Question about Denon AVR-4306 Receiver
Cannot connect denon products to computer
Dear Reader, We are having problem with connecting our new denon 4306 to our computer. Computer does not regonize it. Hope you can help. Many thanks, Skibby (The Netherlands)
  • Anonymous Nov 05, 2007
    Cannot hook up denon to the tv
    cannot hook up my denon 4306 to my tv
  • 3 Answers
Hello! I presume you are connecting it via the RS232 connection to the PC. This method is NOT plug and play, like a USB connection is, so you will have to install the driver that presumably came with it, then manually assign a port from within Windows. Although I don't have this amp, I have experience in connecting similar devices using the RS232 interface. Also, make sure the BAUD speeds are correct. This is also defined from Windows.
Posted on Apr 12, 2007
How can i upgrade denon avr 4306 up to 1080p?
You don't need to upgrade that model as it already supports 1080P. If you are using HDMI connections between the receiver your TV the receiver will upconvert the other analog video sources (composite and component video) to 1080 content. Most likely 1080i as this is the standard format when upconverting.
Feb 28, 2011 | Denon AVR-4306 Receiver
Denon AVR-4306 + Motorola DCT-6416 Blanking
Hi Jim,
I tried connecting my dvr via component and optical to see if it was my hdmi or my dvr. Ended up being a bad hdmi plug in back of my amp. I was fortunate enough to have both style connections on my dvr. Hope this helps
Turk
Oct 13, 2009 | Denon AVR-4306 Receiver
No component output on AVR-4306
This does not work... You can only upscale the video signal with 4306; meaning you can covert s-video, component video to HDMI but can not down-convert HDMI input (coming from your HD DVD player) to Component video output. Sorry that I could not give you a solution as this is the 4306's limitation (written on the 4306 manual.).
Nov 21, 2008 | Denon AVR-4306 Receiver
On screen display
Try connecting to the yellow RCA monitor output on the amp and corresponding input on the TV. This works for me. You could also try the composite outputs on the amp. This is one flaw the amp has that the setup screen will not display through the HDMI connection.
Aug 04, 2008 | Denon AVR-4306 Receiver
Install ps3 on avr-4306
PLUG THE STANDARD PS3 CABLE INTO PS3 THEN TO TV GO TO SET MENU FOR PS3 AND SET VIDEO OUT TO HDMI,PICTURE WILL GO OFF SO BE QUICK AND PUT HDMI CABLE INTO PS3 THEN TV,NOW SET AUDIO OUT PUT TO HDMI,THEN CONNECT TO AMP,IF YOU STILL GET NOTHING CHECK AMP SETTINGS IE INPUT SELECTION FOR HDMI.
HOPE THIS HELPS.
CABLE GUY.
Jun 18, 2008 | Denon AVR-4306 Receiver
Zone 2 Problem
Yes and no. You can get some digital signals to go to zones 2 & 3 but only PCM ones, Analogue always goes. I have a Denon DVD player connected to my 4306 with a denonlink cable. I had to connect RCA Analogue cables to the DVD input to get the sound to come out on Zone 2.
May 02, 2007 | Denon AVR-4306 Receiver
Coonecting receiver to computer
If you are using a Windows OS then you will need to go to the speaker icon on the bottom right of your screen and open the menu that allows you to select the line in input. Good luck.
Apr 12, 2007 | Denon AVR-4306 Receiver
Denon AVR 4306 receiver not connecting up 1080p with playstation 3
HELLO, I DID A LITTLE RESEARCH FOR YOU AND FOUND IN YOUR MANUAL ON PG 103 IT STATES "RES OF 1080P ARE NOT HANDLED"
Jan 21, 2007 | Denon AVR-4306 Receiver
Open Questions:
See all Denon AVR-4306 Receiver Questions
Denon AVR-4306 Receiver Logo
688 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
