Question about Jabra FS258 Wireless Headset
Jabra FS258 Wireless Headset does not charge
Light blinks a bit and then nothing
SOURCE: jabra bt160
hold the button down for a long time
Posted on Jul 12, 2007
SOURCE: CHARGING My Jabra bt160
I think something's goofy with these headsets. I bought 2 of them recently (one for me and one for my g/f). Within a week or so, she told me hers just "died" - and she couldn't get the blue light to come on when it was plugged into the charger.
Mine acted dead too, just a day or so before she told me about her problem. On mine, I think I just held down the "volume down" button and the main button at the same time for about 15 seconds and it appeared to "reset" it. That apparently didn't work for hers, but oddly enough - after a few days, we plugged it into my charger and it started working again!
Posted on Dec 11, 2007
  • 4 Answers
SOURCE: Jabra BT2050 blinks three times; doesnot pair up
Hold round center button for 10 seconds, light will stay on and be in pairing mode.
Posted on Dec 08, 2009
  • 16 Answers
SOURCE: jabra bt 250v not charging or cannot use headset.
Try this link to help you on this site it is a battery problem
http://www.fixya.com/support/t190081-jabra_bt250v_indicator_light_doesnt
Posted on Jan 07, 2010
SOURCE: Jabra BT650 won't turn on. green light blinks only
For a while I was not able to figure out how to turn the Jabra Halo headset on. What you need to do is unfold the headset and then push the hinged portion into itself, which will lock it in place so that it will no longer hinge for the time being.
Posted on Oct 28, 2010
My ear piece is not working, when I put it on charge the light does not show it is charging what can I do ?
When there is no light, while connected to the charger, it is NOT charging. You should checK the charger and the power cord. Eventually check the connector in the headset.
Perhaps you even can borrow for a few moments a charger from a friend? if another charges connected the light goes on, you need another charger. If nothing changes I think the little battery inside is defect. Don't bother buying and replacing the battery, when it almost costs the same as a new headset.
Jul 28, 2014 | Jabra Neonode N2 / N 2 MOBILE/CELL PHONE...
Jabra BT650 won't turn on. green light blinks only while charging.
Oct 14, 2010 | Jabra BT650 Bluetooth Headset Halo
Don't know passkey
Jabra pass key is 0000 this fixed my problem
Dec 21, 2009 | Jabra FS258 Wireless Headset
My Jabra headset won't pair with my phone--my phone can't "discover" the headset. The headset is charged and when it is turned on, it blinks three times in a row
Assuming you're talking about the Jabra BT2050 headset press and hold the center (round) button for at least 10 seconds; light will stay solid entering the pairing mode. Follow instructions on your phone.
Dec 14, 2009 | Jabra BT2050 Bluetooth Headset
Nov 20, 2009 | Jabra BT2050 Bluetooth Headset
My jabra BT160 won't charge
i had the same problem with mine. the problem is with the completely empty battery.
solution is to disassemble it and force charge the battery inside.
you have to cut any usb cable leaving the side which connects to pc and remove the insolation from red and black wires. connect them for few seconds to battery soldering points on jabra board (red to red, black to black, sometimes you have to scratch the solder a bit if it oxidized a bit). once you see the light you can start charging it normally.
Sep 23, 2009 | Jabra BT160 Wireless Headset
Steady Red Light
From the sounds of this.. It's all due to bad keying of the polarized charging plug. The solid red light PROBABLY means you're battery is pretty darn dead. It'll need a new battery(not worth the cost imho. get a new jabra, and be happy once again) At a certain low voltage, the red light starts blinking. when it drops below the preset threshold, it will shut off completely. If it sits too long at this discharged rate, the battry WILL self-terminate. If the voltage drops below a certain level, it's ruined. Also note, most Li-ion cells will only last a few years. 2-3 years of "full power" is usual. Mine's 2 years old(steady usage), and showing signs of it's age.
"My red light won't go off even though I charged it all night.
Also, a small piece of plastic came off the charge opening. I don't know if this is will pose a problem to the use of the Jabra BT150."
This is probably the most telling bit of information. It means you DID plug the charger in upside down. It will NEVER charge in that configuration, as it is supplying power to the completely wrong pins. If the battery was good to start with, it shouldn't hurt the headset, but never know. I have accidentily plugged it in backwards for a couple min before noticing, with no ill efect, but YMMV.
"Doesn't anyone from the Jabra manufacturer check this site?"
NO (especially not for discontinued products)
Oct 05, 2007 | Jabra BT150 Wireless Headset
Not sure if Jabra bluetooth headset or charger that not working
I had the same problem, called support, they told me battery is defective or too old and doesn't accept the charge. Battery in a headset is hardwired and can't be replaced, so the whole thing is trash :(
May 26, 2007 | Jabra BT250 Consumer Headset
Jabra FS258 Wireless Headset Logo
Top Jabra Radio Communications Experts
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Mitch
Mitch
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
