blue.
The Supertooth 3 will now prompt you to select your language: press the Multi-Function button when you hear your language spoken.
The Supertooth 3 is now in pairing mode.
Step 2: Apple iPhone
Now you need to use your iPhone to search for Bluetooth devices:
Select Settings.
Select General.
Select Bluetooth.
Wait for your phone to search for devices, then select your BlueAnt device from the list.
If you are prompted for a PIN, enter 0000 (four zeros).
Select Connect.
Your BlueAnt device is now paired.
Jul 12, 2011 | Blueant Supertooth 3 Bluetooth Handsfree...
How do I pair it to my droid two
Hi Amygreb4037
According to BlueAnt this is the correct procedure:
Firstly:
Make sure the Supertooth 3 is turned off. You can tell if the Supertooth 3 is on or off by looking at the light on the front. If the light is on or flashing, then the Supertooth 3 is on: turn it off by holding down the Multi-Function button (the green button) for about 5 seconds, until you hear the voice announce that the Supertooth 3 is powering down. With the Supertooth 3 off, hold down the Multi-Function button for about 6 seconds, until the light on the front of the unit starts flashing red and blue. The Supertooth 3 will now prompt you to select your language: press the Multi-Function button when you hear your language spoken. The Supertooth 3 is now in pairing mode.
Then on your droid two
Go to the system menu and enable Bluetooth Go to your phone's Bluetooth menu. Select Add New Device. Wait for your phone to search for devices, then select your BlueAnt device from the list. If you are prompted for a PIN, enter 0000 (four zeros). If you are prompted to connect to the device, select Yes or Connect.
The two should then be paired and working.
More information can be found on BlueAnts website:
http://www.myblueant.com/knowledgebase/pairing/products/st3.php
I hope this helps.
Mar 03, 2011 | Blueant Supertooth 3 Bluetooth Handsfree...
Lost my manual for my BlueAnt CE0678, have a new phone and forgotton how to pair them. Please help
I GOT A SUPERTOOTH BUDDY CE0678 ITS PAIRING WITH MY PHONE BUT NOTHING HAPPENS NO MANUALS ETC PHONE SAMSUNG C303
Jan 10, 2011 | Blueant Supertooth Light Bluetooth Speaker...
Is Blueant ST3 Compatible with the iPhone4
Any bluetooth device should work with the iPhone4. Here is the directions for "pairing" from the BlueAnt website.
  1. Make sure the Supertooth 3 is turned off. You can tell if the Supertooth 3 is on or off by looking at the light on the front. If the light is on or flashing, then the Supertooth 3 is on: turn it off by holding down the Multi-Function button (the green button) for about 5 seconds, until you hear the voice announce that the Supertooth 3 is powering down.
  2. With the Supertooth 3 off, hold down the Multi-Function button for about 6 seconds, until the light on the front of the unit starts flashing red and blue.
  3. The Supertooth 3 will now prompt you to select your language: press the Multi-Function button when you hear your language spoken.
  4. The Supertooth 3 is now in pairing mode.
Pairing Your BlueAnt Step 4: Apple iPhone Now you need to use your iPhone to search for Bluetooth devices:
  1. Select Settings.
  2. Select General.
  3. Select Bluetooth.
  4. Wait for your phone to search for devices, then select your BlueAnt device from the list.
  5. If you are prompted for a PIN, enter 0000 (four zeros).
  6. Select Connect.
Jan 08, 2011 | Blueant Supertooth 3 Bluetooth Handsfree...
Hi I have a blueant supertooth it's working but I couldn't pair with iPhone .iPhone couldn't search Bluetooth device why??
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode (usually you have to hold the power button for 7-10 seconds).
Your phone will find the device, and you will be prompted to enter the devise's PIN number (often 0-0-0-0). Your phone should pair with the device then.
Jan 01, 2011 | Blueant Supertooth 3
Having trouble pairing phone with Blue Ant ST3
  1. If the Supertooth 3 is on, turn it off by holding down the green Multi-Function button for about 5 seconds (until you hear a voice announce "BlueAnt ST3 powering down").
  2. Hold down "Vol " and the green Multi-Function button until you hear a loud siren/distinctive tone.
  3. The Supertooth 3 will turn on. Hold down the green Multi-Function button for about 5 seconds to turn it off again.
  4. The Supertooth 3 has now been reset: all pairing and other information has been deleted. When you turn the Supertooth 3 back on again it will prompt you to select a language and then go into pairing mode.
You will now need to re-pair your phone with your Supertooth 3.
Apr 17, 2010 | Blueant Supertooth Light Bluetooth Speaker...
I have a BlueAnt Supertooth BTSLBC3 car speaker that won't pair up to my new BlackBerry curve 8530 phone. The BlackBerry won't see the BlueAnt Supertooth BTSLBC3. The BlueAnt Supertooth BTSLBC3 is paired...
Pairing Your BlueAntStep 2: Activate Pairing Mode on the Supertooth Light
  1. If the microphone arm is open, close it to turn the Supertooth Light off.
  2. Press and hold the answer button.
  3. With the answer button held down, open the microphone arm.
  4. The lights will start flashing red and blue, indicating that the Supertooth Light is in pairing mode.
You now need to activate Bluetooth
Apr 03, 2010 | Blueant Supertooth Light Bluetooth Speaker...
How do i sync supertooth light to a new mobile phone
Turn the blueant off by holding the green button until it powers down. Put your phone in discover mode (refer to your phone's manual) then power the blueant back up but hold down the green button until the light starts flashing red and blue. Now you should be able to see it on the phone. I just discovered my Samsung I910 wouldn't pair unless I used the windows on screen keyboard instead of the Samsung on screen keyboard.
Jun 11, 2009 | Blueant Supertooth Light Bluetooth Speaker...
How do I turn ON the Bluetooth fucntion on my phone? How and where can I find the Bluetooth menu with the list of devices on SGH-a437?
Go to this page, it will answer any question concerning the blueant .. including pairing to your phone .. activating your blueant etc http://www.blueant.com.au/index.php
Apr 14, 2009 | Samsung Bluetooth?® WEP200 Headset...
Samsung sgh617 blackjack2 and bluetooth compatability
Mar 21, 2009 | Samsung BlackJack II Smartphone
Blueant Supertooth Light Bluetooth Speaker Car Kit Logo
3,028 people viewed this question
Top Blueant Radio Communications Experts
Josh Whitehead
Josh Whitehead
Michael Vincent Cruz
aliasger yq
Are you a Blueant Radio Communication Expert? Answer questions, earn points and help others
