Question about ASUS F5RL-AP360E, Intel Core 2 Duo T2390 1.86GHz, 2GB DDR2, 250GB HDD, 15.4 WXGA, DVD SuperMulti Dua... PC Notebook
Windows doesn't start and there is an error message
The msg reads something like insert windows discs and then click fix my computer. I don't have the discs and the supplier is saying that I am not supposed to have them. Is this true - I thought that all computers should be supplied with the discs in the event of this very problem. It won't let me start it in safe mode either when pressing f8.
  • 238 Answers
It depends. Some of the computer stores give an Operating System disc when a customer purchases a computer package but one thing for sure they will give you a system drivers disc for your unit.  In your case now, you should have a boot media disc (Operating System) installer for you to install a fresh copy of your operating system or repair your Operating System problem you are facing now. Make sure you are setting your bios boot sequence to cd, floppy and last will be your harddisk.
Posted on Dec 24, 2008
Windows failed to start. A recent hardware or software change might be the cause. To fix the problem: 1. Insert your windows installation disc and restart your computer. 2. Choose your language settings,...
Big trouble. Try safe mode, if possible. Don\'t use recovery procedure, just manually remove unnecessary things. Finally backup your data, and reinstall whole system?
Mar 19, 2014 | Acer Computers & Internet
Hi, I have a windows 7 ultimate 32 bit. And when
Try first getting in via safe mode (Hit F8 when booting and then choose Safe Mode) - then use system restore to revert to a previous working state.
Aug 10, 2013 | Computers & Internet
Advent 4213 Netbook 0xc000000f
The first thing I would try is to try to start the computer is Safemode. Safemode is a way of loading Windows without loading all of it. It only starts up with the most basic stuff that you need to help you diagnose other problems.
To start in Safemode, turn off the computer. Turn on the computer, and immediately begin pressing the F8 key. Press it once every half of a second, and keep doing this over and over and over. If the computer allows you to get into Safemode, then you have a chance to try to Restore the computer to an earlier point.
If you cannot accomplish anything using this method, then you may need to find someone who has an "external cd drive." This will make it possible for you to put the original Windows discs in and do a repair that way. This assumes you have those discs! If you don't have the discs, you may be able to buy them from Advent. I would suggest going to their web site to see if they offer any other solutions!
I just looked at the Advent site located here: Advent. It appears that your recovery discs are actually not burned onto discs when you first get the machine. You are supposed to put one of those USB drives (thumb drive) into the machine when it is still working right and copy the recovery program onto the USB drive. Maybe if you can get the computer to start in Safemode, then you might be able to copy the recovery program as instructed on the Advent website above. Just click that link and read about it.
Oct 21, 2012 | Advent Netbook
Bootmgr missing error on startup
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors an outdated BIOS and damaged or loose IDE cables
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a
non-bootable source.
This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
make sure there are no disks in cd floppy usb drives
How to Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your
Windows installation disc, or can't access the recovery options provided by your computer manufacturer."
or
If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
a) Insert the Windows 7 System Repair DVD or Installation DVD and reboot.
b) Select the correct keyboard input method and click 'Next'.
Note: If you are using the Windows7 Install DVD then at the 'Install Now' prompt (Do not pick the Install
Now option) instead choose the 'Repair your computer' option located in the lower left of the dispay.
c) The System Repair tool will search for a valid operating system and will report that "Windows found problems with your computer's startup options. Do you want to apply repairs and restart your computer?"
d) Click 'Repair and restart' and reboot again to the Windows 7 System Repair environment.
e) Click 'Next' at the keyboard selection prompt and when the 'System Recovery Options' screen appears verify that the "Use recovery tools that can help fix problems starting Windows" is selected.
Note that on your Dual Boot system there now should be only one operating system listed. Click the 'Next' button.
f) Now from the menu list select the 'Command Prompt' option.
g) At the DOS prompt type the following three commands:
bootrec.exe /fixmbr
bootrec.exe /fixboot (may return an 'Eliment not found' message)
bootrec.exe /RebuildBcd
h) Close the command prompt window and click the 'Startup Repair' option.
i) The repair process may take some time, so wait until the process completes at which point you will see two messages "Windows cannot repair this computer automatically" and "Startup Repair cannot repair this computer automatically".
These messages are the result of the radical changes made by removing the other drive. Ignore the Send/Don't send options.
J) Close this message window by clicking on the X in the upper right corner of the Send/Don't send window. Next click on the 'View advanced options for system recovery and support' option and from the main menu once again click 'Startup Repair'.
This time the repair process may only that a few seconds and when prompted "Startup Repair could not detect a problem", click 'Finish' and run the 'Startup Repair' option one more time, click 'Finish', and then remove the System Repair DVD and click 'Restart'. Reboot the computer.
hope this helps
Oct 09, 2012 | Dell Studio 1737 Laptop
How do i fix windows update error 1722
According to the error code 1722, it is actually a windows installer error. What we need to do is to fix the Windows Installer.
Try the following fix below...
(Please note that before trying any of the solutions below, you must be logged into your computer as an Administrator.)
  • Check whether Windows Installer engine is functioning.
  1. Click Start > Accessories > Command Prompt.
  2. At the command prompt, type MSIExec and press Enter. MSI refers to the Windows Installer.
  3. In the MSI engine is working, you should see no error messages. However, if you see an error message, note down the error. Search for it in a search engine such as Google to find troubleshooting solutions.
  4. Now try to install or uninstall the program again. If the problem persists, go to the next fix.
  • Check that Windows Installer service is not disabled.
  1. Click Start and type service.msc in the Search box and press Enter.
  2. The Services window is opened. Right-click on 'Windows Installer' service, then click 'Start'. The service needs to start without any errors.
  3. Now try to install or uninstall your program again. If it persists, try the next fix.
  • Check for latest version of Windows Installer.
  2. Once the command prompt window opens up, type MSIExec and press Enter. If MSI engine is working, you should see no error messages, and it should open a separate dialog box, which shows the MSI version.
  3. If the installer version doesn't show as version 4.5, download the latest version athttp://support.microsoft.com/kb/942288/
  4. Now try to install or reinstall your program again. If it still persists, try the next fix.
  • Reregister the installer engine.
  2. At the command prompt, first type MSIExec / unregister, then press Enter and type MSIExec / regserver
  3. Now try to install or reinstall your program again.
  • Clean your CD or DVD media.
  1. If you are trying to install the program from a CD or DVD media, use a CD or DVD disc cleaning kit.
  2. You can also gently wipe the silver side of the disc with a soft, lint-free cotton cloth. Make sure you do not use paper or other rough cloth as this can scratch the plastic or leave streaks that can damage the disk. Make sure you wipe the disk from the center outward and not circular motion.
  3. If you use a damp cloth or commercial disk cleaning solution, wipe the disc thoroughly before inserting into the drive.
  • Copy installation files to your computer.
  1. If you are using a removable or external media to install the program, copy the installation files from there to your computer's hard drive and then run the installation file from that location. It is usually called autorun.exe or setup.exe. If you are not sure, just check the Readme file in the setup folder about how to start the installation.
  2. Unless there is no .exe file present in the setup folder, we do not recommend that you run .msi files directly.
  • Terminating other programs running on your computer.
  1. Click Start and type msconfig in the Search box.
  2. One the 'General' tab, click 'Selective startup', then click to clear the 'Load startup items' checkbox.
  3. Click 'Services' tab, click 'Hide all Microsoft services', and then click 'Disable all'.
  4. Click OK, then click Restart.
  5. After the computer restarts, try to run your program installation.
  6. Once you have finished troubleshooting the problem, restart your computer again.
  7. Click Start, type msconfig in the Search box. Click on the 'General' tab, click 'Normal startup', click OK, then click Restart.
    Hope this helps!
Sep 09, 2011 | Computers & Internet
I had Dell Windows XP along time ago. I now have Windows Vista Business and I think it is Service pack 1. I pressed F12 and did diagnosis then it scanned right off the bat it says... "Error Code...
Hi. Error 0146 is pertaining to a failing hard drive. You can still try to reinstall Windows Vista by requesting for a CD from Dell by contacting them.
If they fail to send you a CD or if the error still comes up after reinstalling Vista, then you need to replace your hard drive.
Feb 06, 2011 | Dell Inspiron 1501 Notebook
I haven't had a recent hardware or software change but when I turn on my Dell Inspiron 1521 laptop I get a black screen with the following message: Windows Boot Manager Windows failed to start. A...
boot from an applicable boot disk & use fixmbr to repair the boot sector,
OR have you tried safe mode or last good....( you need to press F8 seconds after the PC is turned on)
Dec 31, 2010 | Dell Inspiron 1521 Notebook
I have a problem. the computer started to produce
Can give me more detail how to fix the problem
Jul 18, 2010 | Computers & Internet
What is file error 0xc000000e
File: \Boot\BCD
Status: 0xc000000e
Info: An error occurred while attempting to read the boot configuration data.
1. Insert your Windows Installation disc and restart your computer.
2. Choose your language settings and then click "Next"
3. Click "Repair your computer"
If you do not have this disc, contact your system administrator or computer
manufacturer for assistance.
ERNZ
Feb 03, 2010 | Toshiba Sattelite A105-S2051 Notebook
ASUS F5RL-AP360E, Intel Core 2 Duo T2390 1.86GHz, 2GB DDR2, 250GB HDD, 15.4 WXGA, DVD SuperMulti Dua... PC Notebook Logo
112 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
