Question about Video Game Consoles & Games
WHY DOES THE DISC PORT ON MY WII NOT GLOW BLUE ??
  • 73 Answers
The blue light on the disc port of the wii has a connector inside.you need to open the wii first and check if the connector is in place.if not just plug it in.is the wii modded?if so,maybe the guy that fix the chip forget to insert the plug.or if its not modded then the LED is already burn out and needs a replacement.hope this one helps
Posted on Dec 24, 2008
Blue disk light on until console unplugged now games won't work
One has nothing to do with the other. It's a coincidence.
The blue light means that there is an update available from Nintendo to be installed. It could also mean that you received a message or news from Nintendo. If you don't like the blue light, you can change it in the wiiconnect24 settings.
If your Wii isn't reading games, the first thing to do is to check the disc. If it is not scratched or no discs at all are working, your drive needs to be replaced. You can find a new Wii DVD drive replacement at the following page:
Wii Replacement DVD Drive Repair Part
Jun 22, 2013 | Nintendo Wii Console
Is my wii turned off? I pressed the power button but there is still a yellowish light. And then the opening for the disks has the blue light that won't shut off. So is it turned off or is something...
The Wii can stay connected to the internet to keep itself and apps, such as the weather and news, current. If you have the yellow light and the glowing blue disc slot, this feature is on.
You can go to the Wii's settings to turn the feature off.
Jun 10, 2011 | Nintendo Video Game Consoles & Games
MY WII BALANCE BOARD IS CHARGED BUT THE BLUE LIGHT WONT STAY ON.
  1. Insert a Wii Balance Board compatible game disc in the Wii console.
  2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
  3. Open the small SD Card slot cover on the front of the Wii console.
  4. Remove the Battery Cover on the bottom of the Wii Balance Board.
  5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
  6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
  7. The blue light will stop blinking and stay on steady once the syncronization is complete.
click here to download repair guide if u want
Dec 15, 2010 | Nintendo Wii Fit - Balance Board + Game...
Bought 2nd hand wii fit, have just loaded disc and replaced batteries in board but power light not staying on board, flashes for about 30 seconds and then switches off. Does it need to be synchronised with...
    Hope this helps
    Try these steps!
  7. The blue light will stop blinking and stay on steady once the synchronization is complete.
please leave a good rating and testimonial if you appreciate my help. THNX
Mar 27, 2010 | Nintendo Wii Fit for Wii
How do we connect the dance mat to the Wii console for DDR 3?
How do I connect the mat to the Wii™?
If your Wii™ is standing upright with the power button facing you at the top left, the top skinny side of the Wii™ that points up towards the ceiling contains the flaps. Lift the flap up, like how you would open a book, on the top of the console. You will find the ports under this flap. Plug your mat into the port that is the closest to where you would stick in the disc.
If your Wii™is laying flat horizontal, with the disc slot going left and right, and the power button facing you at the bottom left corner, the left skinny side of the Wii™that faces towards the left contains the flaps. Flip the flap down towards the left and you should see the 4 ports. Plug your dance mat into the port that is closest to the front of your Wii™ where you would stick in the disc.
Other steps to make sure you have tried:
Make sure that your Wii™ is turned off before plugging in your mat.
Also, make sure the connection is secure to your console.
Then with the game in the Wii™, turn on your console.
The mat should be recognized at that point.
Mar 22, 2010 | Konami Dance Dance Revolution Hottest...
Okay, I have a problem...obviously. I have a Legend of Zelda: Twilight Princess disc stuck in my Wii. When I turn it on, I can play it all right. But when I press Eject, the light for the disc tray glows...
  1. You should take the wii To the nearest nintendo shop or where you had bought it from thank you there is noy any thing you can do right now and if you dont take it to the service center the wii may would get damaged and the disc too
Jul 05, 2009 | Nintendo Wii Console
Wii won't read discs, spits them out, no blue light
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Jan 18, 2009 | Nintendo Wii Console
Blue light
All we did was hit reset on the Wii system while on the Wii main menu.
Feb 27, 2008 | Nintendo Wii Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
Nikki  Mclean
Nikki Mclean
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
