Question about Mitsubishi CK-35308 35" TV
Mitsubishi CK-3513R - Horizintal white line
My TV is actually a Mitsubishi CK-3513R 35 inch, not the CK-35308. I didn't see mine in the product list. It only has a single horizontal line across the center of the screen. I think it is the Vertical IC, but I'm not sure how to locate or identify it. I have worked on TVs many years ago when they used vaccume tubes. I don't believe it will be difficult to fix if I can identify the component. Is this IC soldered in or in a socket? Your help will be appreciated. Thanks in advance.
Check timer//
Posted on Nov 11, 2007
    Genius:
  • 1,074 Answers
This ic is soldered onto the board with a heat sink it is related to horizontal circuit.your problem could also be the flyback.good luck
Posted on Apr 14, 2007
Tv remote codes mitsubishi model ck 31302
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Try this link too
http://remotesearch.blogspot.com/
Apr 11, 2014 | Directv Televison & Video
No picture. Just a thin horizontal band of light running through the center of TV.
HI,
Your tv has problem with its vertical scanning side. vertical scanning output ic (integrated circuit ) may have some problem ( faulty or dry soldering in its leads). You can easily find out the vertical ic on your tv. there will be four wire coming from the coil which is fitted on the picture tube neck, of which 2 will goto horizontal scanning section and the remaining two will go to vertical scanning section. just follow the two thin wire (normally in color green and yellow ). it will goto a socket on the main board. follow the track on the board. it will lead u to vertical scanning section. check for any dry soldering, if not , replace the ic.
ok
Mar 07, 2011 | Mitsubishi CK-35308 35" TV
Power
Will it not turn on?
May 05, 2010 | Mitsubishi CK-35308 35" TV
Sound takes up to an hour to come on, Mitsubishi 35'' tv
A $700 dollar estimate for a sound problem seems out of line - get asecond opinion (did some one look at it or just a guess). If the sound eventually comes on you probably have a connection (internal) problem or a intermittent part in audio section -cap o/p IC.
If you use a satellite or cable box can you hook your sound from that to an audio system thereby bypassing the TV?
Sep 30, 2009 | Mitsubishi CK-35308 35" TV
Flatline!
the vertical drive ic that drives the yoke for vertical sweep has blown.
sometimes it is solder problems like sharp and toshiba had.
the part is 10$ the pc board will label it ,the yoke is the coil setup on the picture tube.if you follow the wiring half goes to the horizontal drive,and the others to the vertical section.the chip drives the coil directly.there are VERY high voltages in there ,even turned off. the pix tube cap on top is 30000v. like a stun gun.the horizontal drive 2000 volts and the main power supply 165 volts dc high current.you need a special setup to discharge the picture tube.
May 15, 2009 | Mitsubishi CK-35308 35" TV
I have a 35-inch Mitsubishi TV Model CK-35MX2. It is 15 years old but has never had a problem. Recently, when I first turn it on in the morning, the picture has a vertical roll until it warms up and after...
I have a Mitsubishi  "CS-3515R.  Serial number 528801. When I turn it on by remote or on the set itself, I can hear the power come on.  BUT there is no picture and no sound.  What do I do?
Oct 20, 2008 | Televison & Video
White horizontal line down middle of TV screen
caution whenever you see horizontal line please reduce brightness of your tv for safety of crt. your problem in vertical section only mostly due to loose contact in connector,print or loose components.
Sep 20, 2007 | Mitsubishi CS-35505 35" TV
Mistubishi Diva Horizintal Strip Picture on Tube
Nope, the good news is that it is NOT a Tube problem! From your description, it looks more like a Cold solder in the Vertical Output stages (80% probability. Another possibility is dried out Electrolytic Capacitors in the same stages, or in the Power supply Line to the Vertical Output Stage. Nothing you can do, unless you know solid state electronics. Better get a good Technecian to have a look. he will locate the Cold solder quickly enough, and do a resolder.
May 12, 2007 | Mitsubishi CS-35505 35" TV
Televison & Video Logo
281 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
