Question about Acer TravelMate 244XC Notebook
ACER Travelmate 244
I'm trying to use my recovery discs. I've done this before with no problem.
I press F2 to enter BIOS setup and I then select BOOT. Then, as instructed on screen, I select CD ROM DRIVE. Then I insert the system CD and press escape. I am invited to select yes to accept the changes but the machine does not allow me to do this. Instead I get a high pitched whine. If I then press Enter, Windows starts up and I go round in circles. What can I do?
Thank you in advance,
L Affley
    Sergeant:
  • 313 Answers
You could have a problem with the cdrom drive, thus the whine. Since it can't read the cdrom drive it goes then to read the hard drive (thus going around in circles).
If you have access to another computer, put the cd recovery drives on a flash drive, have the computer boot to the flash drive (if bios capable). The flash drive will recover your computer the same way your cd's did.
Let me know if this helped.
Posted on Dec 24, 2008
Ideapad Z560 neither accessing BIOS setup or is starting normally
Your bios seems corrupted. You will probably need to reflash from a thumb drive which is bootable. The F2 should get you to booting screen to access the thumb drive to boot from to flash the bios.
Dec 23, 2012 | Lenovo IdeaPad Z560 Notebook
Icant get my acer travelmate to boot from cd
You need to set the BIOS configuration to boot from the CD.
I'm not sure how the Travelmate enters the BIOS (Setup), it could be the F1, F2, ESC or DEL ket after the ACER logo and before the Windows logo appear on the screen. When the BIOS opens, go to the Config page, set the CD to be the first boot device.
Aug 15, 2011 | Acer TravelMate 722iTX PC Notebook
I need to press a key on my keyboard to start factory recovery
Hi and welcome to Fixya!
In order to revert the machine back to its factory setting, you need to have the recovery disk (if you don't have it, call the warranty support line of e-machines so they can provide it to you).
To restore Windows from your recovery discs, you will need to
insert the first backup disc and enable the F12 Boot Menu via the BIOS Setup
Utility.
1 Turn on your computer and insert the first system recovery disc into the
optical disc drive. Restart your computer.
2 During startup when the eMachines logo shows, press the F2 key to enter
BIOS Setup, where you can set system parameters.
3 Use the left and right arrow keys to select the Main submenu.
4 Use the up and down arrow keys to select F12 Boot Menu.
5 Use the F5 or F6 key to change F12 Boot Menu to Enabled.
6 Press the ESC key to enter the Exit submenu, press the ENTER key to Exit
Saving Changes. Press the ENTER key again to select Yes. The system will
reboot.
7 After rebooting, when the eMachines logo shows, press the F12 key to
open the Boot Menu. Here you can select which device to boot from.
8 Use the arrow keys to select the IDE1*, then press the ENTER key. Windows
will be installed from the recovery disc.
9 Insert the second recovery disc when prompted, then follow the onscreen
prompts to complete the restore.
10 Remove the recovery disc from the optical drive once the restore is
complete. Do this before rebooting your computer.
Hope this helps!
Takasashi
Jul 25, 2011 | eMachines E620-5885 Notebook
Hi How do I clear BIOS password set by misstake on Acer Travelmate 2413 LCI? I can not get in to BIOS setup
When you turn on computer look for Acer logo on boot up. Press F8 or F10 or F2 while the logo comes up several times (if you miss turn it off and try again)and then you can access your bios. Use arrow keys and enter to clear the password. Follow the bottom of the screen for directions and if you need more help let me know and thanks for using FixYa.
Feb 01, 2011 | Acer TravelMate 2413LCi Notebook
Cant restore acer netbook back to facotry settings did not do backup when purchased
Recovery procedure for Acer netbooks.
Important Information
The Recovery disc will help you to restore the hard drive with the original software content that was installed when you purchased your notebook. Follow the steps below to rebuild your hard drive. Your drive will be reformatted and all data will be erased. It is important to back up all data files before you use this option.
Restoration procedure:
1. Press the power button to turn the system on.
2. Select to boot from a USB optical drive. There are two ways to do this:
2.1. Press <F2> during the Power-On Self-Test (when the Acer logo is displayed onscreen after bootup) to enter BIOS Setup.
2.1.1. Select the Boot menu.
2.1.2. Refer to onscreen instructions to set the first device to any bootable optical disc drive.
2.2. Press <F12> during the Power-On Self-Test (when the Acer logo is displayed onscreen after bootup), and select the USB ODD from the list that appears.
3. Ensure the Recovery disc is in an external (USB) optical disc drive, and exit the boot selection menu, by selecting Exit Saving Changes from the Exit menu or pressing <F10>, or by pressing <Enter> as appropriate.
4. Select Exit Saving Changes from the Exit menu or press <F10>.
5. Follow the onscreen instructions to complete the installation process.
6. When you finish the recovery process, please remove the Recovery disc and insert the System disc again.
7. Restart your computer.
Create a Recovery USB device
You will need a second computer with an ODD to complete this procedure.
1) Insert the Recovery CD into the optical drive. Plug in a USB/flash drive with a minimum capacity of 1 GB.
2) Enter the BIOS setup and set the first boot device to the ODD. Save the changes and exit.
3) Allow your computer to boot up.
4) From the list of options, select "install2usb".
5) You will see a list of available disks, select the USB drive you plugged in.
6) Click the next button to complete the procedure.
7) Remove the USB ODD and USB/flash drive. You now have the Recovery system stored in your USB/flash drive, for future use if necessary.
Apr 23, 2010 | Acer Aspire One Netbook 8.9" Notebook
Make sure your scsi disk is turned on refer to manualwhen installing windows xp pro, acer travel mate 290. then states use another partition but comes with the same message one of your disk is damaged...
yes indeed nowadays laptops are designed for windows vista and better versions as these are equipped with SATA harddisks. to install windows xp in these systems u need to change SATA settings in bios which can be done by 1->pressing F2/DEL key during the starting acer empower people screen which v get once v switch on the laptop 2->in the BIOS screen go to MAIN tab by pressing right arrow 3->scroll down till u get SATA mode->press enter .two options ll be available 1.AHCI 2.IDE 4->select IDE and press enter. 5-> go to exit tab and select save and exit 6-> now try installing xp pro!!
Jan 11, 2010 | Acer TravelMate 290 Notebook
How do i restore my acer laptop to factory
Select models have the ability to have the operating system reinstalled from a hidden drive built into the netbook. To start the Acer eRecovery:
  1. Tap the Alt and F10 keys togther during Power-On Self-Test (POST while the Acer logo is being displayed).
  2. When prompted with a boot screen, hit the Enter key.
  3. After the Acer eRecovery program has loaded follow the prompts to reinstall the operating system.
If the ability to reinstall from the previous method is not available or fails during the recovery, recovery of the operating system will need to be from Acer Recovery Media. In order to recover the system using Acer Recovery Media an external optical disc drive is required.
  1. Press F2 to enter BIOS Setup during Power-On Self-Test (POST while the Acer logo is being displayed).
  2. Arrow over to "Boot".
  3. Ensure that the external optical drive is plugged into a USB port.
  4. Refer to on screen instructions to set the first device to "USB CDROM".
  5. Press the CD-ROM drive eject button and insert the System CD.
  6. Close the CD-ROM tray.
  7. Press "F10", then press "Enter" to save the changes and reboot the system.
  8. The netbook will boot from the Acer Recovery Media, follow the prompts to reinstall the operating system.
Please rate!
B_R
Jan 08, 2010 | Acer Aspire One Netbook 8.9" Notebook
HOW CAN I RESTORE MY ACER TRAVELMATE 2200 without the original disk??????????????? NOW CAN U ANSWER THAT...ASAP
Hello !
Note: the recovery process helps you restore the C: drive with the original software content that is installed when you purchase your notebook.
You can try ALT+F10 or CTRL+F10 during the initial boot cycle. This should prompt the laptop to access the recovery partition on the hard drive.
If it doesn't work :
Activate BIOS Setup Utility, press <F2> during POST.
Check the BIOS settings.
a Check to see if "Acer disc-to-disc" function is enabled or not.
b Make sure the [Acer D2D Recovery] setting in [Main] is
[Enabled].
c Exit the BIOS Setup Utility and save changes. The system will
reboot.
Hope this helps.
Sep 29, 2009 | Acer Travelmate 2200 Notebook
Won't go past opening screen with "acer" in the middle
If you have Vista, you can press F11 and go into the recovery mode, and it will prompt you to restore your computer to an earlier date.
Mar 22, 2009 | Acer TravelMate 290 Notebook
BIOS setup
hit F2 continuesly when the acer boot logo shows on the screen...thats all.
Dec 12, 2007 | Acer Aspire 5610-4648 Notebook
Acer TravelMate 244XC Notebook Logo
134 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
