Question about Epson Stylus CX6600 All-In-One InkJet Printer
Epson Stylus DX 8400
Hi,Marry Christmas !
I recently bought this printer(Epson Stylus DX 8400 ) without cartridge(Used printer).
I bought anet set of cartridge and installed them;but it still gives this error message "Ink cartridges cannot be recognized"
I'd be glad if u could help me in.
Salman Majd
  • Anonymous Apr 27, 2009
    Cannot recognize...
  • John Sparozich May 11, 2010
    Did you buy the correct cartridges for your model printer, as they are all diffrent and will only work with the printer that they are made to work with?
    Did you remove the tape?
All ink cartridges full but wont print black, dx 8400, please help
try to perform a head cleaning process for a few cycles then try to print again... this may also depend on how long was the printer been stored for it to have clogged nozzles
Jul 11, 2011 | Epson Stylus DX8400 All-In-One InkJet...
Epson Stylus DX 8400 All cartridges are recognised but the blue will not print at all, tried new cartridge, no change.
First, did you make sure all the adhesive tape was removed from the cartridge? Second, try printing a test page or preforming an alignment (or cartridge alignment--same thing). You should be able to do this by accessing your printer utilities or setup software that came with the device. Sometimes there's an actual button or menu screen on the device that will let you do it that way.
If all else fails, reinstall the drivers that came with the printer and that should take care of it.
Mar 21, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I have a supermarket till receipt stuck in the works of my epson dx 8400 how can I get it out
***hi there,il be willing to help you on that. ****
If paper is stuck inside, turn off the Epson Stylus CX8400 Series.
Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX8400 Series back on.
***if my troubleshooting steps are helpful, pls vote for me, i will appreciate it, so that I can be a part of fixya, thanks, Godbless****
Feb 17, 2010 | Epson CX8400 All-In-One InkJet Printer
If ink cartridge Unrecognizable, there are two posibilities : Chip Error at ink tank, or printer error. For chip error, try to plug the ink tank to another printer (same type). If the ink tank recognized by other printer, so the problem is printer.
So ;
1. Check chip conector at head carriage.
2. Check the wiring of the head, and chip.
If two point above is ok, the last action is check the power supply and board. It may be epprom is damage.
May 28, 2009 | Epson Stylus DX8400 All-In-One InkJet...
It sounds like you have incompatible cartridges for your printer... Some folks have reported that disabling the Status monitor and turning the printer off/on, plus rebooting the computer can solve this but that's just something I've heard.
You may want to double check with the ink supplier that they have provided the correct cartridges for your DX rather than a CX model.
May 17, 2009 | Epson Stylus DX8400 All-In-One InkJet...
Need to reset ink cartridges without spending money
Check with a cartridge refill supplier. They might sell you the same chip resetter they use. I know they do here. They even sell it in a kit with the inks.
Apr 21, 2009 | Office Equipment & Supplies
I've got the Epson Stylus DX 8400 printer. when I put the cartridge,this message come up: "ink cartridges cannot be recognized." txs
I had the same problem too.  I went to the Epson website and they gave instructions to shake the cartridge 4-5 times prior to installing.   It worked!!!  I tried alot of things before I saw that I needed to shake the cartridge.  Definitely give this a try if you haven't already.
Dec 27, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Changing ink in a epson stylus 8400
on the printer push setup, then push ink levels from there you should be able to select the change cartridge and be good to go
Aug 02, 2008 | Epson CX8400 All-In-One InkJet Printer
Epson Stylus CX6600 All-In-One InkJet Printer Logo
195 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
