Question about Olympus DS-30 Digital Voice Recorder
No space available.
On the machine, I deleted all sound files in all folders, and yet it still came up Memory Full when I hit record. Hooked it up to PC, could only find system files in folders A to E, Audible, Music and Podcast. So (and I know this was BAD), I took *all* files off and put them on PC. Got system error on machine.  Tried to put system files back on, one at a time. But machine said that there's no space to put them back on. Huh?!  Tried to put various files back on got got a mixture of error code (couldn't find associated files), and not enough space. Um, help?
  • Anonymous Jan 15, 2009
    Yes. Same problem and sent message to Olympus folks with no response to my problem
    President:
  • 919 Answers
Format of the DS-30
If you format the recorder, all files will be removed and all function settings will return to defaults except
date and time settings.
1 While the recorder is stopped, press the MENU button for 1 second or longer. The menu opens ( P91,93).
2 Press the + or – button to choose “Format”.
3 Press the OK or 9 button. The “Cancel” indicator flashes.
4 Press the + button to choose “Start”.
5 Press the OK button. After the “Data Will Be Cleared” message is on for two seconds, “Cancel” will turn on.
6 Press the + button again to choose “Start”.
7 Press the OK button. Formatting begins and an indicator flashes
on the display.
“Format Done” displays when formatting ends
Posted on Dec 29, 2008
I downloaded the contents of my Tascam DR-05 to my computer because it was full, but, instead of doing it as always, by just downloading the soundfiles, I copied the file folder dr005 to my computer,
Eric have you tried to do a "Quick Format"? If I'm not mistaken when that is done, you re-format your card and the small memory in the DR05. I had trouble with mine at first but when I did the formatting after I put the bigger 2GB memory card in the DR05 worked great. I record on "All Files" too, that seems to work well also.
Hope that helps,
Patrick
Oct 14, 2014 | Tascam DR-05 Portable Digital Recorder
Olympus DS-30 recorder: memory is full but there are no files to delete
1.Press the FOLDER button to choose a folder.
Every time the FOLDER button is pressed, it cycles through folders and the List display will appear (+P20).
Press the + or button to choose the file you want to erase.
Press the ERASE button. The “Cancel” indicator flashes.
Press the + button to choose “Erase”.
5
Press the OK button. The display changes to “File Erase!” and erasing will start. “Erase Done” is displayed when the file is erased. File numbers will be reassigned automatically
Apr 04, 2008 | Olympus DS-30 Digital Voice Recorder
Deleting tracks off 4gb sa2640 gogear
The files are not deleted from the device but moved to the recycle bin. To completely remove the files from the MP3 player, use the following procedure:
1. Open Windows Explorer by double clicking the My Computer icon on your desktop.
2. Click on the Tools menu and select Folder Options.
3. Select the Tab View and check to select the Show hidden Files and Folders option.
4. Navigate to the device. A folder called recycle bin is available. Completely remove this folder from the device.Once the recycle bin folder is removed, the files are completely removed from the device and the free space is available.
Mar 27, 2014 | Philips GOGEAR SA6045 MP3 Player
My memory card having corrupted file name 'PH0228~1.JPG' when i delete folders from memory card allfolders deleting except the file containing folder. after removing it from pc it automitically retrive all...
Find the memory card in your "My computer" directory. Hit the windows key and E at the same time to bring it up. Right click the card, then select "Format...". From here you can format the card to FAT32 to completely erase everything and make it like new again. If the formatting fails, the card has a hardware corruption and should be replaced.
~KenjiFox
Jan 07, 2011 | Computers & Internet
After deleting pictures I never get 40GB of memory space back
I found the same thing. Had to go to "my computer" , load up the photobank icon.
Click on the cards folder and then delete each folder.
THEN ,after clearing off the photobank, go to the desktop and empty the recycle bin. You will get the 40gigs back.
Feb 09, 2010 | SmartDisk PhotoBank PB40 40 GB USB 2.0...
Sony ICD-UX71F memory problems
You need to have it connected to your Mac and then empty your Trash (on the Mac) to clear the memory on the dictaphone.
Aug 15, 2009 | Sony ICD-UX80 Handheld Digital...
I can't delete files from my memory stick on my cell phone
you need to go into the media folder on your phone and then look for option to go to card, then when you are in the card folder look for options, then hit options and look for option to format card, hit format and it will probably give you a message saying are you sure because if you do this it will delete all the files on card, hit YES! and then it should delete all the files and be good to go!!
Jun 19, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
Sony ICD-UX70/UX80 digital recorder...memory full problem
I solved the problem by connecting my Sony IC Recorder to the USB port on my McBook Pro computer and then emptying the trash can on the Mac computer. Visually (flashing red indicator light) and audibly (the recorder's sound that indicates something being erased), it was clear that mp3 files were finally, really being erased on the Sony recorder even though the recorder's own screen display had previously shown only empty folders and no files. Dragging files to the trash can doesn't really erase them unless you also empty the trash. All dragging to the trash can does is somehow mark the files in a way that, unfortunately, makes them invisible to Sony's file detection system.
Chuck in Omaha
Apr 21, 2009 | Sony ICD-UX80 Handheld Digital...
USB with plenty of capacity but apparently no availability
i just had this same problem. go to tools > folder options > view, and under hidden files and folders, click on show hidden files and folders. then click okay. then delete those hidden files, which were written overtime and stored onto the usb without your knowledge. the usb will have full memory space after you're done :)
Oct 06, 2008 | Dane-Elec DaneElec 4GB USB Drive Copper...
Olympus DS-30 Digital Voice Recorder Logo
358 people viewed this question
Top Olympus Audio Players & Recorders Experts
pankaj rautela
pankaj rautela
leoz
Level 1 Expert
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
